  3. OpenHAB
  4. Serial Gateway connection to Openhab
development ope
86 Posts 16 Posters 93.0k Views 10 Watching
  • J
    J
    jemish
    Hay, can any one try that.........feedback from switchboard
    • T
      TimO
      I would try to use something like this on the sensor connected to the switchboard:
      http://www.mysensors.org/build/binary
      This will send V_TRIPPED per default.
      In the rules files you have to bring everything togehter:
      if V_TRIPPED from sensor_id_xyz received
      then update status of light switch
      If you know what I mean. :-D
      • A
        A
        almj
        This post is deleted!
        • L l154
          Hi all,
          I wrote some rules for serial gateway to openhab, temp, hum, switch, dimmer and some internal commands are working without a problem. I don't have too much time to develop this for other devices.
          I'm not a java programmer so if I made some mistakes feel free to comment.
          The goal is to write a rules that will be easily expanded to other devices.
          I create a has map table where I define mappings ID to item name and inversely.
          test.rules file:
          import org.openhab.core.library.types.*
          import org.openhab.core.persistence.*
          import org.openhab.model.script.actions.*
          import java.util.*
          import org.eclipse.xtext.xbase.lib.*
          import org.openhab.core.items.*
          var String ArduinoUpdate = ""
          var String sketchName = ""
          var int V_TEMP = 0
          var int V_HUM = 1
          var int V_LIGHT = 2
          var int V_DIMMER = 3
          var int V_PRESSURE = 4
          var int V_FORECAST = 5
          var int V_RAIN = 6
          var int V_RAINRATE = 7
          var int V_WIND = 8
          var int V_GUST = 9
          var int V_DIRECTION = 10
          var int V_UV = 11
          var int V_WEIGHT = 12
          var int V_DISTANCE = 13
          var int V_IMPEDANCE = 14
          var int V_ARMED = 15
          var int V_TRIPPED = 16
          var int V_WATT = 17
          var int V_KWH = 18
          var int V_SCENE_ON = 19
          var int V_SCENE_OFF = 20
          var int V_HEATER = 21
          var int V_HEATER_SW = 22
          var int V_LIGHT_LEVEL = 23
          var int V_VAR1 = 24
          var int V_VAR2 = 25
          var int V_VAR3 = 26
          var int V_VAR4 = 27
          var int V_VAR5 = 28
          var int V_UP = 29
          var int V_DOWN = 30
          var int V_STOP = 31
          var int V_IR_SEND = 32
          var int V_IR_RECEIVE = 33
          var int V_FLOW = 34
          var int V_VOLUME = 35
          var int V_LOCK_STATUS = 36
          var int V_DUST_LEVEL = 37
          var int V_VOLTAGE = 38
          var int V_CURRENT = 39
          var int msgPresentation = 0
          var int msgSet = 1
          var int msgReq = 2
          var int msgInternal = 3
          var int msgStream = 4
          var int alarmArmor = 1
          // Internal Commands
          var int I_BATTERY_LEVEL = 0
          var int I_TIME = 1
          var int I_VERSION = 2
          var int I_ID_REQUEST = 3
          var int I_ID_RESPONSE = 4
          var int I_INCLUSION_MODE = 5
          var int I_CONFIG = 6
          var int I_FIND_PARENT = 7
          var int I_FIND_PARENT_RESPONSE = 8
          var int I_LOG_MESSAGE = 9
          var int I_CHILDREN = 10
          var int I_SKETCH_NAME = 11
          var int I_SKETCH_VERSION = 12
          var int I_REBOOT = 13
          var int I_GATEWAY_READY = 14
          // Mappings
          var HashMap<String, String> sensorToItemsMap = newLinkedHashMap(
          	"21;1;" -> "tempSalon01",
          	"tempSalon01" -> "21;1;",
          	"21;0;" -> "humSalon01",
          	"humSalon01" -> "21;0;",
          	"22;0;" -> "plugStrip01s12",
          	"plugStrip01s12" -> "22;0;",
