  3. why mysensors is based on nrf24?
65 Posts 13 Posters 21.8k Views 11 Watching
  • R
    R
    Reza
    @VaZso @AWI thank you friends. if simple NRF with pcb antenna that you use (original) have a good connection with 15-20 m distance and 30-40 cm width wall ( a connection without any lost or failed packet) so NRF is good radio really. I have not experienced it until now.
    V 1 Reply Last reply
    • R Reza
      V
      V
      VaZso
      wrote on last edited by VaZso
      #62
      @Reza Don't forget it is only true if there are no other noises in that frequency like any WLAN radios at a nearby channel or microwave oven, etc.
      Even a bluetooth connection can cause some loss as it is hopping from frequency to frequency.
      Bluetooth works somewhat like in the tale - it does not interfere with other equipments but it interferes with all of them a bit...
      So, if data integrity is really important, one should handle re-sending missing informations by software especially in wider ranges of distance. However, internal retry also helps.
      (I don't know what mysensor's library do about this question.)
      R 1 Reply Last reply
      • V VaZso
        R
        R
        Reza
        @VaZso i see different channels in my home and all channel was never busy.i am sure this is just related to radio structure
        thank you
        • R Reza
          thank you
          V
          V
          VaZso
          @Reza What are you mean about "all channel was never busy"?
          (I assume you tried free channels.)
          Anyway, a simple wlan-scan only shows occupied wlan channels but not other communications (or noises) in the same frequency range.
          Anyway, some modifications of the antenna may highly affects signal strength.
          • V VaZso
            R
            R
            Reza
            @VaZso i see 0-85 channel and i see most is silent , but my controller and gateway is 1m distance with router (because controller connect with lan cable to router)
            anyway thank you. i think this is related to just chinese radio...
