  3. MLX90614 contactless temperature sensor
6 Posts 4 Posters 3.4k Views 5 Watching
  • U
    U
    user2684
    In case somebody can be interested (I've not seen any old posts talking about it), I've just tested this contactless temperature sensor from aliexpress (https://www.aliexpress.com/item/Free-Shipping-GY-906-MLX90614ESF-New-MLX90614-Contactless-Temperature-Sensor-Module-For-Arduino-Compatible/32465332978.html?spm=2114.13010608.0.0.gJhz6T) which is pretty cool.
    It reports BOTH the ambient temperature and the object temperature (the latter ranging from -70 to +380 C), has a standard i2c interface and works great with this library: https://github.com/adafruit/Adafruit-MLX90614-Library.
    The price is also pretty interesting, being around 3.5$.
    It can be used in many applications to e.g. measure the temperature of a body, the temperature of an oven, the temperature of a board, or whatever object could make sense in your project.
    YveauxY 1 Reply Last reply
    • U user2684
      YveauxY
      YveauxY
      @user2684 What's your experience on the measurement distance?
      Posts on the internet suggest it is only a few cm's without using a lense, which would make practical use very limited IMHO.
      • U
        U
        user2684
        It starts "sensing" e.g. the human body when around 50cm away but the real measurement happens only when less than 10 cm away. Agree this is not the best scenario but could be still probably useful for something line on-demand body temperature measurement or when the absolute value has a relative importance (e.g. when a significant variation has to be detected).
          A Former User
          Hi guys,
          I made a battery powered sensor with MLX90614 to check my furnace's temp. It needs Adafruit's MLX90614 library. I'm using RFM69 radios, so please make sure you chose the right one.
           * Version 1.0 - Henrik Ekblad
           * Pressure sensor example using BMP085 module
           * http://www.mysensors.org/build/pressure
          //#define MY_RADIO_NRF24
          #define MY_RADIO_RFM69
          #include <Wire.h>
          //MLX90614 library from Adafruit
          #include <Adafruit_MLX90614.h>
          Adafruit_MLX90614 mlx = Adafruit_MLX90614();
          #define MY_PARENT_NODE_ID 0
          #define TEMP_CHILD 0
          #define TEMP2_CHILD 1
          #define BAT_CHILD 2
          int oldBatteryPcnt = 0;
          // Sleep time between reads (in ms). Do not change this value as the forecast algorithm needs a sample every minute.
          const unsigned long SLEEP_TIME = 60000;
          float lastTemp=-1;
          float lastTemp2=-1;
          float lastBat=-1;
          boolean metric;
          MyMessage tempMsg(TEMP_CHILD, V_TEMP);
          MyMessage temp2Msg(TEMP2_CHILD, V_TEMP);
          MyMessage batMsg(BAT_CHILD, V_VOLTAGE);
          //  metric = getConfig().isMetric;
            mlx.begin();
           //       pinMode(5, OUTPUT);
              analogReference(INTERNAL1V1);
          #else
              analogReference(INTERNAL);
          void presentation()  {
            sendSketchInfo("MLX90614", "1.0");
            // Register sensors to gw (they will be created as child devices)
            present(TEMP_CHILD, S_TEMP);
            present(TEMP2_CHILD, S_TEMP);
            present(BAT_CHILD, S_MULTIMETER);
          // Loop
            Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempC());
            Serial.print("*C\tObject = "); Serial.print(mlx.readObjectTempC()); Serial.println("*C");
                int batteryPcnt = sensorValue / 10.23;
                float batteryV  = sensorValue * 0.003363075;
            #ifdef MY_DEBUG
              Serial.print(batteryV);
              Serial.println(" V");
              Serial.print(batteryPcnt);
              Serial.println(" %");
                  // Power up radio after sleep
                  oldBatteryPcnt = batteryPcnt;
              send(tempMsg.set(mlx.readAmbientTempC(), 2));
              lastTemp = mlx.readAmbientTempC();
              send(temp2Msg.set(mlx.readObjectTempC(), 2));
              lastTemp2 = mlx.readObjectTempC();
              send(batMsg.set(batteryV, 2));
              lastBat = batteryV;
            sleep(SLEEP_TIME);
          • U
            U
            user2684
            Hi, in case can be useful, this sensor is also available through NodeManager (https://github.com/mysensors/NodeManager) as SENSOR_MLX90614.
            • wallyllamaW
              wallyllamaW
              wallyllama
              Positioning would be critical, but these sensors always make me think of a sort of automated health diagnostic system. It checks your temperature and reports if you have a fever.
