  3. relay with button...relay not physically changing state
12 Posts 3 Posters 4.3k Views 3 Watching
  • T Offline
    T Offline
    Ticupolu
    Hi all, please help i'm having issues with relay button sketch...relay doesn't change state when changing physical switch, i can see it changing in oh2 and arduino serial monitor i'm pretty new to this and don't know why?? other than that relay works perfect with oh2 here is my sketch
    // MySensor Debug
    // Enables repeater functionality (relays messages from other nodes)
    //#define MY_REPEATER_FEATURE
    #define MY_NODE_ID 50
    #define MY_RF24_CE_PIN 40
    #define MY_RF24_CS_PIN 53
    #define MY_RF24_MOSI_PIN 51
    #define MY_RF24_MISO_PIN 50
    #define MY_RF24_SCK_PIN 52
    #include <Bounce2.h>
    #include <DHT.h>
    #include <OneWire.h>
    #define RELAY_PIN    22  // Arduino Digital I/O pin number for relay
    #define RELAY_PIN_2  23
    #define RELAY_PIN_3  24
    #define RELAY_PIN_4  25
    #define RELAY_PIN_5  26
    #define RELAY_PIN_6  27
    #define BUTTON_PIN   9  // Arduino Digital I/O pin number for button
    #define BUTTON_PIN_2 10
    #define BUTTON_PIN_3 11
    #define BUTTON_PIN_4 12
    #define BUTTON_PIN_5 17
    #define BUTTON_PIN_6 18
    #define CHILD_ID 11 // Id of the sensor child for 1st relay
    #define CHILD_ID_2 12 // Id of the sensor child for 2nd relay
    #define CHILD_ID_3 13
    #define CHILD_ID_4 14
    #define CHILD_ID_5 15
    #define CHILD_ID_6 16
    #define CHILD_ID_HUM1 7
    #define CHILD_ID_TEMP1 8
    #define MAX_ATTACHED_DS18B20 1
    #define MOTION_DATA_PIN 5
    #define CHILD_ID_MOTION 5
    // Relay status
    #define RELAY_ON 1
    #define RELAY_OFF 0
    // Source of state change (used when printing debug information)
    #define CHANGE_STATE_SOURCE_RADIO 0
    #define CHANGE_STATE_SOURCE_SWITCH 1
    #define DHT1_DATA_PIN 2
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 5000;
    float lastTemp1;
    float lastHum1;
    bool lastMotion = false;
    uint8_t nNoUpdatesTemp1;
    uint8_t nNoUpdatesHum1;
    uint8_t nNoUpdatesMotion;
    bool metric = true;
    int numSensors=0;
    bool receivedConfig = false;
    Bounce debouncer = Bounce();
    int oldValue;
    bool state;
    Bounce debouncer2 = Bounce();
    int oldValue2;
    bool state2;
    Bounce debouncer3 = Bounce();
    int oldValue3;
    bool state3;
    Bounce debouncer4 = Bounce();
    int oldValue4;
    bool state4;
    Bounce debouncer5 = Bounce();
    int oldValue5;
    bool state5;
    Bounce debouncer6 = Bounce();
    int oldValue6;
    bool state6;
    MyMessage msgDallas(0,V_TEMP);
    MyMessage msg(CHILD_ID, V_LIGHT);
    MyMessage msg2(CHILD_ID_2, V_LIGHT);
    MyMessage msg3(CHILD_ID_3, V_LIGHT);
    MyMessage msg4(CHILD_ID_4, V_LIGHT);
    MyMessage msg5(CHILD_ID_5, V_LIGHT);
    MyMessage msg6(CHILD_ID_6, V_LIGHT);
    MyMessage msgHum1(CHILD_ID_HUM1, V_HUM);
    MyMessage msgTemp1(CHILD_ID_TEMP1, V_TEMP);
    MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
    DHT dht;
    void before()
      sensors.begin();
    void presentation() {
      sendSketchInfo("Double Relay & Button", "0.2");
      present(CHILD_ID, S_LIGHT);
      present(CHILD_ID_2, S_LIGHT);
      present(CHILD_ID_3, S_LIGHT);
      present(CHILD_ID_4, S_LIGHT);
      present(CHILD_ID_5, S_LIGHT);
      present(CHILD_ID_6, S_LIGHT);
      present(CHILD_ID_MOTION, S_MOTION);
      present(CHILD_ID_HUM1, S_HUM);
      present(CHILD_ID_TEMP1, S_TEMP);
      pinMode(MOTION_DATA_PIN, INPUT);
    //numSensors = 1;
      for (int i =0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
         present(i, S_TEMP);
      // Setup the button
      pinMode(BUTTON_PIN, INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN, HIGH);
      // Setup the button
      pinMode(BUTTON_PIN_2, INPUT);
      digitalWrite(BUTTON_PIN_2, HIGH);
       // Setup the button
      pinMode(BUTTON_PIN_3, INPUT);
      digitalWrite(BUTTON_PIN_3, HIGH);
       // Setup the button
