  3. OpenHAB
  4. Serial Gateway connection to Openhab
development ope
86 Posts 16 Posters 93.0k Views 10 Watching
  • T TimO
    Ok, I think we're getting closer.
    So, If you see strange chars in the serial monitor the baud rate of the serial monitor isn't right. Just change the baud rate in the serial monitor, it's a dropdown at the bottom right. If you set it to 115200 baud it should work (Gateway startup complete).
    The 115.200 is a fixed baud rate MySensors uses. It is faster than 9600 and the serial communication could be the bottleneck. In the MySensors library it is defined in MySensors.h. You may change that, but that won't help.
    I suppose you have a blocking issue, since both Arduino IDE and OpenHAB try to use the COM port. Try to make sure only one application at a time is running and using the port. At least OpenHAB should throw an error that the COM port is blocked. I'm not sure how Windows handles blocking.
    If you see "Gateway startup complete" in the Arduino IDE / serial monitor, close the Arduino IDE (and the serial monitor) and fire up OpenHAB with debugging enabled (start_debug.bat). Post everything the serial binding throws out here.
    Can't help you with MQTT because I haven't used it yet.
    E
    E
    ewgor
    wrote on last edited by ewgor
    #61
    This post is deleted!
    • E
      E
      ewgor
      #62
      i solved the problem with DHT, now i need to know how to configure Openhab in order to see the the gateway. I changed the COM in items already.
      In order to test your sketch that one with DHT and 2 realys what should i do? do i need 2 arduinos: one as a gateway and 2nd as a node point? how many nRF modules do i need?
      Now i have nRF24L01 but i dont know how to make it work with OpenHAB
      In addons i have org.openhab.binding.serial-1.7.0.jar
      Any help please?
      Thanks.
      • E
        E
        ewgor
        #63
        Anyone, any idea how to test the serial gateway? At this point on the serial monitor i get 0;0;3;0;14;Gateway startup complete. How to test it with Openhab? PLS HELP :)
        For gateway im using a UNO and i try to have my mega as a node point. If i use Arduino Mega as a gateway its ok, i couldnt find any connection scheme for the node point (mega or uno). Right now i see on the serial monitor of the node point check wires and on the gateway startup complete! Where is the problem? how to connect the node point with my relays and what should i see on the serial monitor? Again somebody pls help me understand how to test it with Openhab?
        • T
          TimO
          For the Arduino Mega you have to change the connections. Check out this thread:
          http://forum.mysensors.org/topic/249/arduino-mega-sensor-shield-2
          When the "node point" starts up fine you should see a lot of messages coming on the serial monitor of the gateway. Then the communication between both nodes is working.
          E 1 Reply Last reply
          • T TimO
            E
            E
            ewgor
            @TimO with your help again i managed to find the right pins on my mega and now with my dht11 connected i get the temp and hum values constantly. On the server side when i start the bat file or sh file i get the values on the node serial monitor but nothing apears on the localhost.
            there are any changes that needs to be done in the items, rules or the sitemap?
            thanks for replay.
            • E
              E
              ewgor
              #66
              today, trying to make it work i discovered that if i start the Openhab server i get the DHT11 values on the server and i can access the serial monitor of the node point but when i switch the arduino IDE to the serial gateway com4 i get this errors on the arduino IDE and i cannot acces the serial monitor:
              Arduino: 1.5.8 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
              processing.app.SerialException: Error opening serial port 'COM4'.
              	at processing.app.Serial.<init>(Serial.java:145)
              	at processing.app.Serial.<init>(Serial.java:90)
              	at processing.app.SerialMonitor.open(SerialMonitor.java:93)
              	at processing.app.Editor.handleSerial(Editor.java:2537)
              	at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:357)
              	at java.awt.Component.processMouseEvent(Unknown Source)
              	at javax.swing.JComponent.processMouseEvent(Unknown Source)
              	at java.awt.Component.processEvent(Unknown Source)
              	at java.awt.Container.processEvent(Unknown Source)
              	at java.awt.Component.dispatchEventImpl(Unknown Source)
              	at java.awt.Container.dispatchEventImpl(Unknown Source)
              	at java.awt.Component.dispatchEvent(Unknown Source)
              	at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
              	at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
              	at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
              	at java.awt.Window.dispatchEventImpl(Unknown Source)
              	at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
              	at java.awt.EventQueue.access$200(Unknown Source)
              	at java.awt.EventQueue$3.run(Unknown Source)
              	at java.security.AccessController.doPrivileged(Native Method)
              	at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
              	at java.awt.EventQueue$4.run(Unknown Source)
              	at java.awt.EventQueue.dispatchEvent(Unknown Source)
              	at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
              	at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
              	at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
              	at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
              	at java.awt.EventDispatchThread.run(Unknown Source)
              Caused by: jssc.SerialPortException: Port name - COM4; Method name - openPort(); Exception type - Port busy.
              	at jssc.SerialPort.openPort(SerialPort.java:164)
              	at processing.app.Serial.<init>(Serial.java:141)
              	... 35 more
                enabled in File > Preferences.
