  3. RGB Controller app on Vera causing NACK:0 messages on my sensor.
3 Posts 1 Posters 1.3k Views 1 Watching
  • C
    C
    CurtisMack
    Hi, I'm a first time poster, but plan on getting involved in this more.
    I have a custom made sensor that controls a single RGB LED. The SN value is set to "Dimmable RGBW LED". I think it is working well. It is controlled with a serial controller connected to a Vera3. The device registered 3 DimmableLight sensors which I can control perfectly using the sliders. I installed the RGB Controller app on my Vera, and registered the three sensors for the three colors. This is working well unless I choose a color that would turn on the sensor 2 color. The sensor seems to be throwing an error when trying to get a status on sensor 1, so something upstream skips setting a value for 2 and jumps to sensor 3.
    Here is a log from my sensor. There are a couple of custom debug messages, but I think they are self explanatory. It includes the boot, a few good results, and then a few bad at the end:
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSF:SID:OK,ID=3
    14 TSM:FPAR
    51 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    324 TSF:MSG:READ,0-0-3,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    328 TSF:MSG:FPAR OK,ID=0,D=1
    2058 TSM:FPAR:OK
    2059 TSM:ID
    2060 TSM:ID:OK
    2062 TSM:UPL
    2065 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2074 TSF:MSG:READ,0-0-3,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2079 TSF:MSG:PONG RECV,HP=1
    2081 TSM:UPL:OK
    2083 TSM:READY:ID=3,PAR=0,DIS=1
    2088 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2095 TSF:MSG:READ,0-0-3,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2102 TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    2110 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2132 TSF:MSG:READ,0-0-3,s=255,c=3,t=6,pt=0,l=1,sg=0:I
    2139 TSF:MSG:SEND,3-3-0-0,s=1,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=OK:
    2147 TSF:MSG:SEND,3-3-0-0,s=2,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=OK:
    2154 TSF:MSG:SEND,3-3-0-0,s=3,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=OK:
    2161 TSF:MSG:SEND,3-3-0-0,s=4,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=OK:
    2169 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=11,pt=0,l=17,sg=0,ft=0,st=OK:Dimmable RGBW LED
    2180 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    2186 MCO:REG:REQ
    2189 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2196 TSF:MSG:READ,0-0-3,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2201 MCO:PIM:NODE REG=1
    2203 MCO:BGN:STP
    Setting up: 32550
    Setting up: 52550
    Setting up: 62550
    5208 TSF:MSG:SEND,3-3-0-0,s=1,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    5215 TSF:MSG:SEND,3-3-0-0,s=2,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    5223 TSF:MSG:SEND,3-3-0-0,s=3,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    5264 !TSF:MSG:SEND,3-3-0-0,s=4,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=NACK:
    5270 MCO:BGN:INIT OK,TSP=1
    5273 TSF:MSG:READ,0-0-3,s=2,c=1,t=3,pt=0,l=2,sg=0:70
    Message for sensor: 2 Type : 3 newLevel : 70 requestedLevel : 70
    Changing level to 70, sensor 2, PIN 5
    5317 !TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=NACK:70
    5323 TSF:MSG:READ,0-0-3,s=3,c=1,t=3,pt=0,l=2,sg=0:93
    Message for sensor: 3 Type : 3 newLevel : 93 requestedLevel : 93
    Changing level to 93, sensor 3, PIN 6
    5334 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=OK:93
    25615 TSF:MSG:READ,0-0-3,s=2,c=1,t=3,pt=0,l=2,sg=0:33
    25619 TSF:MSG:ACK REQ
    25623 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:33
    Message for sensor: 2 Type : 3 newLevel : 33 requestedLevel : 33
    Changing level to 33, sensor 2, PIN 5
    25634 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:33
    43226 TSF:MSG:READ,0-0-3,s=1,c=1,t=3,pt=0,l=2,sg=0:37
    43231 TSF:MSG:ACK REQ
    43235 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:37
    Message for sensor: 1 Type : 3 newLevel : 37 requestedLevel : 37
    Changing level to 37, sensor 1, PIN 3
    43246 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:37
    64391 TSF:MSG:READ,0-0-3,s=1,c=1,t=3,pt=0,l=1,sg=0:0
    64396 TSF:MSG:ACK REQ
    64400 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=OK:0
    Message for sensor: 1 Type : 3 newLevel : 0 requestedLevel : 0
    Changing level to 0, sensor 1, PIN 3
    64410 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:0
    64420 TSF:MSG:READ,0-0-3,s=2,c=1,t=3,pt=0,l=1,sg=0:7
    64424 TSF:MSG:ACK REQ
    64429 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=OK:7
    Message for sensor: 2 Type : 3 newLevel : 7 requestedLevel : 7
    Changing level to 7, sensor 2, PIN 5
    64474 !TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=NACK:7
    64480 TSF:MSG:READ,0-0-3,s=3,c=1,t=3,pt=0,l=1,sg=0:0
    64485 TSF:MSG:ACK REQ
    64523 !TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=0,l=1,sg=0,ft=1,st=NACK:0
    Message for sensor: 3 Type : 3 newLevel : 0 requestedLevel : 0
    Changing level to 0, sensor 3, PIN 6
    64534 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=OK:0
    64543 TSF:MSG:READ,0-0-3,s=2,c=1,t=3,pt=0,l=1,sg=0:0
    64548 TSF:MSG:ACK REQ
    64551 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=OK:0
    Message for sensor: 2 Type : 3 newLevel : 0 requestedLevel : 0
    Changing level to 0, sensor 2, PIN 5
    64563 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:0
    80031 TSF:MSG:READ,0-0-3,s=1,c=1,t=3,pt=0,l=2,sg=0:95