      pinMode(BUTTON_PIN_4, INPUT);
      digitalWrite(BUTTON_PIN_4, HIGH);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      debouncer2.attach(BUTTON_PIN_2);
      debouncer2.interval(5);
      debouncer3.attach(BUTTON_PIN_3);
      debouncer3.interval(5);
      debouncer4.attach(BUTTON_PIN_4);
      debouncer4.interval(5);
      debouncer5.attach(BUTTON_PIN_5);
      debouncer5.interval(5);
      debouncer6.attach(BUTTON_PIN_6);
      debouncer6.interval(5);
      // Set the initial values of oldValue/oldValue2 variables from status of physical switches
      //  if this is not done the loop() will detect status change and switch the relays on or off
      debouncer.update();
      debouncer2.update();
      debouncer3.update();
      debouncer4.update();
      debouncer5.update();
      debouncer6.update();
      oldValue = debouncer.read();
      oldValue2 = debouncer2.read();
      oldValue3 = debouncer3.read();
      oldValue4 = debouncer4.read();
      oldValue5 = debouncer5.read();
      oldValue6 = debouncer6.read();
      setRelayState(RELAY_PIN, RELAY_OFF);
      pinMode(RELAY_PIN, OUTPUT);
      digitalWrite(RELAY_PIN_2, RELAY_OFF);
      pinMode(RELAY_PIN_2, OUTPUT);
       digitalWrite(RELAY_PIN_3, RELAY_OFF);
      pinMode(RELAY_PIN_3, OUTPUT);
       digitalWrite(RELAY_PIN_4, RELAY_OFF);
      pinMode(RELAY_PIN_4, OUTPUT);
      digitalWrite(RELAY_PIN_5, RELAY_OFF);
      pinMode(RELAY_PIN_5, OUTPUT);
      digitalWrite(RELAY_PIN_6, RELAY_OFF);
      pinMode(RELAY_PIN_6, OUTPUT);
      state = loadState(CHILD_ID);
      setRelayState(RELAY_PIN, state);
      state2 = loadState(CHILD_ID_2);
      setRelayState(RELAY_PIN_2, state2);
      state3 = loadState(CHILD_ID_3);
      setRelayState(RELAY_PIN_3, state3);
      state4 = loadState(CHILD_ID_4);
      setRelayState(RELAY_PIN_4, state4);
      state5 = loadState(CHILD_ID_5);
      setRelayState(RELAY_PIN_5, state5);
      state6 = loadState(CHILD_ID_6);
      setRelayState(RELAY_PIN_6, state6);
      bool tripped = digitalRead(MOTION_DATA_PIN) == HIGH;
    if (tripped || nNoUpdatesMotion == FORCE_UPDATE_N_READS) {
        lastMotion = tripped;
        Serial.println(tripped);
        send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
        nNoUpdatesMotion = 0;
      else if (lastMotion) {
      else {
        nNoUpdatesMotion++;
      wait(conversionTime);
      for (int i = 0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
         //Only send data if temperature has changed and no error
        //#if COMPARE_TEMP == 1
       // if (lastTemperature[i] != temperature && temperature != -127.00 && temperature != 85.00) {
       // #else
       // if (temperature != -127.00 && temperature != 85.00) {
        //#endif
          send(msgDallas.setSensor(i).set(temperature,1));
          Serial.print("Dallas");
          Serial.println(i);
          Serial.println(" :");
        Serial.println(temperature);
      wait(UPDATE_INTERVAL);
      dht.setup(DHT1_DATA_PIN); // set data pin of DHT1 sensor
      wait(dht.getMinimumSamplingPeriod());
      dht.readSensor(true);
      float temperature1 = dht.getTemperature();
      if (isnan(temperature1)) {
      } else if (temperature1 != lastTemp1 || nNoUpdatesTemp1 == FORCE_UPDATE_N_READS) {
        lastTemp1 = temperature1;
        if (!metric) {
          temperature1 = dht.toFahrenheit(temperature1);
        // Reset no updates counter
        nNoUpdatesTemp1 = 0;
        temperature1 += SENSOR_TEMP_OFFSET;
        send(msgTemp1.set(temperature1, 1));
        //#ifdef MY_DEBUG
        //Serial.print("T1: ");
        //Serial.println(temperature1);
        //#endif
      } else {
        nNoUpdatesTemp1++;
      float humidity1 = dht.getHumidity();
      if (isnan(humidity1)) {
      } else if (humidity1 != lastHum1 || nNoUpdatesHum1 == FORCE_UPDATE_N_READS) {
        lastHum1 = humidity1;
        nNoUpdatesHum1 = 0;
        send(msgHum1.set(humidity1, 1));
        #ifdef MY_DEBUG