          	"22;1;" -> "plugStrip01s34",
          	"plugStrip01s34" -> "22;1;",
          	"20;0;" -> "lightSalonCeiling00",
          	"lightSalonCeiling00" -> "20;0;",
          	"20;1;" -> "lightSalonCeiling01",
          	"lightSalonCeiling01" -> "20;1;",
          	"20;2;" -> "lightSalonCeiling02",
          	"lightSalonCeiling02" -> "20;2;",
          	"20;3;" -> "lightSalonCeiling03",
          	"lightSalonCeiling03" -> "20;3;",
          	"20;4;" -> "lightSalonCeiling04",
          	"lightSalonCeiling04" -> "20;4;",
          	"10;4;" -> "lightBar04",
          	"lightBar04" -> "10;4;",
          	"10;0;" -> "lightKitchenCabinet00",
          	"lightKitchenCabinet00" -> "10;0;",
          	"10;1;" -> "lightKitchenCabinet01",
          	"lightKitchenCabinet01" -> "10;1;",
          	"10;2;" -> "lightKitchenCabinet02",
          	"lightKitchenCabinet02" -> "10;2;",
          	"10;3;" -> "lightKitchenCabinet03",
          	"lightKitchenCabinet03" -> "10;3;",
          	"20;255;" -> "sensorLRCDimmer",
          	"21;255;" -> "sensorLRHumTemp",
          	"22;255;" -> "sensorLRStripPlug01",
          	"10;255;" -> "sensorKCLight"
          // dimmer function
          val org.eclipse.xtext.xbase.lib.Functions$Function5 dimmerOperation = [
          	org.openhab.core.library.items.DimmerItem relayItem,
          	org.openhab.core.library.items.StringItem arduinoItem,
          	String arduinoDevMap,
          	String receivedCommand,
          	Integer subType|
          	var Number percent = 0
          	if(relayItem.state instanceof DecimalType) percent = relayItem.state as DecimalType
          	if(receivedCommand==INCREASE) percent = percent + 5
          	if(receivedCommand==DECREASE) percent = percent - 5
          	if(receivedCommand==ON) percent = 100
          	if(receivedCommand==OFF) percent = 0
          	if(percent<0)   percent = 0
          	if(percent>100) percent = 100
          	println ("Function: dimmerOperation >> "+arduinoDevMap + "1;1;" + subType + ";" + percent )
          	arduinoItem.sendCommand(arduinoDevMap + "1;0;" + subType + ";" + percent + "\n")
          //switch function
          val org.eclipse.xtext.xbase.lib.Functions$Function4 switchOperation = [
          	org.openhab.core.library.items.SwitchItem relayItem,
          	Integer subType|
          	var Integer state = 0
                  if (relayItem.state == OFF) {
          		state = 0
          	else {
          		state = 1
          	println ("Function: switchOperation >> "+arduinoDevMap + "1;1;" + subType + ";" + state )
          	arduinoItem.sendCommand(arduinoDevMap + "1;0;" + subType + ";" + state + "\n")
          //receiving msg from mysensors gateway
          rule "Arduino sends to Openhab"
          	when
          		Item Arduino received update
          	then
          		var String lineBuffer =  Arduino.state.toString.split("\n")
          		for (String line : lineBuffer) {
          			var String[] message = line.split(";")
          			var Integer nodeId = new Integer(message.get(0))
          			var Integer childId = new Integer(message.get(1))
          			var Integer msgType = new Integer(message.get(2))
          			var Integer ack = new Integer(message.get(3))
          			var Integer subType = new Integer(message.get(4))
          			var String msg = message.get(5)
          			if(msgType == 1 ){
          				if (subType == V_TEMP){
          					postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), msg)
          					println ("Temp item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " temp: " + msg )
          				if (subType == V_HUM){
          					println ("HUM item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " hum: " + msg )
          				if (subType == V_DIMMER){
          					println ("Dimmer item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " Dimmer: " + msg )
