  3. OpenHAB
  4. Serial Gateway connection to Openhab
development ope
86 Posts 16 Posters 94.1k Views 10 Watching
  • T
    TimO
    @ewgor said:
    String Arduino "Arduino" { serial="/dev/ttyUSB0@115200" }
    Use something like:
    String Arduino "Arduino" { serial="COM4@115200" }
    E 1 Reply Last reply
    • T TimO
      Use something like:
      E
      E
      ewgor
      @TimO said:
      Use something like:
      thank you for answer TimO, i assume this 115200 is the baud rate, isn't it? on testing different arduino codes, i had to modify it to 9600 because otherwise it wouldn't work...
      can you please share with us any arduino code for a few relays and some sensors? or to suggest us some links where we can find something useful?
      i need an example only for an arduino (mega) connected directly through usb to my laptop.
      thanks again, i will try this "String Arduino "Arduino" { serial="COM4@115200" }" when i'll have an arduino code as an example.
      • T
        TimO
        Yes, you're right, 115000 is the baudrate.
        Have you seen my tutorial?
        http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway
        • E
          E
          ewgor
          wrote on last edited by ewgor
          #49
          I saw your tutorial but in there you speak about tests made on a system with Linux like a rpi and I'm working only for tests from my laptop with windows 7 and arduino mega! Later when I will have something working I'll purchase a rpi for a permanent installation but for the moment I need just the arduino code to match with this openhab configuration.
          Any idea?
          Thanks again.
          • T
            TimO
            I'm using the standard serial gateway: http://www.mysensors.org/build/serial_gateway
            (For the mega you have to change CE/CSN Pin, just search the forum)
            The OpenHAB part of my tutorial will work on Windows 7 too, there's no difference in the OpenHAB configuration except the COM4 port you already mentioned.
            The arduino code you're searching is the MySensors standard stuff, there is no need to change that to make it work with OpenHAB.
            • T TimO
              E
              E
              ewgor
              @TimO i am trying to make this serial communication work following your tutorial. i don understand why it has to be so difficult for some of us who have small ideas about arduino i mean is not like today a bought it and i don't know a thing about it!
              cause was not working with my existing openhab i deleted all and i followed your link here https://openhab.ci.cloudbees.com/job/openHAB/ and i got this"distribution-1.7.0-SNAPSHOT-addons.zip" and this "distribution-1.7.0-SNAPSHOT-runtime.zip".
              now, do i need all addons or a few of them? if i need a few, which one? its not clear ...
              regarding arduino, i got all libraries from here http://www.mysensors.org/download/ and extrated into the libraries folder of arduino.
              when i compile the example sketch SerialGateway, it is compiling and i even can upload it but, starting the server with start.bat or start.sh and having the com4 modified and all items, rules and map according to your instruction, it doesnt work, i get this error "Error opening serial port 'COM4'.
              i dont know what to do! and i don't understand how to see the temp and humid. real values when you have uploaded a standard serial gateway and you don't have any commands in the arduino code about dht or other type of sensor! is this code only for test? just to see that you have the communication working and on the web it will appear just some values?
              its becoming really frustrating trying days and nights to make it work,, reading a lot of comments where other guys made it and you don't!
              can u please help? where i'm wrong? i'm using this time an arduino uno but this doesn't matter, i changet the string with baudrate115200, 9600, without it and nothing! i cant make the serial communication work!
              • T TimO
                @CARSTEN I've compiled a modified version of the OpenHab Serial binding with a baud rate of 115200 as this is standard in mysensors.
                Download: org.openhab.binding.serial_1.6.0.201411271703.jar
                As @tboha suggested you currently have to manage all commands by yourself.
                I've attached my modified serial binding here. Please be aware, that all other configurations that depend on serial binding won't work with the modified version, because of the changed baud rate.