        Serial.print("H1: ");
        Serial.println(humidity1);
      } else {
        nNoUpdatesHum1++;
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      int value2 = debouncer2.read();
      int value3 = debouncer3.read();
      int value4 = debouncer4.read();
      int value5 = debouncer5.read();
      int value6 = debouncer6.read();
      if (value != oldValue) {
        send(msg.set(state ? false : true), true); // Send new state and request ack back
        // Write some debug info
        printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID, value);
      oldValue = value;
      if (value2 != oldValue2) {
        send(msg2.set(state2 ? false : true), true); // Send new state and request ack back
        printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID_2, value2);
      oldValue2 = value2;
     if (value3 != oldValue3) {
        send(msg3.set(state3 ? false : true), true); // Send new state and request ack back
        printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID_3, value3);
      oldValue3 = value3;
      if (value4 != oldValue4) {
        send(msg4.set(state4 ? false : true), true); // Send new state and request ack back
        printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID_4, value4);
      oldValue4 = value4;
      if (value5 != oldValue5) {
        send(msg5.set(state5 ? false : true), true); // Send new state and request ack back
        printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID_5, value5);
      oldValue5 = value5;
      if (value6 != oldValue6) {
        send(msg6.set(state6 ? false : true), true); // Send new state and request ack back
        printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID_6, value6);
      oldValue6 = value6;
      if (message.isAck()) {
    #ifdef MY_DEBUG
        Serial.println(F("This is an ack from gateway"));
      else if (message.type == V_LIGHT && message.sensor == CHILD_ID) {
        // Change relay state
        state = message.getBool();
        // Store state in eeprom
        saveState(CHILD_ID, state);
        printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID, state);
      else if (message.type == V_LIGHT && message.sensor == CHILD_ID_2) {
        state2 = message.getBool();
        saveState(CHILD_ID_2, state2);
        printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID_2, state2);
      else if (message.type == V_LIGHT && message.sensor == CHILD_ID_3) {
       state3 = message.getBool();
        saveState(CHILD_ID_3, state3);
        printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID_3, state3);
      else if (message.type == V_LIGHT && message.sensor == CHILD_ID_4) {
        state4 = message.getBool();
        saveState(CHILD_ID_4, state4);
        printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID_4, state4);
      else if (message.type == V_LIGHT && message.sensor == CHILD_ID_5) {
        state5 = message.getBool();
        saveState(CHILD_ID_5, state5);
        printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID_5, state5);
      else if (message.type == V_LIGHT && message.sensor == CHILD_ID_6) {
        state6 = message.getBool();
        saveState(CHILD_ID_6, state6);
        printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID_6, state6);
    // Set status of a relay pin
    void setRelayState(byte relayPin, bool value) {
      digitalWrite(relayPin, value ? RELAY_ON : RELAY_OFF);
    // Print debug info, centralized in one place to minimize memory usage and have only one #ifdef MY_DEBUG for all state change messages
    void printStateChangedDebug(int source, int sensorID, bool value) {
    #ifdef MY_DEBUG
      Serial.print(F("Sensor value changed, source="));
      Serial.print(source == CHANGE_STATE_SOURCE_RADIO ? F("Radio") : F("Physical switch"));
      Serial.print(F(", Sensor="));
      Serial.print(sensorID);
      Serial.print(F(", New status: "));
      Serial.println(value);
    any idea?  i'm stuck thanks in advance!