          				if (subType == V_LIGHT){
          					var String state
          					var Integer statusInt = new Integer(message.get(5))
          					if(statusInt == 1) {
          						state = "ON"
          					else {
          						state = "OFF"
          					postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), state)
          					println ("Light Item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " Light: " + state )
          			// Internal Command
          			if(msgType == 3){
          				if(subType == I_SKETCH_NAME){
          						println("Sketch name: " + msg )
          						sketchName=msg
          				if(subType == I_SKETCH_VERSION){
          						println("Sketch version: " + msg )
          						postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), sketchName+" " +msg )
          						sketchName=""
          end
          rule "lightBar04 Switch Rule"
          	when
          		Item lightBar04 changed
          	then
          		switchOperation.apply(lightBar04, Arduino, sensorToItemsMap.get("lightBar04"), V_LIGHT)
          end
          rule "lightKitchenCabinet00 Switch Rule"
          	when
          		Item lightKitchenCabinet00 changed
          	then
          		switchOperation.apply(lightKitchenCabinet00, Arduino, sensorToItemsMap.get("lightKitchenCabinet00"), V_LIGHT)
          end
          rule "lightKitchenCabinet01 Switch Rule"
          	when
          		Item lightKitchenCabinet01 changed
          	then
          		switchOperation.apply(lightKitchenCabinet01, Arduino, sensorToItemsMap.get("lightKitchenCabinet01"), V_LIGHT)
          end
          rule "lightKitchenCabinet02 Switch Rule"
          	when
          		Item lightKitchenCabinet02 changed
          	then
          		switchOperation.apply(lightKitchenCabinet02, Arduino, sensorToItemsMap.get("lightKitchenCabinet02"), V_LIGHT)
          end
          rule "lightKitchenCabinet03 Switch Rule"
          	when
          		Item lightKitchenCabinet03 changed
          	then
          		switchOperation.apply(lightKitchenCabinet03, Arduino, sensorToItemsMap.get("lightKitchenCabinet03"), V_LIGHT)
          end
          rule "lightSalonCeiling00 Switch Rule"
          	when
          		Item lightSalonCeiling00 received command
          	then
          		if(lightSalonCeiling00.state instanceof DecimalType || receivedCommand==INCREASE || receivedCommand==DECREASE){
          		dimmerOperation.apply(lightSalonCeiling00, Arduino, sensorToItemsMap.get("lightSalonCeiling00"), receivedCommand, V_DIMMER)
          	end
          rule "lightSalonCeiling01 Switch Rule"
          	when
          		Item lightSalonCeiling01 received command
          	then
          		if(lightSalonCeiling01.state instanceof DecimalType || receivedCommand==INCREASE || receivedCommand==DECREASE){
          		dimmerOperation.apply(lightSalonCeiling01, Arduino, sensorToItemsMap.get("lightSalonCeiling01"), receivedCommand, V_DIMMER)
          	end
          rule "lightSalonCeiling02 Switch Rule"
          	when
          		Item lightSalonCeiling02 received command
          	then
          		if(lightSalonCeiling02.state instanceof DecimalType || receivedCommand==INCREASE || receivedCommand==DECREASE){
          		dimmerOperation.apply(lightSalonCeiling02, Arduino, sensorToItemsMap.get("lightSalonCeiling02"), receivedCommand, V_DIMMER)
          	end
          rule "lightSalonCeiling03 Switch Rule"
          	when
          		Item lightSalonCeiling03 received command
          	then
          		if(lightSalonCeiling03.state instanceof DecimalType || receivedCommand==INCREASE || receivedCommand==DECREASE){
          		dimmerOperation.apply(lightSalonCeiling03, Arduino, sensorToItemsMap.get("lightSalonCeiling03"), receivedCommand, V_DIMMER)
          	end
          rule "lightSalonCeiling04 Switch Rule"
          	when
          		Item lightSalonCeiling04 received command
