  3. Node dont connect to RaspBerry gateway
28 Posts 4 Posters 7.8k Views 4 Watching
    The gateway is replying but node is not receiving. Where are you getting power for your nrf24 radio on the rpi? Are you using a capacitor ? size?
    keldandorinK 1 Reply Last reply
      keldandorinK
      keldandorinK
      keldandorin
      @gohan taking power from 3v3 pin number 1 an using capasitor that is 10uF
        Other users reported a similar problem and they solved by using something like this (that's the one I have on my rpi) or any other similar voltage regulator + capacitor
          keldandorinK
          keldandorinK
          keldandorin
          @gohan had it running now for a cuple of hours and sudenly it registerd. No luck efter reboot though. Guess I have to order one of them Voltage regulators/capacitors....realy wish I hade one now in my Man Cave :joy:
            I ordered them by mistake some time ago, but they turned out to be very useful 😂
            keldandorinK 2 Replies Last reply
              keldandorinK
              keldandorinK
              keldandorin
              @gohan had it running again for some time and at message1890739 It got connected again and seems to be able to send message to GW. But as you say its the GW sending part that dosent seems to work.
              1890739 TSM:FPAR:OK
              1890740 TSM:ID
              1890742 TSM:ID:OK
              1890744 TSM:UPL
              1890749 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              1892756 TSM:UPL
              1892761 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              1892768 TSF:MSG:READ,0-0-3,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              1892773 TSF:MSG:PONG RECV,HP=1
              1892776 TSM:UPL:OK
                keldandorinK
                keldandorinK
                keldandorin
                @gohan You think one of this could solv it to.
                http://www.ebay.com/itm/10pcs-LM350-LM350T-3A-Adjustable-Voltage-Regulator-TO-220-NS-/270934993534?hash=item3f14fbea7e:m:m1teKyPPDfS02DlKXI_oD1g
                Using 5v as output insted and regulat it down to 3.3 v and capasitator on that.
                Got them in local store :)
                  I suggested those modules because you can quickly swap the radio module, but that may work too. Pls post back your results