    F Boots33B 2 Replies Last reply
    • T Ticupolu
      // MySensor Debug
      #include <DHT.h>
      // Relay status
      #define RELAY_ON 1
      #define RELAY_OFF 0
      float lastTemp1;
      float lastHum1;
      bool metric = true;
      int numSensors=0;
      int oldValue;
      bool state;
      int oldValue2;
      bool state2;
      int oldValue3;
      bool state3;
      int oldValue4;
      bool state4;
      int oldValue5;
      bool state5;
      int oldValue6;
      bool state6;
      DHT dht;
      void before()
        sensors.begin();
      //numSensors = 1;
           present(i, S_TEMP);
        // Setup the button
        // Setup the button
         // Setup the button
         // Setup the button
        debouncer.update();
        else {
          nNoUpdatesMotion++;
         // #else
          //#endif
            Serial.println(i);
          if (!metric) {
          //#ifdef MY_DEBUG
          //#endif
        } else {
          nNoUpdatesTemp1++;
          nNoUpdatesHum1 = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum1++;
        debouncer.update();
        oldValue = value;
        oldValue2 = value2;
        oldValue3 = value3;
        oldValue4 = value4;
        oldValue5 = value5;
        oldValue6 = value6;
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
      F Offline
      F Offline
      FotoFieber
      @Ticupolu
      Do you have a wiring diagram?
      Which arduino do you use'
      Do you really need waits to save batery?
      T 1 Reply Last reply
      • T Offline
        T Offline
        Ticupolu
        thank you for response ..i'm using mega 2560 no i dont have diagram and do i need waits?? im not using batteries....trying to show you what is going on in serial monitor but dont know how to post it
        • F FotoFieber
          @Ticupolu
          T Offline
          T Offline
          Ticupolu
          @FotoFieber here is my serial monitor...i first close relay with oh2(it works my relay closes physically) then with physical switch (it shows relay is changing state in oh2 and serial monitor but not physically on relay)
          70185 TSF:MSG:SEND,1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
          71721 TSF:MSG:SEND,50-50-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:18.6
          Dallas0
          18.60
          0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.2.0-beta
          4 MCO:BGN:BFR
          64 TSM:INIT
          65 TSF:WUR:MS=0
          72 TSM:INIT:TSP OK
          74 TSM:INIT:STATID=50
          76 TSF:SID:OK,ID=50
          77 TSM:FPAR
          114 TSF:MSG:SEND,50-50-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          586 TSF:MSG:READ,0-0-50,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          591 TSF:MSG:FPAR OK,ID=0,D=1
          2121 TSM:FPAR:OK
          2122 TSM:ID
          2123 TSM:ID:OK
          2125 TSM:UPL
          2128 TSF:MSG:SEND,50-50-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          2139 TSF:MSG:READ,0-0-50,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          2144 TSF:MSG:PONG RECV,HP=1
          2147 TSM:UPL:OK
          2148 TSM:READY:ID=50,PAR=0,DIS=1
          2153 TSF:MSG:SEND,50-50-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          2161 TSF:MSG:READ,0-0-50,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          2168 TSF:MSG:SEND,50-50-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
          2178 TSF:MSG:SEND,50-50-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
          2197 TSF:MSG:READ,0-0-50,s=255,c=3,t=6,pt=0,l=1,sg=0:M
          2204 TSF:MSG:SEND,50-50-0-0,s=255,c=3,t=11,pt=0,l=21,sg=0,ft=0,st=OK:Double Relay & Button
          2214 TSF:MSG:SEND,50-50-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.2