          	then
          		if(lightSalonCeiling04.state instanceof DecimalType || receivedCommand==INCREASE || receivedCommand==DECREASE){
          		dimmerOperation.apply(lightSalonCeiling04, Arduino, sensorToItemsMap.get("lightSalonCeiling04"), receivedCommand, V_DIMMER)
          	end
          rule "plugStrip01s12 Switch Rule"
          	when
          		Item plugStrip01s12 changed
          	then
          		switchOperation.apply(plugStrip01s12, Arduino, sensorToItemsMap.get("plugStrip01s12"), V_LIGHT)
          end
          rule "plugStrip01s34 Switch Rule"
          	when
          		Item plugStrip01s34 changed
          	then
          		switchOperation.apply(plugStrip01s34, Arduino, sensorToItemsMap.get("plugStrip01s34"), V_LIGHT)
          end
          my test.item
          String Arduino "Arduino" { serial="/dev/ttyUSB0@115200" }
          Group All
          Group flat "Flat" <house>
          Group livingRoom "Living Room"  <sofa>  (All,flat)
          Group kitchen      "Kitchen" <kitchen>  (All,flat)
          Group corridor      "Corridor" <corridor>  (All,flat)
          Group bathroom      "Bathroom" <bath>  (All,flat)
          Group gmRoom  "Grandma Room" <smile>  (All,flat)
          Group weather   (All)
          Group status    (All)
          Group mysensors    (All)
          Group:Switch:OR(ON, OFF) kLights "Lights" <light> (All, kitchen)
          Group:Switch:OR(ON, OFF) kcLights "Cabinet Lights [(%d)]" <light> (All, kLights)
          Group:Switch:OR(ON, OFF) skcLights "Single Cabinet Lights [(%d)]" <light> (All)
          Group:Switch:OR(ON, OFF) lrLights "Lights" <light> (livingRoom)
          Group:Switch:OR(ON, OFF) lrcLights "Ceiling Lights [(%d)]" <light> (lrLights)
          Group:Switch:OR(ON, OFF) lrSockets "Sockets" <socket> (livingRoom)
          Group:Switch:OR(ON, OFF) lrPlugStrip "Sockets [(%d)]" <socket> (lrSockets)
          Group:Number:AVG humAndTemp "Avg. Room Humidity[%.1f %%] and Temperature [%.1f °C]" <temperature>
          Group:Number:AVG temperature "Avg. Room Temperature [%.1f °C]" <temperature> (status)
          Group:Number:AVG humidity "Avg. Room Humidity [%.1f %%]" <temperature> (status)
          Group:Switch:OR(ON, OFF) lights "All Lights [(%d)]" <light> (All)
          Number tempChartPeriod          "Chart Period"
          Number tempSalon01 "Temperature [%s °C]" <temperature> (temperature,humAndTemp)
          Number humSalon01 "Humidity [%s %%]" <temperature> (humidity,humAndTemp)
          Switch lightKitchenCabinet00	"Light 1" (lights, kcLights)
          Switch lightKitchenCabinet01	"Light 2" (lights, kcLights)
          Switch lightKitchenCabinet02	"Light 3" (lights, kcLights)
          Switch lightKitchenCabinet03	"Light 4" (lights, kcLights)
          Switch lightBar04		"Bar Lights" (lights, kLights, lrLights)
          Dimmer lightSalonCeiling00	"Light 1 [%s %%]" (lights, lrcLights)
          Dimmer lightSalonCeiling01	"Light 2 [%s %%]" (lights, lrcLights)
          Dimmer lightSalonCeiling02	"Light 3 [%s %%]" (lights, lrcLights)
          Dimmer lightSalonCeiling03	"Light 4 [%s %%]" (lights, lrcLights)
          Dimmer lightSalonCeiling04	"Light All [%s %%]" (lights,lrLights,allLights)
          Switch plugStrip01s12		"Sockets 1-2" <socket> (lrPlugStrip)
          Switch plugStrip01s34		"Sockets 3-4" <socket> (lrPlugStrip)
          String sensorLRCDimmer "Living Room Ceiling Light Sensor [%s]" (mysensors)
          String sensorLRStripPlug01 "Living Room Strip Plug 01 Sensor [%s]" (mysensors)
          String sensorLRHumTemp "Living Room Hum&Temp&Motion&Light  Sensor [%s]" (mysensors)
          String sensorKCLight "Kitchen&Bar Light Sensor [%s]" (mysensors)
          my test.sitemap
          sitemap demo label="Main Menu"
          	Frame label="Home" {
          		Group label="Kitchen" icon="kitchen" {