                I'm currently testing with this Serial Gateway:
                Serial Gateway
                Here is my OpenHab configuration for simple testing:
                demo.items: demo.items
                demo.rules: demo.rules
                demo.sitemap: demo.sitemap
                E
                E
                ewgor
                @TimO hi here too,
                cant test this version because i get this error regarding DHT:
                Arduino: 1.5.8 (Windows 7), Board: "Arduino Uno"
                RelayActuator.ino:21:5: error: no matching function for call to 'DHT::DHT()'
                RelayActuator.ino:21:5: note: candidates are:
                In file included from RelayActuator.ino:6:0:
                D:\Kit\Arduino\libraries\DHT/DHT.h:40:4: note: DHT::DHT(uint8_t, uint8_t, uint8_t)
                DHT(uint8_t pin, uint8_t type, uint8_t count=6);
                D:\Kit\Arduino\libraries\DHT/DHT.h:40:4: note: candidate expects 3 arguments, 0 provided
                D:\Kit\Arduino\libraries\DHT/DHT.h:38:7: note: DHT::DHT(const DHT&)
                class DHT {
                D:\Kit\Arduino\libraries\DHT/DHT.h:38:7: note: candidate expects 1 argument, 0 provided
                RelayActuator.ino: In function 'void setup()':
                RelayActuator.ino:48:7: error: 'class DHT' has no member named 'setup'
                RelayActuator.ino: In function 'void updateHumidityTemp()':
                RelayActuator.ino:72:26: error: 'class DHT' has no member named 'getHumidity'
                RelayActuator.ino:84:27: error: 'class DHT' has no member named 'getTemperature'
                RelayActuator.ino:90:25: error: 'class DHT' has no member named 'toFahrenheit'
                Error compiling.
                i have downloaded all needed libraries from here http://www.mysensors.org/download/ but cant compile!
                do i need ther DHT library?
                thanks!
                • T
                  TimO
                  @ewgor Hi!
                  Using OpenHAB (1.X) with MySensors is a long and at the beginning frustrating process as OpenHAB itself don't support MySensors out of the box. I hope I'm able to change that with OpenHAB 2.0.
                  1. OpenHAB 1.7.0 is stable. You don't have to use the snapshot release. But that won't solve your problems.
                  2. You just need the serial binding from the addons. Copy "org.openhab.binding.serial-1.7.0-SNAPSHOT.jar" to "OPENHAB-HOME/addons". But I suppose you already did that, because of the error "Error opening serial port 'COM4'.
                  3. https://github.com/openhab/openhab/wiki/Serial-Binding according to this "COM4@115200" should work fine. I've not tested it with windows yes. This is your main problem. Don't try to go further, nothing will work. Are you able to open the serial monitor in the Arduino Development Environment? With the correct baudrate you should see something like "Gateway startup complete".
                  4. You're Arduino Development Environment can't find the libraries. I've extracted all libraries to "C:\Users\myUser\Documents\Arduino\libraries". It now looks like:
                  Adafruit_BMP085
                  BH1750
                  Bounce2
                  DHT
                  MySensors
                  The DHT library is part of the file you downloaded.
                  • T TimO
                    @ewgor Hi!
                    Adafruit_BMP085
                    BH1750
                    Bounce2
                    DHT
                    MySensors
                    E
                    E
                    ewgor
                    @TimO thanks for reply,
                    1. first shot was with Openhab 1.7.0 from here http://www.openhab.org/downloads.html and than i followed your link from here https://openhab.ci.cloudbees.com/job/openHAB/ and tried with the SNAPSHOT 1.8.0 version, both of them works and i can test different examples from here with my laptop and 2 smartphones.
                    2. every time i try a server, i have 2 folders with as follows: 1 folder is the original addons folder wich is empty and another one as a copy like addons1 in which i extracted all addons. Before starting the server i copy the needed addon (.jar file) in the original folder named addons, in my case the serial.jar.
                    3. if the server is not started i can compile the SerialGateway code and i can upload it too into my arduino. The problem si that when i open the serial monitor of arduino IDE i get some strange chars like: \Ú or LÊ or Lœ and this is happening every time i open the serial monitor. I think is a baudrate problem but i cant see where in the SerialGateway sketch i can change this baudrate or should i change it directly in the library? By the way, can you please tell me, why its not working with different baudrates?
                    4. i have all libraries from here http://www.mysensors.org/download/ copied and pasted directly in my arduino libraries folder which in my case is in D/kit/arduino/libraries. For DHT i have DHT library / DHT tester! Do i need other library? i Know i tested a sketch for DHT11 and an LCD and it worked.
                    However, if i have the server started on my laptop its impossible to compile the SerialGateway sketch and i receive this error posted above. I even can't upload the sketch if i close the server, i need to restart my PC....
                    Maybe it would be a beeter sollution to use Mqtt because i have a wiznet w5100 and a ENC28J60 ethernet module but the problem is (i asked somewhere here on the forum) that i cannot use or test Mosquitto broker, and so i cannot test a Mqtt connection. I downloaded the broker from the original page for my system, i have it installed on windows but i cannot access any of the .exe files because of some missing dll. After days of searching and a lot of struggling i got the dll's but didn't start because of some unexpected error! I know this is the subject of another topic but i didn't get a reply there so i ask here...