          2223 TSF:MSG:SEND,50-50-0-0,s=11,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          2231 TSF:MSG:SEND,50-50-0-0,s=12,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          2239 TSF:MSG:SEND,50-50-0-0,s=13,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          2247 TSF:MSG:SEND,50-50-0-0,s=14,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          2254 TSF:MSG:SEND,50-50-0-0,s=15,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          2263 TSF:MSG:SEND,50-50-0-0,s=16,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          2271 TSF:MSG:SEND,50-50-0-0,s=5,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
          2279 TSF:MSG:SEND,50-50-0-0,s=7,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          2286 TSF:MSG:SEND,50-50-0-0,s=8,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
          2292 MCO:REG:REQ
          2296 TSF:MSG:SEND,50-50-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
          2302 TSF:MSG:READ,0-0-50,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          2308 MCO:PIM:NODE REG=1
          2310 MCO:BGN:STP
          2314 TSF:MSG:SEND,50-50-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
          2320 MCO:BGN:INIT OK,TSP=1
          2324 TSF:MSG:SEND,50-50-0-0,s=5,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
          3862 TSF:MSG:SEND,50-50-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:18.6
          Dallas0
          18.60
          10467 TSF:MSG:READ,0-0-50,s=12,c=1,t=2,pt=0,l=1,sg=0:0
          Sensor value changed, source=Radio, Sensor=12, New status: 0
          10880 TSF:MSG:SEND,50-50-0-0,s=8,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.6
          10889 TSF:MSG:SEND,50-50-0-0,s=7,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:41.1
          H1: 41.10
          15897 TSF:MSG:SEND,50-50-0-0,s=5,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
          17434 TSF:MSG:SEND,50-50-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:18.6
          Dallas0
          18.60
          29453 TSF:MSG:SEND,50-50-0-0,s=5,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
          30990 TSF:MSG:SEND,50-50-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:18.6
          Dallas0
          18.60
          38007 TSF:MSG:SEND,50-50-0-0,s=8,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.7
          38017 TSF:MSG:SEND,50-50-0-0,s=7,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:41.0
          H1: 41.00
          43024 TSF:MSG:SEND,50-50-0-0,s=12,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
          Sensor value changed, source=Physical switch, Sensor=12, New status: 1
          43033 TSF:MSG:SEND,50-50-0-0,s=5,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
          43795 TSF:MSG:READ,0-0-50,s=12,c=1,t=2,pt=1,l=1,sg=0:1
          43800 TSF:MSG:ACK
          44573 TSF:MSG:SEND,50-50-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:18.7
          Dallas0
          18.70
          56590 TSF:MSG:SEND,50-50-0-0,s=5,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
          58127 TSF:MSG:SEND,50-50-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:18.7
          Dallas0
          18.70
          F 1 Reply Last reply
          • T Ticupolu
            Dallas0
            18.60
            4 MCO:BGN:BFR
            64 TSM:INIT
            65 TSF:WUR:MS=0
            72 TSM:INIT:TSP OK
            76 TSF:SID:OK,ID=50
            77 TSM:FPAR
            2121 TSM:FPAR:OK
            2122 TSM:ID
            2123 TSM:ID:OK
            2125 TSM:UPL
            2147 TSM:UPL:OK
            2292 MCO:REG:REQ
            2310 MCO:BGN:STP
            Dallas0
            18.60
            H1: 41.10
            Dallas0
            18.60
            Dallas0
            18.60
            H1: 41.00
            43800 TSF:MSG:ACK
            Dallas0
            18.70
            Dallas0
            18.70
            F Offline
            F Offline
            FotoFieber
            @Ticupolu
            Are thes buttons switches or push buttons?
            You call setRelayState only from the recieve functions. (Do I miss something?) This means, that relay changes must be initiated from outside and don't occur only from a button press.