          			Frame label="Kitchen" {
          				Group item=kLights label="Lights" {
          				Switch item=lightBar04 label="Bar Lights"
          				Switch item=kcLights label="Cabinet Lights"
          				Group item=kcLights
          		Group item=livingRoom {
          			Frame label="Living Room" {
          				Group item=lrLights
          				Group label="Sensors" icon="temperature" {
          					Text item=tempSalon01 valuecolor=[tempSalon01=="Uninitialized"="lightgray",tempSalon01>90="lightgray",>25="orange",>15="green",>5="orange",<=5="blue"]
          					Text item=humSalon01 valuecolor=[humSalon01=="Uninitialized"="lightgray",tempSalon01>90="lightgray",>25="orange",>15="green",>5="orange",<=5="blue"]
          					Switch item=tempChartPeriod label="Chart Period" mappings=[0="12 Hours", 1="Day", 2="Week", 3="Month"]
          					Chart item=humAndTemp period=12h refresh=5000 visibility=[tempChartPeriod==0,tempChartPeriod=="Uninitialized"]
          					Chart item=humAndTemp period=D refresh=1800 visibility=[tempChartPeriod==1]
          					Chart item=humAndTemp period=W refresh=3600 visibility=[tempChartPeriod==2]
          					Chart item=humAndTemp period=M refresh=7200 visibility=[tempChartPeriod==3]
          				Group item=lrPlugStrip
          		Group item=corridor
          		Group item=bathroom icon="bath"
          		Group item=grandmotherRoom icon="smiley"
          	Frame label="Lights All"{
          		Switch item=lights mappings=[OFF="All Off"]
          		Group item=lights
          		Group item=mysensors
          E
          E
          ewgor
          @l154 said:
          Hi all,
          test.rules file:
          import java.util.*
          var int V_TEMP = 0
          var int V_HUM = 1
          var int V_LIGHT = 2
          var int V_RAIN = 6
          var int V_WIND = 8
          var int V_GUST = 9
          var int V_UV = 11
          var int V_WATT = 17
          var int V_KWH = 18
          var int V_VAR1 = 24
          var int V_VAR2 = 25
          var int V_VAR3 = 26
          var int V_VAR4 = 27
          var int V_VAR5 = 28
          var int V_UP = 29
          var int V_DOWN = 30
          var int V_STOP = 31
          var int V_FLOW = 34
          var int msgSet = 1
          var int msgReq = 2
          var int I_TIME = 1
          // Mappings
          // dimmer function
          	Integer subType|
          //switch function
          	Integer subType|
          		state = 0
          	else {
          		state = 1
          	when
          	then
          			if(msgType == 1 ){
          					var String state
          						state = "ON"
          					else {
          						state = "OFF"
          			// Internal Command
          			if(msgType == 3){
          						sketchName=msg
          						sketchName=""
          end
          	when
          	then
          end
          	when
          	then
          end
          	when
          	then
          end
          	when
          	then
          end
          	when
          	then
          end
          	when
          	then
          	end
          	when
          	then
          	end
          	when
          	then
          	end
          	when
          	then
          	end
          	when
          	then
          	end
          	when
          	then
          end
          	when
          	then
          end
          my test.item
          Group All
          Group weather   (All)
          Group status    (All)
          my test.sitemap
          				Group item=kcLights
          				Group item=lrLights
          		Group item=corridor
          		Group item=lights
          hi all,
          does anyone have an arduino code for l154 nice work here above?
          i need an example only for arduino (dont have a rpi) on which i can connect a few relays and a few sensors like dht11 and a light sensor.
