  3. Combining DHT and Binary sensor update issue
4 Posts 2 Posters 1.7k Views 2 Watching
  • BrydenB
    BrydenB
    Bryden
    Having an issue trying to figure how to get instant response from the binary inputs (reed switch) whilst also having a DHT in the mix.
    The issue is that the binary change only gets sent when the temp or humidity is sent.
    Running the code with out the DHT in there work flawlessly. and state changes are sent immediately
    I assume is has to do with the Wait function in the loop, but with out that wait you poll the DHT too much and it wont read any data.
    Set up is NodeMCU as MQTT gateway. running 2.0
    #include <ESP8266WiFi.h>
    #include <Bounce2.h>
    #include <DHT.h>
    // DHT22
    #define DHT_DATA_PIN 12
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 4
    #define CHILD_ID_TEMP 5
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    // Setting multiple child ID's for each switch and it's GPIO pin
    //Switch 1
    #define CHILD_ID_1 1
    #define BUTTON_PIN_1  4  // Arduino Digital I/O pin for button/reed switch
    //Switch 2
    #define CHILD_ID_2 2
    #define BUTTON_PIN_2  5  // Arduino Digital I/O pin for button/reed switch
    //Switch 3
    #define CHILD_ID_3 3
    #define BUTTON_PIN_3  10  // Arduino Digital I/O pin for button/reed switch
    //Switch 1
    Bounce debouncer_1 = Bounce();
    int oldValue_1=-1;
    //Switch 2
    Bounce debouncer_2 = Bounce();
    int oldValue_2=-1;
    //Switch 3
    Bounce debouncer_3 = Bounce();
    int oldValue_3=-1;
    // Setting mysensor message string (ChildID, V type)
    MyMessage msg1(CHILD_ID_1,V_TRIPPED);
    MyMessage msg2(CHILD_ID_2,V_TRIPPED);
    MyMessage msg3(CHILD_ID_3,V_TRIPPED);
    DHT dht;
    //Presenting each child ID
    void presentation() {
      //Switch
      present(CHILD_ID_1, S_DOOR);
      present(CHILD_ID_2, S_DOOR);
      present(CHILD_ID_3, S_DOOR);
      //DHT
      present(CHILD_ID_HUM, S_HUM);
    //Setting up each GPIO pin as an input and turning on internal pull up resistor
      // Setup button 1
      pinMode(BUTTON_PIN_1,INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN_1,HIGH);
      debouncer_1.attach(BUTTON_PIN_1);
      debouncer_1.interval(5);
      // Setup button 2
      pinMode(BUTTON_PIN_2,INPUT);
      digitalWrite(BUTTON_PIN_2,HIGH);
      debouncer_2.attach(BUTTON_PIN_2);
      debouncer_2.interval(5);
      // Setup button 3
      pinMode(BUTTON_PIN_3,INPUT);
      digitalWrite(BUTTON_PIN_3,HIGH);
      debouncer_3.attach(BUTTON_PIN_3);
      debouncer_3.interval(5);
      //DHT
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      // Switch 1
      debouncer_1.update();
      // Get the update value
      int value_1 = debouncer_1.read();
      if (value_1 != oldValue_1) {
         // Send in the new value
         send(msg1.set(value_1==HIGH ? 1 : 0));
         oldValue_1 = value_1;
      // Switch 2
      debouncer_2.update();
      int value_2 = debouncer_2.read();
      if (value_2 != oldValue_2) {
         send(msg2.set(value_2==HIGH ? 1 : 0));
         oldValue_2 = value_2;
      // Switch 3
      debouncer_3.update();
      int value_3 = debouncer_3.read();
      if (value_3 != oldValue_3) {
         send(msg3.set(value_3==HIGH ? 1 : 0));
         oldValue_3 = value_3;
      wait(UPDATE_INTERVAL);
    rejoe2R 1 Reply Last reply
    • BrydenB Bryden
      #include <DHT.h>
      // DHT22
      float lastTemp;
      float lastHum;
      bool metric = true;
      //Switch 1
      //Switch 2
      //Switch 3
      //Switch 1
      int oldValue_1=-1;
      //Switch 2
      int oldValue_2=-1;
      //Switch 3
      int oldValue_3=-1;
      DHT dht;
        //Switch
        //DHT
        // Setup button 1
        // Setup button 2
        // Setup button 3
        //DHT
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
        // Switch 1
        // Switch 2
        // Switch 3
      rejoe2R
      rejoe2R
      rejoe2
      wrote on last edited by gohan
      @Bryden You will either have to use some interrupt functionality (wich is pretty hard to code when using other than just pins 2 and/or 3.
      Easier to understand is not to make the loop() wait and instead only reading the DHT-Values when a certain time has passed. See eg. the Servo example (also for the necessary preparation):
      if (attachedServo && millis() - timeOfLastChange > DETACH_DELAY) {
          myservo.detach();
          attachedServo = false;
      • BrydenB
        BrydenB
        Bryden
        Thought it might be a little harder than my pay grade.
        might implement it a little later
        • BrydenB Bryden
          rejoe2R
          rejoe2R
          rejoe2
          @Bryden It's not rocket science, just inserting an additional variable and putting the dht measuring part in some if (){}-functionality.
          You may try...
          #include <DHT.h>
          // DHT22
          float lastTemp;
          float lastHum;
          //this is needed to store some time info = last time we got DHT values in millis
          uint16_t lastDHTTime = 0;
          bool metric = true;
          //Switch 1
          //Switch 2
          //Switch 3
          //Switch 1
          int oldValue_1=-1;
          //Switch 2
          int oldValue_2=-1;
          //Switch 3
          int oldValue_3=-1;
          DHT dht;
            //Switch
            //DHT
            // Setup button 1
            // Setup button 2
            // Setup button 3
            //DHT
            if (millis() - lastDHTTime > UPDATE_INTERVAL) {
              lastDHTTime=millis();
          		if (!metric) {
          		nNoUpdatesTemp = 0;
          		#ifdef MY_DEBUG
          	} else {
          		nNoUpdatesTemp++;
          		lastHum = humidity;
          		nNoUpdatesHum = 0;
          		#ifdef MY_DEBUG
          	} else {
          		nNoUpdatesHum++;
            // Switch 1
            // Switch 2
            // Switch 3
            //wait(UPDATE_INTERVAL); //replaced by if (millis() ...)
