  3. 💬 NodeManager
💬 NodeManager
contest2017arduinonewbiemysensorsbattery sensor
196 Posts 42 Posters 113.5k Views 41 Watching
  • Sergio RiusS Sergio Rius
    @user2684 Mmmmm what if you have a motion sensor in the same node? (I'm trying to migrate my own sketch)
    U
    U
    user2684
    @Sergio-Rius yes, you can have a motion sensor on the same node as far as it is a sleeping node. This is because the interrupt is coming from the MySensors sleep() call. Having this compatibility in a non sleeping node is instead only planned (https://github.com/mysensors/NodeManager/issues/142)
    • S
      strangeoptics
      Hi, I would like to have smartSleep for my nodes. I read that NodeManager can do that. But I couldn't find an explanation how it is doing it. I use OpenHAB as the controller and MQTT to communicate to the MySensors-Gateway. Is smartSleep working for this scenario? Did you extend the Gateway?
      U 1 Reply Last reply
      • S strangeoptics
        U
        U
        user2684
        @strangeoptics NodeManager does use smart sleep by default. The way it works (with or without node manager) is pretty simple: when the node tells the gw/controller is about to go to sleep, it actually wait (by default 500ms I think) for new messages before powering off the radio and going to sleep. Useful if you have a sleeping node and want to communicate with it. Im not familiar with those controllers but I'm sure others are but generally speaking the way it works is the controller usually queue your messages and when the node checks in release the queue.
        S 1 Reply Last reply
        • U user2684
          strangeoptics
          @user2684 If I understand it correct, NodeManager is basically using the smartSleep method of the MySensors library and extended it with a default delay of 500ms after the heart beat message.
          The logic for queuing the messages inbetween the wakeup periods is not implementet from NodeManager and has to come from the controller. In my case OpenHAB hasn't got the logic and smartSleep wouldn't work :(
          • S strangeoptics
            U
            U
            user2684
            @strangeoptics not really, node manager is not extending smart sleep at all, smart sleep from the core MySensors library by itself is implemented with this delay :)
            • U user2684
              strangeoptics
              @user2684 so which controler are you using?
              • S strangeoptics
                U
                U
                user2684
                https://www.mysensors.org/controller/myhouse but since I wrote it, my opinion would be biased :P
                • stefaanvS
                  stefaanvS
                  stefaanv
                  The configuration service is a good ideaal.
                  Even better would be if it would allow setting and reading user parameters.
                  • mar.conteM
                    mar.conteM
                    mar.conte
                    Hi
                    I have a led ir emitter can i send to my air contiotioner a code like x0284828 by digital output in nodemanager(with irremote library is simple)
                    M.C.
                    • mar.conteM mar.conte
                      Hi
                      U
                      U
                      user2684
                      @mar.conte mmm not sure I got the use case. I think we need some sort of "IR" specific output. Btw if you prefer, feel free to open a new thread on https://forum.mysensors.org/category/43/nodemanager
                      • D Dencan
                        Hi, nice work!
                        I have changed the code for REBOOT so there is no need for a reboot-pin.
                        like this...
                        else if (strcmp(message, "REBOOT") == 0) {
                        #if DEBUG == 1
                        Serial.println(F("REBOOT"));
                        // Software reboot with watchdog timer
                        // Enter Watchdog Configuration mode:
                        WDTCSR |= (1<<WDCE) | (1<<WDE);
                        // Reset enable
                        WDTCSR= (1<<WDE);
                        // Infinite loop until watchdog reset after 16 ms
                        while(true){}
                        U
                        U
                        user2684
                        Hi @Dencan @core_c I'm having trouble with both the solutions you recommended. When the reboot code is triggered, I have my pro mini 3.3v board freezing with the power led blinking continuously (https://github.com/mysensors/NodeManager/issues/133). Do you guys know what the issue could be? Thanks!
                        D 1 Reply Last reply
                        • U user2684
                          D
                          D
                          Dencan
                          @user2684 It appears that this problem is caused by a bug in bootloaders used in some Arduino boards.
                          The solution suggested is to flash optiboot bootloader to the Arduino Pro Mini. Or not using a bootloader.
                          I use mostly barebone atmega328's with optiboot bootloader, working perfectly with reboot function, so I haven't been aware of the problem until now when I used a pro mini.
                          Please read this article which explains the cause of the problem and suggested fix.
                          https://andreasrohner.at/posts/Electronics/How-to-make-the-Watchdog-Timer-work-on-an-Arduino-Pro-Mini-by-replacing-the-bootloader/
                          I will try it on a pro mini when I have time.