          Someone please a little help here with a arduino code or some links on where we can find something to work with this openhab configuration?
          thanks in advance.
          • E
            E
            ewgor
            one more question:
            to make the connection with openhab should i change this "String Arduino "Arduino" { serial="/dev/ttyUSB0@115200" }" to "String Arduino "Arduino" { serial="COM4" }" couse my arduino is connecting on com4?
            thanks!
            • T
              TimO
              Use something like:
              String Arduino "Arduino" { serial="COM4@115200" }
              E 1 Reply Last reply
              • T TimO
                Use something like:
                E
                E
                ewgor
                @TimO said:
                Use something like:
                thank you for answer TimO, i assume this 115200 is the baud rate, isn't it? on testing different arduino codes, i had to modify it to 9600 because otherwise it wouldn't work...
                can you please share with us any arduino code for a few relays and some sensors? or to suggest us some links where we can find something useful?
                i need an example only for an arduino (mega) connected directly through usb to my laptop.
                thanks again, i will try this "String Arduino "Arduino" { serial="COM4@115200" }" when i'll have an arduino code as an example.
                • T
                  TimO
                  Yes, you're right, 115000 is the baudrate.
                  Have you seen my tutorial?
                  http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway
                  • E
                    E
                    ewgor
                    wrote on last edited by ewgor
                    #49
                    I saw your tutorial but in there you speak about tests made on a system with Linux like a rpi and I'm working only for tests from my laptop with windows 7 and arduino mega! Later when I will have something working I'll purchase a rpi for a permanent installation but for the moment I need just the arduino code to match with this openhab configuration.
                    Any idea?
                    Thanks again.
                    • T
                      TimO
                      I'm using the standard serial gateway: http://www.mysensors.org/build/serial_gateway
                      (For the mega you have to change CE/CSN Pin, just search the forum)
                      The OpenHAB part of my tutorial will work on Windows 7 too, there's no difference in the OpenHAB configuration except the COM4 port you already mentioned.
                      The arduino code you're searching is the MySensors standard stuff, there is no need to change that to make it work with OpenHAB.
                      • T TimO
                        E
                        E
                        ewgor
                        @TimO i am trying to make this serial communication work following your tutorial. i don understand why it has to be so difficult for some of us who have small ideas about arduino i mean is not like today a bought it and i don't know a thing about it!
                        cause was not working with my existing openhab i deleted all and i followed your link here https://openhab.ci.cloudbees.com/job/openHAB/ and i got this"distribution-1.7.0-SNAPSHOT-addons.zip" and this "distribution-1.7.0-SNAPSHOT-runtime.zip".
                        now, do i need all addons or a few of them? if i need a few, which one? its not clear ...
                        regarding arduino, i got all libraries from here http://www.mysensors.org/download/ and extrated into the libraries folder of arduino.
                        when i compile the example sketch SerialGateway, it is compiling and i even can upload it but, starting the server with start.bat or start.sh and having the com4 modified and all items, rules and map according to your instruction, it doesnt work, i get this error "Error opening serial port 'COM4'.
                        i dont know what to do! and i don't understand how to see the temp and humid. real values when you have uploaded a standard serial gateway and you don't have any commands in the arduino code about dht or other type of sensor! is this code only for test? just to see that you have the communication working and on the web it will appear just some values?
                        its becoming really frustrating trying days and nights to make it work,, reading a lot of comments where other guys made it and you don't!
                        can u please help? where i'm wrong? i'm using this time an arduino uno but this doesn't matter, i changet the string with baudrate115200, 9600, without it and nothing! i cant make the serial communication work!
                        • T TimO
                          @CARSTEN I've compiled a modified version of the OpenHab Serial binding with a baud rate of 115200 as this is standard in mysensors.
                          Download: org.openhab.binding.serial_1.6.0.201411271703.jar
                          As @tboha suggested you currently have to manage all commands by yourself.
                          I've attached my modified serial binding here. Please be aware, that all other configurations that depend on serial binding won't work with the modified version, because of the changed baud rate.