    80035 TSF:MSG:ACK REQ
    80039 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:95
    Message for sensor: 1 Type : 3 newLevel : 95 requestedLevel : 95
    Changing level to 95, sensor 1, PIN 3
    80051 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:95
    80060 TSF:MSG:READ,0-0-3,s=2,c=1,t=3,pt=0,l=1,sg=0:0
    80065 TSF:MSG:ACK REQ
    80069 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=OK:0
    80080 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:0
    80090 TSF:MSG:READ,0-0-3,s=3,c=1,t=3,pt=0,l=1,sg=0:0
    80094 TSF:MSG:ACK REQ
    80098 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=OK:0
    80109 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:0
    121469 TSF:MSG:READ,0-0-3,s=1,c=1,t=3,pt=0,l=1,sg=0:0
    121475 TSF:MSG:ACK REQ
    121479 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=OK:0
    121490 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:0
    121499 TSF:MSG:READ,0-0-3,s=2,c=1,t=3,pt=0,l=1,sg=0:0
    121504 TSF:MSG:ACK REQ
    121508 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=OK:0
    121520 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:0
    121529 TSF:MSG:READ,0-0-3,s=3,c=1,t=3,pt=0,l=2,sg=0:95
    121534 TSF:MSG:ACK REQ
    121538 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:95
    Message for sensor: 3 Type : 3 newLevel : 95 requestedLevel : 95
    Changing level to 95, sensor 3, PIN 6
    121549 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:95
    149488 TSF:MSG:READ,0-0-3,s=1,c=1,t=3,pt=0,l=1,sg=0:0
    149493 TSF:MSG:ACK REQ
    149531 !TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=NACK:0
    149542 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=OK:0
    149552 TSF:MSG:READ,0-0-3,s=3,c=1,t=3,pt=0,l=2,sg=0:10
    149557 TSF:MSG:ACK REQ
    149561 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:10
    Message for sensor: 3 Type : 3 newLevel : 10 requestedLevel : 10
    Changing level to 10, sensor 3, PIN 6
    149572 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:10
    192808 TSF:MSG:READ,0-0-3,s=1,c=1,t=3,pt=0,l=1,sg=0:0
    192813 TSF:MSG:ACK REQ
    192850 !TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=NACK:0
    192862 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=OK:0
    192872 TSF:MSG:READ,0-0-3,s=3,c=1,t=3,pt=0,l=2,sg=0:10
    192877 TSF:MSG:ACK REQ
    192880 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:10
    192892 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:10
    239961 TSF:MSG:READ,0-0-3,s=1,c=1,t=3,pt=0,l=2,sg=0:95
    239965 TSF:MSG:ACK REQ
    240004 !TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=NACK:95
    240015 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=OK:95
    240025 TSF:MSG:READ,0-0-3,s=3,c=1,t=3,pt=0,l=1,sg=0:0
    240029 TSF:MSG:ACK REQ
    240033 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=OK:0
    240045 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:0
    272983 TSF:MSG:READ,0-0-3,s=1,c=1,t=3,pt=0,l=1,sg=0:2
    272988 TSF:MSG:ACK REQ
    273026 !TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=NACK:2
    Message for sensor: 1 Type : 3 newLevel : 2 requestedLevel : 2
    Changing level to 2, sensor 1, PIN 3
    273037 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=OK:2
    273046 TSF:MSG:READ,0-0-3,s=3,c=1,t=3,pt=0,l=2,sg=0:95
    273051 TSF:MSG:ACK REQ
    273055 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:95
    273067 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:95
    312927 TSF:MSG:READ,0-0-3,s=1,c=1,t=3,pt=0,l=2,sg=0:95
    312932 TSF:MSG:ACK REQ
    312936 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:95
    312947 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:95
    312956 TSF:MSG:READ,0-0-3,s=2,c=1,t=3,pt=0,l=1,sg=0:0
    312962 TSF:MSG:ACK REQ
    312966 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=OK:0
    312976 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:0
    312986 TSF:MSG:READ,0-0-3,s=3,c=1,t=3,pt=0,l=1,sg=0:2
    312991 TSF:MSG:ACK REQ
    312994 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=OK:2
    Message for sensor: 3 Type : 3 newLevel : 2 requestedLevel : 2
    Changing level to 2, sensor 3, PIN 6
    313006 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:2
    449119 TSF:MSG:READ,0-0-3,s=1,c=1,t=3,pt=0,l=1,sg=0:0
    449123 TSF:MSG:ACK REQ
    449161 !TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=NACK:0
    449172 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=OK:0
    449182 TSF:MSG:READ,0-0-3,s=3,c=1,t=3,pt=0,l=2,sg=0:95
    449186 TSF:MSG:ACK REQ
    449190 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:95
    449202 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:95
    1011819 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    1011825 TSF:MSG:BC
    1011942 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
    Here is the sketch. The code is adapted from several projects I found on this site, but has been modified heavily without attribution (so far). Don't laugh or cringe too much. It is my first attempt at one of these:
    #define SN "Dimmable RGBW LED"
    #define SV "1.1"
    #define RED_PIN 3
    #define GREEN_PIN 5
    #define BLUE_PIN 6
    #define WHITE_PIN 0
    #define FADE_DELAY 10 // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    int RGB_pins[5] = {0, RED_PIN, GREEN_PIN, BLUE_PIN,WHITE_PIN};
    int CurrentValue[5] = {0,0,0,0,0};
    int r = 1;
    int g = 2;
    int b = 3;
    int w = 4;
    int i;
    int newLevel;
    char convBuffer[10];
    static int16_t currentLevel = 0; // Current dim level...