              On the serial monitor of the node point i receive this:
              repeater started, id 101
              send: 101-101-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
              send: 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
              send: 101-101-0-0 s=255,c=3,t=11,pt=0,l=5,st=ok:Relay
              send: 101-101-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
              send: 101-101-0-0 s=1,c=0,t=3,pt=0,l=0,st=fail:
              send: 101-101-0-0 s=2,c=0,t=3,pt=0,l=0,st=ok:
              send: 101-101-0-0 s=0,c=0,t=7,pt=0,l=0,st=ok:
              send: 101-101-0-0 s=1,c=0,t=6,pt=0,l=0,st=ok:
              Failed reading humidity from DHT
              Failed reading temperature from DHT
              send: 101-101-0-0 s=1,c=1,t=0,pt=7,l=5,st=ok:31.0
              T: 31.00
              send: 101-101-0-0 s=1,c=1,t=0,pt=7,l=5,st=fail:30.0
              T: 30.00
              T: 31.00
              and on the Openhab start.bat i see this:
              2015-07-15 17:48:14.153 [INFO ] [runtime.busevents             ] - Arduino state
               updated to 0;0;3;0;9;read: 101-101-0 s=255,c=3,t=11,pt=0,l=5:Relay
              101;255;3;0;11;Relay
              0;0;3;0;9;read: 101-101-0 s=255,c=3,t=12,pt=0,l=3:1.0
              101;255;3;0;12;1.0
              0;0;3;0;9;read: 101-101-0 s=1,c=0,t=3,pt=0,l=0:
              101;1;0;0;3;
              0;0;3;0;9;read: 101-101-0 s=2,c=0,t=3,pt=0,l=0:
              101;2;0;0;3;
              0;0;3;0;9;read: 101-101-0 s=0,c=0,t=7,pt=0,l=0:
              101;0;0;0;7;
              0;0;3;0;9;read: 101-101-0 s=1,c=0,t=6,pt=0,l=0:
              101;1;0;0;6;
              ArduinoUpdate -> 0;0;3;0;9;read: 101-101-0 s=255,c=3,t=11,pt=0,l=5:Relay
              101;255;3;0;12;1.0
              101;1;0;0;3;
              101;2;0;0;3;
              101;0;0;0;7;
              101;1;0;0;6;
              2015-07-15 17:48:15.171 [INFO ] [runtime.busevents             ] - Arduino state
               updated to 0;0;3;0;9;read: 101-101-0 s=1,c=1,t=0,pt=7,l=5:31.0
              101;1;1;0;0;31.0
              ArduinoUpdate -> 0;0;3;0;9;read: 101-101-0 s=1,c=1,t=0,pt=7,l=5:31.0
              101;1;1;0;0;31.0
              2015-07-15 17:48:44.203 [INFO ] [runtime.busevents             ] - Arduino state
               updated to 0;0;3;0;9;read: 101-101-0 s=0,c=1,t=1,pt=7,l=5:35.0
              101;0;1;0;1;35.0
              ArduinoUpdate -> 0;0;3;0;9;read: 101-101-0 s=0,c=1,t=1,pt=7,l=5:35.0
              101;0;1;0;1;35.0
              help :)
              • T
                TimO
                The access to the serial port is exclusive, stop OpenHAB to access the serial port of The gateway with the arduino IDE.
                • T TimO
                  E
                  E
                  ewgor
                  @TimO i saw that I can access the gateway and see what node point transmit but as you say without having the server start.
                  How do I see temp and hum on the local host? And what do I need to do to switch the two LEDs from local host?
