  3. Node dont connect to RaspBerry gateway
28 Posts 4 Posters 7.8k Views 4 Watching
    Double check node ID, I don't see it in node log
    keldandorinK
    keldandorinK
    keldandorin
    @gohan Changed radio on Rpi
    and node log looks like this now, Forgot MY_ before node :smile:
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:STATID=2
    18 TSF:SID:OK,ID=2
    19 TSM:FPAR
    55 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2063 !TSM:FPAR:NO REPLY
    2065 TSM:FPAR
    2101 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4108 !TSM:FPAR:NO REPLY
    4110 TSM:FPAR
    4146 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6153 !TSM:FPAR:NO REPLY
    6155 TSM:FPAR
    6191 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8198 !TSM:FPAR:FAIL
    8199 TSM:FAIL:CNT=1
    8201 TSM:FAIL:PDT
    keldandorinK 1 Reply Last reply
    • keldandorinK keldandorin
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      18 TSF:SID:OK,ID=2
      19 TSM:FPAR
      2065 TSM:FPAR
      4110 TSM:FPAR
      6155 TSM:FPAR
      8198 !TSM:FPAR:FAIL
      8199 TSM:FAIL:CNT=1
      8201 TSM:FAIL:PDT
      keldandorinK
      keldandorinK
      keldandorin
      @keldandorin Looks like I get som data to GW now but it dosent connect. Node has ID 3
      mysgw: TSF:MSG:BC
      mysgw: TSF:MSG:FPAR REQ,ID=3
      mysgw: TSF:CKU:OK,FCTRL
      mysgw: TSF:MSG:GWL OK
      mysgw: !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      mysgw: TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      mysgw: TSF:MSG:BC
        Do you have cap on the radio?
          keldandorinK
          keldandorinK
          keldandorin
          @gohan yes
            @gohan yes
            keldandorinK
            keldandorinK
            keldandorin
            @keldandorin If I pars log from GW it says
            Sent Message
            Sender: 0
            Last Node: 0
            Next Node: 3
            Destination: 3
            Sensor Id: 255
            Command: INTERNAL
            Message Type:I_FIND_PARENT_RESPONSE
            Payload Type: P_BYTE
            Payload Length: 1
            Signing: 0
            Failed uplink counter: 0
            Status: NACK (OK=success, NACK=no radio ACK received)
            Payload: 0
            Just like its acctualy responding to Node !
            But the node dosent like the awnser
            • keldandorinK
              keldandorinK
              keldandorin
              Hi guys, realy need som help here. Got my Rpi gateway up and running and logfile looks ok, see below.
              have a working Node running with DTH22. (know its working sins its conenct to my Arduino GW)
              Tryed to onfigured Node Id on node. Connecting to my RpiGW with MYScontroller and can see the gateway but no nodes connect.
              Log on PRI looks like this
              mysgw: Starting gateway...
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: TSM:INIT:TSP OK
              mysgw: TSM:INIT:GW MODE
              mysgw: MCO:REG:NOT NEEDED
              mysgw: MCO:BGN:STP
              mysgw: MCO:BGN:INIT OK,TSP=1
              mysgw: TSF:MSG:BC
              Log on Node like this
              3 TSM:INIT
              4 TSF:WUR:MS=0
              11 TSM:INIT:TSP OK
              13 TSM:INIT:STATID=3
              14 TSF:SID:OK,ID=3
              16 TSM:FPAR
              52 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2059 !TSM:FPAR:NO REPLY
              2061 TSM:FPAR
              2097 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              4104 !TSM:FPAR:NO REPLY
              4106 TSM:FPAR
              4142 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              6149 !TSM:FPAR:NO REPLY
              6151 TSM:FPAR
              6187 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              8194 !TSM:FPAR:FAIL
              8195 TSM:FAIL:CNT=1
              8197 TSM:FAIL:PDT
              From my basic understanding it looks like the GW dont responding in the correct way or the node dont like the awnser. Anyone with more experince out there that can give me some ideas how to fix this.
              Thx
              /Håkan
                The gateway is replying but node is not receiving. Where are you getting power for your nrf24 radio on the rpi? Are you using a capacitor ? size?
                  keldandorinK
                  keldandorinK
                  keldandorin
                  @gohan taking power from 3v3 pin number 1 an using capasitor that is 10uF
                    Other users reported a similar problem and they solved by using something like this (that's the one I have on my rpi) or any other similar voltage regulator + capacitor
                      keldandorinK
                      keldandorinK
                      keldandorin
                      @gohan had it running now for a cuple of hours and sudenly it registerd. No luck efter reboot though. Guess I have to order one of them Voltage regulators/capacitors....realy wish I hade one now in my Man Cave :joy:
                        I ordered them by mistake some time ago, but they turned out to be very useful 😂
                        keldandorinK 2 Replies Last reply
                          keldandorinK
                          keldandorinK
                          keldandorin
                          @gohan had it running again for some time and at message1890739 It got connected again and seems to be able to send message to GW. But as you say its the GW sending part that dosent seems to work.
                          1890739 TSM:FPAR:OK
                          1890740 TSM:ID
                          1890742 TSM:ID:OK
                          1890744 TSM:UPL
                          1890749 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                          1892756 TSM:UPL
                          1892761 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                          1892768 TSF:MSG:READ,0-0-3,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          1892773 TSF:MSG:PONG RECV,HP=1
                          1892776 TSM:UPL:OK
                            keldandorinK
                            keldandorinK
                            keldandorin
                            @gohan You think one of this could solv it to.
                            http://www.ebay.com/itm/10pcs-LM350-LM350T-3A-Adjustable-Voltage-Regulator-TO-220-NS-/270934993534?hash=item3f14fbea7e:m:m1teKyPPDfS02DlKXI_oD1g
                            Using 5v as output insted and regulat it down to 3.3 v and capasitator on that.
                            Got them in local store :)
                              I suggested those modules because you can quickly swap the radio module, but that may work too. Pls post back your results