                          I'm currently testing with this Serial Gateway:
                          Serial Gateway
                          Here is my OpenHab configuration for simple testing:
                          demo.items: demo.items
                          demo.rules: demo.rules
                          demo.sitemap: demo.sitemap
                          E
                          E
                          ewgor
                          @TimO hi here too,
                          cant test this version because i get this error regarding DHT:
                          Arduino: 1.5.8 (Windows 7), Board: "Arduino Uno"
                          RelayActuator.ino:21:5: error: no matching function for call to 'DHT::DHT()'
                          RelayActuator.ino:21:5: note: candidates are:
                          In file included from RelayActuator.ino:6:0:
                          D:\Kit\Arduino\libraries\DHT/DHT.h:40:4: note: DHT::DHT(uint8_t, uint8_t, uint8_t)
                          DHT(uint8_t pin, uint8_t type, uint8_t count=6);
                          D:\Kit\Arduino\libraries\DHT/DHT.h:40:4: note: candidate expects 3 arguments, 0 provided
                          D:\Kit\Arduino\libraries\DHT/DHT.h:38:7: note: DHT::DHT(const DHT&)
                          class DHT {
                          D:\Kit\Arduino\libraries\DHT/DHT.h:38:7: note: candidate expects 1 argument, 0 provided
                          RelayActuator.ino: In function 'void setup()':
                          RelayActuator.ino:48:7: error: 'class DHT' has no member named 'setup'
                          RelayActuator.ino: In function 'void updateHumidityTemp()':
                          RelayActuator.ino:72:26: error: 'class DHT' has no member named 'getHumidity'
                          RelayActuator.ino:84:27: error: 'class DHT' has no member named 'getTemperature'
                          RelayActuator.ino:90:25: error: 'class DHT' has no member named 'toFahrenheit'
                          Error compiling.
                          enabled in File > Preferences.
                          i have downloaded all needed libraries from here http://www.mysensors.org/download/ but cant compile!
                          do i need ther DHT library?
                          thanks!
                          • T
                            TimO
                            @ewgor Hi!
                            Using OpenHAB (1.X) with MySensors is a long and at the beginning frustrating process as OpenHAB itself don't support MySensors out of the box. I hope I'm able to change that with OpenHAB 2.0.
                            1. OpenHAB 1.7.0 is stable. You don't have to use the snapshot release. But that won't solve your problems.
                            2. You just need the serial binding from the addons. Copy "org.openhab.binding.serial-1.7.0-SNAPSHOT.jar" to "OPENHAB-HOME/addons". But I suppose you already did that, because of the error "Error opening serial port 'COM4'.
                            3. https://github.com/openhab/openhab/wiki/Serial-Binding according to this "COM4@115200" should work fine. I've not tested it with windows yes. This is your main problem. Don't try to go further, nothing will work. Are you able to open the serial monitor in the Arduino Development Environment? With the correct baudrate you should see something like "Gateway startup complete".
                            4. You're Arduino Development Environment can't find the libraries. I've extracted all libraries to "C:\Users\myUser\Documents\Arduino\libraries". It now looks like:
                            Adafruit_BMP085
                            BH1750
                            Bounce2
                            DHT
                            MySensors
                            The DHT library is part of the file you downloaded.
                            • T TimO
                              @ewgor Hi!
                              Adafruit_BMP085
                              BH1750
                              Bounce2
                              DHT
                              MySensors
                              E
                              E
                              ewgor
                              @TimO thanks for reply,
                              1. first shot was with Openhab 1.7.0 from here http://www.openhab.org/downloads.html and than i followed your link from here https://openhab.ci.cloudbees.com/job/openHAB/ and tried with the SNAPSHOT 1.8.0 version, both of them works and i can test different examples from here with my laptop and 2 smartphones.
                              2. every time i try a server, i have 2 folders with as follows: 1 folder is the original addons folder wich is empty and another one as a copy like addons1 in which i extracted all addons. Before starting the server i copy the needed addon (.jar file) in the original folder named addons, in my case the serial.jar.