                  As always, thanks for sharing a little part of your experience :)
                  • T
                    TimO
                    Use something like this in the rules file:
                    For a button (always sends on when activated):
                    rule "Licht Flur EG"
                            when
                                    Item corridorLight01 received update
                            then
                                    sendCommand(Arduino, "102;1;1;0;2;1\n")
                    For a switch use something like
                    rule "Küche"
                            when
                                    Item kitchenLight01 received command
                            then
                                    if(receivedCommand==ON) {
                                    if(receivedCommand==OFF) {
                                            sendCommand(Arduino, "102;1;1;0;2;0\n")
                    end
                    • E
                      E
                      ewgor
                      So TimO you say your example above (arduinos sketches for the serial gateway and the 2nd one for temp, hum and two switches + openhab items, rules and sitemap) is not working? i just followed and nothing happen ... still strugling. Now you give me this example which has nothing to do with your example. If i want to use it i need to modify all files and i dont know how!
                      Can anyone help me??
                      • T
                        TimO
                        Well, I thought your base is my tutorial: http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway
                        The advantage of OpenHAB is, you're very free and are able to do things you like to do. The disadvantage is, you currently have to "program" your rules.
                        It would help to know your OpenHAB configurations, sketches and so on, because I'm using my own OpenHAB (and MySensors) configuration/installation, that certainly is not the best configuration für everyone.
                        (But it works the way I want it to work ;-))
                        You only asked for (and got) pieces of the puzzle, you have to put it together by yourself or ask for the complete solution, as you did in another thread. :D
                        • T TimO
                          E
                          E
                          ewgor
                          @TimO
                          I see, so if are not a programmer and you don't know how to make your own sketches (arduino, rules) you don't have any chance to make your own project .... i thought, being open source and asking for help in a community where you can find a lot of guys who have idea about the subject, maybe you can make it easier without spending hours and hours just to come back to the same place you started , moreover without a solution.
                          Anyhow, thanks a lot, with the help you gave i am almost there but i think i still need to wait maybe a half year till i'll see my project on :(
                          • E
                            E
                            ewgor
                            Can anyone help? I'm trying to move my server from my laptop to my raspberry pi 2 and I'm having problems.
                            I changed the port in the items file with
                            "String Arduino "Arduino" { serial="/dev/ttyUSB0@115200" }"
                            And now the server receive the commands from my laptop or from my phone but it not sends the info to the node point and it not receive info from the node point too.
                            If I start the server from my laptop with start.bat it works but when I start the server from my pi with
                            Sudo /opt/openhab/start.sh it acts as I said above!
                            Can anyone please help me understand what I'm missing?
                            Thanks!
                            • T
                              TimO
                              Try to connect with a terminal software like miniterm to /dev/ttyUSB0 and check if data from the serial gateway is received.
                              miniterm.py -b 115200 -p /dev/ttyUSB0
                              You may have to install miniterm first.
                              • T TimO
                                E
                                E
                                ewgor
                                @TimO i solved following your tutorial here with dmesg and checking for what usb name rpi have for the gateway. Still not did those steps for a permanent usb but its on going.
                                Thanks!
                                • T TimO
                                  @CARSTEN I've compiled a modified version of the OpenHab Serial binding with a baud rate of 115200 as this is standard in mysensors.
                                  Download: org.openhab.binding.serial_1.6.0.201411271703.jar
                                  As @tboha suggested you currently have to manage all commands by yourself.
                                  I've attached my modified serial binding here. Please be aware, that all other configurations that depend on serial binding won't work with the modified version, because of the changed baud rate.
                                  I'm currently testing with this Serial Gateway:
                                  Serial Gateway
                                  Here is my OpenHab configuration for simple testing:
                                  demo.items: demo.items
                                  demo.rules: demo.rules
                                  demo.sitemap: demo.sitemap
                                  F
                                  F
                                  Fay Candiliari
                                  wrote on last edited by Fay Candiliari
                                  #76
                                  @TimO Hi TimO! This is Fay from codebender.cc Thank you for using codebender! I just wanted to let you know that one of the sketches you are using in this comment has been deleted and so it is not available for users to view it. Let me know if you have any question. :)
                                  hekH 1 Reply Last reply
                                  • T
                                    TimO
                                    @Fay-Candiliari : Thank you very much for the hint!
                                    F 1 Reply Last reply
                                    • F Fay Candiliari
                                      wrote on last edited by hek
                                      #78
                                      @Fay-Candiliari
                                      Hi @Fay-Candiliari , Nice to see you here!
                                      • T TimO
                                        F
                                        F
                                        Fay Candiliari
                                        @TimO You are welcome :)
                                          @Fay-Candiliari
                                          F
                                          F
                                          Fay Candiliari
                                          Hi @hek Likewise! :)
