  3. Reflow Oven
Reflow Oven
31 Posts 13 Posters 35.9k Views 9 Watching
  • G
    G
    Gohper
    I have been looking at the ControLeo for a while.
    I already have an oven which I use for baking wet snuff.
    Today it has three DS18bB20 sensors which needs to be replaced. And I will try to get the sketch working on a Nano.
    Then will need two Nanos, one for board baking and one for baking snuff.
    Have anyone run the sketch on an ATMega328?
    • blaceyB
      blaceyB
      blacey
      Peter Easton, the ControLEO inventor, is about to release a servo-based automatic oven-door opener that will use the 4th relay to open the door at the end of the reflow cycle. I saw a prototype when I visited him recently but he is planning to launch it at the Maker Faire in San Francisco, CA this Thu/Fri, I plan to pick one up when I visit his booth.
      RJ_MakeR 1 Reply Last reply
      • blaceyB blacey
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @blacey I'm hoping, at some point, he offers upper and lower temperature zones and stored temperature profiles.. That would place his product far ahead of the rest.
        RJ_Make
        blaceyB 1 Reply Last reply
        • RJ_MakeR RJ_Make
          blaceyB
          blaceyB
          blacey
          @ServiceXp Have you sent that request directly to Peter? He is pretty responsive to suggestions...
          • blaceyB blacey
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @blacey Yes Sir.
            RJ_Make
            • bjornhallbergB
              bjornhallbergB
              bjornhallberg
              So, my reflow build is coming along ... slowly. Looking into plotting curves on a larger LCD, like the Zallus oven and using a small servo or stepper motor to open the door.
              One thing that is bugging me though is the reflect-a-gold tape. Costs a fortune and I can't even seem to find any or even an equivalent product in Sweden. What do you guys think about the Ebay / Ali knockoffs? Are they good enough? I mean I don't care if they fall short a few percent in heat reflection, I'm not building a spaceship here, as long as the adhesive holds up.
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                Not sure, but I think maybe the more important characteristic is it's "Sticky Power" :stuck_out_tongue: You don't want the tape coming loose..
                RJ_Make
                  @Staringlizard Cool! Is it this oven you're using? 14L, 1200W? Are you happy with the temperature ramp-up time?
                  A Former User
                  @bjornhallberg Sorry for late reply :(, I forgot about my post and did not get any update on mail. But yes, the link you posted is correct :)
                  I have not checked it very thoroughly yet, but so far it gets the job done with the automatic calibration from ControLeo. I even put a board in the oven 3-4 times without anything breaking.
                    These ovens are killing me here. No matter where I look I can't seem to find a convection oven at a reasonable price with quartz elements. It's either one or the other, or crazy prices or ridiculously large volumes that will take ages to heat without the addition of extra heating elements.
                    Here are my candidates so far:
                    http://www.amazon.it/Ariete-Cousine-Petit-Forno-Elettrico/dp/B004JLN2EW
                    10 litres, 1000w. Quartz. High W for the volume if it checks out.
                    http://www.amazon.co.uk/gp/product/B00K22YJEY
                    9 litres, 800w. Quartz. Looks a lot like the one Rocketscream used with great success.
                    http://www.harald-nyborg.se/wasco-miniugn-18l-1380w.html
                    18 litres, 1380W. Not quartz? But can be found locally. A bit low wattage for the volume.
                    Martin TellblomM
                    Martin TellblomM
                    Martin Tellblom
                    @bjornhallberg Did you find a good oven to use in Sweden? I'm looking in to building one myself now
                    MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
                    • S
                      stp715a
                      Thank you for sharing your build. Wondering since it has been a few years, how the Thermo-Tec adhesive is holding up?
                      Thank you.
                      • W
                        W
                        WVRick
                        I have a question. On the convection fan motor is the fan (pictured) for convection or is there another fan inclosed and the one pictured for cooling the motor? I like this build and plan on doing one.