                              3. if the server is not started i can compile the SerialGateway code and i can upload it too into my arduino. The problem si that when i open the serial monitor of arduino IDE i get some strange chars like: \Ú or LÊ or Lœ and this is happening every time i open the serial monitor. I think is a baudrate problem but i cant see where in the SerialGateway sketch i can change this baudrate or should i change it directly in the library? By the way, can you please tell me, why its not working with different baudrates?
                              4. i have all libraries from here http://www.mysensors.org/download/ copied and pasted directly in my arduino libraries folder which in my case is in D/kit/arduino/libraries. For DHT i have DHT library / DHT tester! Do i need other library? i Know i tested a sketch for DHT11 and an LCD and it worked.
                              However, if i have the server started on my laptop its impossible to compile the SerialGateway sketch and i receive this error posted above. I even can't upload the sketch if i close the server, i need to restart my PC....
                              Maybe it would be a beeter sollution to use Mqtt because i have a wiznet w5100 and a ENC28J60 ethernet module but the problem is (i asked somewhere here on the forum) that i cannot use or test Mosquitto broker, and so i cannot test a Mqtt connection. I downloaded the broker from the original page for my system, i have it installed on windows but i cannot access any of the .exe files because of some missing dll. After days of searching and a lot of struggling i got the dll's but didn't start because of some unexpected error! I know this is the subject of another topic but i didn't get a reply there so i ask here...
                              If i cannot test a server on my machine how to purchase a RPI and moreover i never had a RPI so you can imagine how many problems i will face. Anyhow, this is my intention, to buy a RPI and to have a permanent installation.
                              Don't know what to do .... :(((
                              • T
                                TimO
                                Ok, I think we're getting closer.
                                So, If you see strange chars in the serial monitor the baud rate of the serial monitor isn't right. Just change the baud rate in the serial monitor, it's a dropdown at the bottom right. If you set it to 115200 baud it should work (Gateway startup complete).
                                The 115.200 is a fixed baud rate MySensors uses. It is faster than 9600 and the serial communication could be the bottleneck. In the MySensors library it is defined in MySensors.h. You may change that, but that won't help.
                                I suppose you have a blocking issue, since both Arduino IDE and OpenHAB try to use the COM port. Try to make sure only one application at a time is running and using the port. At least OpenHAB should throw an error that the COM port is blocked. I'm not sure how Windows handles blocking.
                                If you see "Gateway startup complete" in the Arduino IDE / serial monitor, close the Arduino IDE (and the serial monitor) and fire up OpenHAB with debugging enabled (start_debug.bat). Post everything the serial binding throws out here.
                                Can't help you with MQTT because I haven't used it yet.
                                • E
                                  E
                                  ewgor
                                  I changed the baud rate to 115200 and now it says "0;0;3;0;9;check wires" on both Arduino (Uno and Mega). I think i saw a topic here somewhere, do i need to change some pins in the SerialGateway sketch?
                                  • T
                                    TimO
                                    Check the connections between NRF24L01+ and Arduino Uno.
                                    In case of the Arduino Mega you have to change the sketch (CE/CSN Pin), just search the forum for an example.
                                    • E
                                      E
                                      ewgor
                                      I dont have any NRF24L01 in myhouse! what is this device? do i have to buy one to see this SerialGateway working between my PC and my Arduino board?
                                      For my Mega ive searched on the the forum but i dont understand how to change the CE/CSN pin ...
                                      I asked on some other topic but no answer.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @ewgor
                                        Have you read this page ?
                                        and this one.
                                        NRF24L01 is the essentially the heart of the mysensors system, it's the radio which it's build uppon.
                                        • tbowmoT tbowmo
                                          @ewgor
                                          and this one.
                                          E
                                          E
                                          ewgor
                                          @tbowmo yes i did, only is just i didnt understand that the NRF24L01 is a must! I already ordered a piece and in a few days i'll be able to test either the Serial Gateway or the Ethernet Gateway....
