  3. Watermeterpulsesensor sketch ok?
3 Posts 2 Posters 1.5k Views 1 Watching
  • E
    E
    egbertje
    When i try the default sketch from the watermeterpulsesensor on an arduino nano, the complete "mysensors"network "hangs"and does not function anymore.
    If i delete the 2 new detected devices in my vera and restart the gateway then the other devices work again.
    If i program for example the energymeterpulsesensor in the same nano then these arduino works fine and the right devices are shown in the vera and show there values.
    What i also see is that when the devices from the watermeter sketch shows up in the vera, they dont show any information about sketch name, sketch version and parent id. These fields are empty.
    Or am i doing something wrong?
    • korttomaK
      korttomaK
      korttoma
      Did you upload the watermeter related files to Vera?
      D_WaterMeter1.json
      D_WaterMeter1.xml
      S_WaterMeter1.xml
      If these files are missing I think your MySensors plugin will hang if you include your watermeterpulsesensor.
      • Tomas
      • E
        E
        egbertje
        Korttoma,
        Thanks for your information.
        That was the solution!
        I had not read the extra info in the controller section that some sensors need additional files to upload to the Vera.