                          • D Dencan
                            U
                            U
                            user2684
                            @Dencan thanks, very good information. Based on what you are saying, I'd probably re-introduce the reboot pin as a backup solution just in case somebody doesn't want or can move away from the default bootloader. In this way both the approaches will be available. Thanks!
                            • ronnyandreR
                              ronnyandreR
                              ronnyandre
                              I have a hard time figuring out one simple thing... Is the NodeManager code supposed to be on the sensors? Or is it supposed to be on the Gateway? Or both??
                              Newbie with RPi and Domoticz, trying to automate my home.
                              Sergio RiusS 1 Reply Last reply
                              • ronnyandreR ronnyandre
                                Sergio RiusS
                                Sergio RiusS
                                Sergio Rius
                                @ronnyandre With NodeManager you can build sensors but also configure a gateway. :+1:
                                ronnyandreR 1 Reply Last reply
                                  ronnyandreR
                                  ronnyandreR
                                  ronnyandre
                                  @Sergio-Rius I think I understood it correctly. Code goes on the sensors, not on the gateway itself? That means, the MySensors Serial Gateway I use is only a carrier of the messages that NodeManager receives on the sensors I implement the code?
                                  • U user2684
                                    @Ivan-Z if you mean an example with DHT22, you need first of all to enable the DHT module in config.h with:
                                    #define MODULE_DHT 1
                                    Then just register the sensor in before() with:
                                    nodeManager.registerSensor(SENSOR_DHT22,6);
                                    Where 6 is the pin where the sensor is attached to. NodeManager will then create automatically two child ids, one for temperature and the other for humidity.
                                    As written in the documentation you need the DHT library from https://github.com/adafruit/DHT-sensor-library (or install it by using the arduino IDE). For some unknown (to me) reasons I had issues in using the library from the mysensors example.
                                    What do you mean by optimization flag?
                                    As for avoid sending the same value, this is already available, have a look at setTackLastValue() from the documentation. When set to true, the value will not be send if the same as the previous (default is of course false). I also implemented setForceUpdate(), to force to send an update after the configured number of cycles, as many examples here are using this approach.
                                    D
                                    D
                                    dakipro
                                    @user2684 Hi, i am trying to get started with NodeManager, and I have a question about dht configuration?
                                    I would like to set it to not update values if temperature is not changed, something like ((SensorLatchingRelay*)nodeManager.getSensor(1))->setTackLastValue(true);
                                    But how do I select both sensors, are they numbers 1 and 2 (both temp and humidity)?
                                    I would also like to add these settings to them.
                                    ((SensorLatchingRelay*)nodeManager.getSensor(1))->setForceUpdate(4);
                                    ((SensorLatchingRelay*)nodeManager.getSensor(1))->setFloatPrecision(1);
                                    Thanks!
                                    Sergio RiusS U 2 Replies Last reply
                                      Sergio RiusS
                                      Sergio RiusS
                                      Sergio Rius
                                      @ronnyandre NodeManager is a code wrapper. It's a collection of libraries, that has been join with a configuration script that automatically picks and does what is needed for your like.
                                      You can make a common temperature sensor, but if you look at the documentation and the NodeManager.h code or the ino template itself, you have options for gateway configuration.
                                      So you should be able to configure a gateway sketch and burn into your hardware.
                                      I hope this gives some light before the dinner ;)
                                      ronnyandreR U 2 Replies Last reply
                                      • D dakipro
                                        Thanks!
                                        Sergio RiusS
                                        Sergio RiusS
                                        Sergio Rius
                                        wrote on last edited by Sergio Rius
                                        #79
                                        @dakipro said in 💬 NodeManager:
                                        SensorLatchingRelay is wrong here.
                                        Try:
                                          int sensorDHT_Id = nodeManager.registerSensor(SENSOR_DHT22, PIN_DHT);
                                          SensorDHT* sensorDHT = (SensorDHT*)nodeManager.getSensor(sensorDHT_Id);
                                          sensorDHT->setSamples(5);
                                          sensorDHT->setSamplesInterval(2001);
                                          sensorDHT->setTackLastValue(true);
                                          sensorDHT->setForceUpdate(3);
                                        Those options refer to the whole device, should be applied also to humidity. There was a bug on this but I think it was already corrected. If not, try with development version.
                                        • D
                                          D
                                          dakipro
                                          Thanks, right after posting the question, I have found a example on the topic itself (search function on the forum does not search current topic anymore, I had to scroll down to be able to "find in page").
                                          I am now using this
                                          int sensorDHT_Id = nodeManager.registerSensor(SENSOR_DHT22,4);
                                          Will see how it goes :)