    MyMessage RedStatus(r, V_DIMMER);
    MyMessage GreenStatus(g, V_DIMMER);
    MyMessage BlueStatus(b, V_DIMMER);
    MyMessage WhiteStatus(w, V_DIMMER);
    Dimmable LED initialization method
    for(int i = 1; i < 4; i++)
    Serial.print( "Setting up: " );
    Serial.print(RGB_pins[i]);
    pinMode(RGB_pins[i], OUTPUT);
    analogWrite(RGB_pins[i], 0);
    Serial.print(255);
    delay( 1000 );
    analogWrite(RGB_pins[i], 255);
    Serial.println(0);
    // Pull the gateway's current dim level - restore light level upon sendor node power-up
    request( r, V_DIMMER );
    request( g, V_DIMMER );
    request( b, V_DIMMER );
    request( w, V_DIMMER );
    present( r, S_DIMMER );
    present( g, S_DIMMER );
    present( b, S_DIMMER );
    present( w, S_DIMMER );
    sendSketchInfo(SN, SV);
    Dimmable LED main processing loop
    if (message.type == V_LIGHT || message.type == V_DIMMER) {
    newLevel = atoi(message.getString(convBuffer));
    i = message.sensor;
    Serial.print( "Message for sensor: " );
    Serial.print( i );
    Serial.print( " Type : " );
    Serial.print( message.type );
    Serial.print( " newLevel : " );
    Serial.print( newLevel );
    Serial.print( " requestedLevel : " );
    Serial.println( requestedLevel );
    fadeToLevel (i, newLevel);
    This method provides a graceful fade up/down effect
    void fadeToLevel(int LED, int toLevel )
    // int delta = ( toLevel - CurrentValue[LED] ) < 0 ? -1 : 1;
    // while ( currentLevel != toLevel ) {
    // currentLevel += delta;
    // analogWrite( RGB_pins[LED], (int)(currentLevel / 100. * 255) );
    // delay( FADE_DELAY );
    if (LED != 4){
    analogWrite( RGB_pins[LED], (int)((100 -toLevel) / 100. * 255) );
    Serial.print( "Changing level to " );
    Serial.print( ", sensor " );
    Serial.print( LED );
    Serial.print( ", PIN " );
    Serial.println( RGB_pins[LED] );
    sendStatus(LED, toLevel);
    void sendStatus(int idx, int level) {
    switch (idx) {
    case 1:
    send(RedStatus.set(level), false);
    break;
    case 2:
    send(GreenStatus.set(level), false);
    break;
    case 3:
    send(BlueStatus.set(level), false);
    break;
    Thank you in advance for any time you spend on this.
    • C
      C
      CurtisMack
      I checked the logs on the Vera, and it looks like the command to change the color is being sent, but it is getting a NACK:96
      50 03/10/17 18:37:37.670 luup_log:3: Arduino: Log: TSF:MSG:SEND,0-0-3-3,s=1,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=OK:0 <0x2e8fd680>
      50 03/10/17 18:37:37.720 luup_log:3: Arduino: Log: !TSF:MSG:SEND,0-0-3-3,s=2,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=NACK:96 <0x2e8fd680>
      50 03/10/17 18:37:37.722 luup_log:3: Arduino: Log: TSF:MSG:SEND,0-0-3-3,s=3,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:94 <0x2e8fd680>
      Any sugestion on how to debug this further?
      • C
        C
        CurtisMack
        Does this look like a radio error, or something else? Could it just be message collisions? Is there a way to tell the system to attempt to resend a message on a NACK?