            • T Offline
              T Offline
              Ticupolu
              limit switch
              • F FotoFieber
                @Ticupolu
                T Offline
                T Offline
                Ticupolu
                @FotoFieber from openhab2 controller on rpi3 it is for chicken coop door and use myopenhab app to open and close remotly
                • T Offline
                  T Offline
                  Ticupolu
                  is there anyway i can make it read and send instead of only send
                  • T Ticupolu
                    // MySensor Debug
                    #include <DHT.h>
                    // Relay status
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    float lastTemp1;
                    float lastHum1;
                    bool metric = true;
                    int numSensors=0;
                    int oldValue;
                    bool state;
                    int oldValue2;
                    bool state2;
                    int oldValue3;
                    bool state3;
                    int oldValue4;
                    bool state4;
                    int oldValue5;
                    bool state5;
                    int oldValue6;
                    bool state6;
                    DHT dht;
                    void before()
                      sensors.begin();
                    //numSensors = 1;
                         present(i, S_TEMP);
                      // Setup the button
                      // Setup the button
                       // Setup the button
                       // Setup the button
                      debouncer.update();
                      else {
                        nNoUpdatesMotion++;
                       // #else
                        //#endif
                          Serial.println(i);
                        if (!metric) {
                        //#ifdef MY_DEBUG
                        //#endif
                      } else {
                        nNoUpdatesTemp1++;
                        nNoUpdatesHum1 = 0;
                        #ifdef MY_DEBUG
                      } else {
                        nNoUpdatesHum1++;
                      debouncer.update();
                      oldValue = value;
                      oldValue2 = value2;
                      oldValue3 = value3;
                      oldValue4 = value4;
                      oldValue5 = value5;
                      oldValue6 = value6;
                    #ifdef MY_DEBUG
                    #ifdef MY_DEBUG
                    Boots33B Offline
                    Boots33B Offline
                    Boots33
                    wrote on last edited by Boots33
                    @Ticupolu The problem with your relay not switching from the local switch may be in your void recieve code.
                    When you switch the local switch it sends a message to the controller and asks for an ack back. It is this returning ack that is used to switch the relay.
                    At the top of your void receive you have code that i think is trapping the ack and stopping it from going any further. Basically your code says if this is an ack print some text else if it's not do the other things. So your ack is just doing a serial print.
                    I am not a big fan of multiple else if statements if they can be avoided and you really don't need to know if the incoming message is an ack or not anyway.
                    I have not tested it but you could try something like
                        switch (message.sensor) {
                            case CHILD_ID:
                              setRelayState(RELAY_PIN, state); // Change relay state
                              saveState(CHILD_ID, state);      // Store state in eeprom
                             break;
                            case CHILD_ID_2:
                             break;
                            case CHILD_ID_3:
                    	     break;
                            case CHILD_ID_4:
                             break;
                            case CHILD_ID_5:
                             break;
                    	    case CHILD_ID_6:
                             break;
                    Your project seems to have a lot going on so as @FotoFieber has said some sort of wiring diagram might also be useful.
                    • Boots33B Boots33
                              case CHILD_ID:
                               break;
                              case CHILD_ID_2:
                               break;
                              case CHILD_ID_3:
                      	     break;
                              case CHILD_ID_4:
                               break;
                              case CHILD_ID_5:
                               break;
                      	    case CHILD_ID_6:
                               break;
                      T Offline
                      T Offline
                      Ticupolu
                      @Boots33 thank you for your explanation and time on this ...i have tried your sketch and it works the relay are now changing state....the only thing that i forgot to mention is that my door open or closes right back after it leaves the limit switch. The relay needs to change state only when the limit switch gets hit not when it leaves lol i dont know if you understand, english is not my first language but i made some sort of wiring diagram like you mention i'm also opening a my project subject for Mysensors Smart chicken coop....new ideas are welcome
                      [0_1488324612760_Poulailler.fzz](Envoi en cours 100%)
                      Boots33B 1 Reply Last reply
                      • T Ticupolu
                        Boots33B Offline
                        Boots33B Offline
                        Boots33
                        @Ticupolu If you only want the relays to toggle when the limit switch is activated then you could add back the original code from the relay example sketch and see if that has the desired effect.
                        if (value != oldValue && value == 0) {
                          oldValue = value;
                          if (value2 != oldValue2 && value2 == 0) {
                          oldValue2 = value2;
                        • Boots33B Boots33
                            oldValue = value;
                            oldValue2 = value2;
                          T Offline
                          T Offline
                          Ticupolu
                          @Boots33 Yess! we got it this time the door relays and limit switch are acting just like i wanted...i will be testing the other 4 relays in the after noon... i wish i could be better at programming without your help i would be stuck thank you!
                          12.2k
