  3. Node dont connect to RaspBerry gateway
28 Posts 4 Posters 7.8k Views 4 Watching
  • keldandorinK
    keldandorinK
    keldandorin
    OK got version 2.1.1 on place on Rpi deffined Node Id but still no luck connecting to Rpi GW :cry:
    GW Log
    mysgw: Starting gateway...
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:FPAR REQ,ID=255
    mysgw: TSF:PNG:SEND,TO=0
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:GWL OK
    mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK,FCTRL
    Node Log:
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:FPAR
    15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2022 !TSM:FPAR:NO REPLY
    2024 TSM:FPAR
    2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4034 !TSM:FPAR:NO REPLY
    4036 TSM:FPAR
    4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6046 !TSM:FPAR:NO REPLY
    6048 TSM:FPAR
    6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8058 !TSM:FPAR:FAIL
    8059 TSM:FAIL:CNT=1
    8061 TSM:FAIL:PDT
    Going to replace radio and try again.
      Double check node ID, I don't see it in node log
      keldandorinK 1 Reply Last reply
        keldandorinK
        keldandorinK
        keldandorin
        @gohan Changed radio on Rpi
        and node log looks like this now, Forgot MY_ before node :smile:
        3 TSM:INIT
        4 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        13 TSM:INIT:STATID=2
        18 TSF:SID:OK,ID=2
        19 TSM:FPAR
        55 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2063 !TSM:FPAR:NO REPLY
        2065 TSM:FPAR
        2101 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        4108 !TSM:FPAR:NO REPLY
        4110 TSM:FPAR
        4146 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        6153 !TSM:FPAR:NO REPLY
        6155 TSM:FPAR
        6191 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        8198 !TSM:FPAR:FAIL
        8199 TSM:FAIL:CNT=1
        8201 TSM:FAIL:PDT
        • keldandorinK keldandorin
          3 TSM:INIT
          4 TSF:WUR:MS=0
          11 TSM:INIT:TSP OK
          18 TSF:SID:OK,ID=2
          19 TSM:FPAR
          2065 TSM:FPAR
          4110 TSM:FPAR
          6155 TSM:FPAR
          8198 !TSM:FPAR:FAIL
          8199 TSM:FAIL:CNT=1
          8201 TSM:FAIL:PDT
          keldandorinK
          keldandorinK
          keldandorin
          @keldandorin Looks like I get som data to GW now but it dosent connect. Node has ID 3
          mysgw: TSF:MSG:BC
          mysgw: TSF:MSG:FPAR REQ,ID=3
          mysgw: !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
          mysgw: TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          mysgw: TSF:MSG:BC
            Do you have cap on the radio?
              keldandorinK
              keldandorinK
              keldandorin
              @gohan yes
                @gohan yes
                keldandorinK
                keldandorinK
                keldandorin
                @keldandorin If I pars log from GW it says
                Sent Message
                Sender: 0
                Last Node: 0
                Next Node: 3
                Destination: 3
                Sensor Id: 255
                Command: INTERNAL
                Message Type:I_FIND_PARENT_RESPONSE
                Payload Type: P_BYTE
                Payload Length: 1
                Signing: 0
                Failed uplink counter: 0
                Status: NACK (OK=success, NACK=no radio ACK received)
                Payload: 0
                Just like its acctualy responding to Node !
                But the node dosent like the awnser
                • keldandorinK
                  keldandorinK
                  keldandorin
                  Hi guys, realy need som help here. Got my Rpi gateway up and running and logfile looks ok, see below.
                  have a working Node running with DTH22. (know its working sins its conenct to my Arduino GW)
                  Tryed to onfigured Node Id on node. Connecting to my RpiGW with MYScontroller and can see the gateway but no nodes connect.
                  Log on PRI looks like this
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: MCO:BGN:STP
                  mysgw: TSF:MSG:BC
                  Log on Node like this
                  3 TSM:INIT
                  4 TSF:WUR:MS=0
                  11 TSM:INIT:TSP OK
                  13 TSM:INIT:STATID=3
                  14 TSF:SID:OK,ID=3
                  16 TSM:FPAR
                  52 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2059 !TSM:FPAR:NO REPLY
                  2061 TSM:FPAR
                  2097 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  4104 !TSM:FPAR:NO REPLY
                  4106 TSM:FPAR
                  4142 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  6149 !TSM:FPAR:NO REPLY
                  6151 TSM:FPAR
                  6187 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  8194 !TSM:FPAR:FAIL
                  8195 TSM:FAIL:CNT=1
                  8197 TSM:FAIL:PDT
                  From my basic understanding it looks like the GW dont responding in the correct way or the node dont like the awnser. Anyone with more experince out there that can give me some ideas how to fix this.
                  Thx
                  /Håkan
                    The gateway is replying but node is not receiving. Where are you getting power for your nrf24 radio on the rpi? Are you using a capacitor ? size?
                      keldandorinK
                      keldandorinK
                      keldandorin
                      @gohan taking power from 3v3 pin number 1 an using capasitor that is 10uF
                        Other users reported a similar problem and they solved by using something like this (that's the one I have on my rpi) or any other similar voltage regulator + capacitor
                          keldandorinK
                          keldandorinK
                          keldandorin
                          @gohan had it running now for a cuple of hours and sudenly it registerd. No luck efter reboot though. Guess I have to order one of them Voltage regulators/capacitors....realy wish I hade one now in my Man Cave :joy:
                            I ordered them by mistake some time ago, but they turned out to be very useful 😂
                            keldandorinK 2 Replies Last reply
                              keldandorinK
                              keldandorinK
                              keldandorin
                              @gohan had it running again for some time and at message1890739 It got connected again and seems to be able to send message to GW. But as you say its the GW sending part that dosent seems to work.
                              1890739 TSM:FPAR:OK
                              1890740 TSM:ID
                              1890742 TSM:ID:OK
                              1890744 TSM:UPL
                              1890749 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                              1892756 TSM:UPL
                              1892761 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                              1892768 TSF:MSG:READ,0-0-3,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                              1892773 TSF:MSG:PONG RECV,HP=1
                              1892776 TSM:UPL:OK
                                keldandorinK
                                keldandorinK
                                keldandorin
                                @gohan You think one of this could solv it to.
                                http://www.ebay.com/itm/10pcs-LM350-LM350T-3A-Adjustable-Voltage-Regulator-TO-220-NS-/270934993534?hash=item3f14fbea7e:m:m1teKyPPDfS02DlKXI_oD1g
                                Using 5v as output insted and regulat it down to 3.3 v and capasitator on that.
                                Got them in local store :)
                                  I suggested those modules because you can quickly swap the radio module, but that may work too. Pls post back your results