                    If i cannot test a server on my machine how to purchase a RPI and moreover i never had a RPI so you can imagine how many problems i will face. Anyhow, this is my intention, to buy a RPI and to have a permanent installation.
                    Don't know what to do .... :(((
                    • T
                      TimO
                      Ok, I think we're getting closer.
                      So, If you see strange chars in the serial monitor the baud rate of the serial monitor isn't right. Just change the baud rate in the serial monitor, it's a dropdown at the bottom right. If you set it to 115200 baud it should work (Gateway startup complete).
                      The 115.200 is a fixed baud rate MySensors uses. It is faster than 9600 and the serial communication could be the bottleneck. In the MySensors library it is defined in MySensors.h. You may change that, but that won't help.
                      I suppose you have a blocking issue, since both Arduino IDE and OpenHAB try to use the COM port. Try to make sure only one application at a time is running and using the port. At least OpenHAB should throw an error that the COM port is blocked. I'm not sure how Windows handles blocking.
                      If you see "Gateway startup complete" in the Arduino IDE / serial monitor, close the Arduino IDE (and the serial monitor) and fire up OpenHAB with debugging enabled (start_debug.bat). Post everything the serial binding throws out here.
                      Can't help you with MQTT because I haven't used it yet.
                      • E
                        E
                        ewgor
                        I changed the baud rate to 115200 and now it says "0;0;3;0;9;check wires" on both Arduino (Uno and Mega). I think i saw a topic here somewhere, do i need to change some pins in the SerialGateway sketch?
                        • T
                          TimO
                          Check the connections between NRF24L01+ and Arduino Uno.
                          In case of the Arduino Mega you have to change the sketch (CE/CSN Pin), just search the forum for an example.
                          • E
                            E
                            ewgor
                            I dont have any NRF24L01 in myhouse! what is this device? do i have to buy one to see this SerialGateway working between my PC and my Arduino board?
                            For my Mega ive searched on the the forum but i dont understand how to change the CE/CSN pin ...
                            I asked on some other topic but no answer.
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @ewgor
                              Have you read this page ?
                              and this one.
                              NRF24L01 is the essentially the heart of the mysensors system, it's the radio which it's build uppon.
                              • tbowmoT tbowmo
                                @ewgor
                                and this one.
                                E
                                E
                                ewgor
                                @tbowmo yes i did, only is just i didnt understand that the NRF24L01 is a must! I already ordered a piece and in a few days i'll be able to test either the Serial Gateway or the Ethernet Gateway....
                                • T TimO
                                  E
                                  E
                                  ewgor
                                  #61
                                  • E
                                    E
                                    ewgor
                                    #62
                                    i solved the problem with DHT, now i need to know how to configure Openhab in order to see the the gateway. I changed the COM in items already.
                                    In order to test your sketch that one with DHT and 2 realys what should i do? do i need 2 arduinos: one as a gateway and 2nd as a node point? how many nRF modules do i need?
                                    Now i have nRF24L01 but i dont know how to make it work with OpenHAB
                                    In addons i have org.openhab.binding.serial-1.7.0.jar
                                    Any help please?
                                    • E
                                      E
                                      ewgor
                                      #63
                                      Anyone, any idea how to test the serial gateway? At this point on the serial monitor i get 0;0;3;0;14;Gateway startup complete. How to test it with Openhab? PLS HELP :)
                                      For gateway im using a UNO and i try to have my mega as a node point. If i use Arduino Mega as a gateway its ok, i couldnt find any connection scheme for the node point (mega or uno). Right now i see on the serial monitor of the node point check wires and on the gateway startup complete! Where is the problem? how to connect the node point with my relays and what should i see on the serial monitor? Again somebody pls help me understand how to test it with Openhab?
                                      • T
                                        TimO
                                        For the Arduino Mega you have to change the connections. Check out this thread:
                                        http://forum.mysensors.org/topic/249/arduino-mega-sensor-shield-2
                                        When the "node point" starts up fine you should see a lot of messages coming on the serial monitor of the gateway. Then the communication between both nodes is working.
                                        • T TimO
                                          E
                                          E
                                          ewgor
                                          @TimO with your help again i managed to find the right pins on my mega and now with my dht11 connected i get the temp and hum values constantly. On the server side when i start the bat file or sh file i get the values on the node serial monitor but nothing apears on the localhost.
                                          there are any changes that needs to be done in the items, rules or the sitemap?
                                          thanks for replay.
