  3. N00b + MQTT gw + openHAB2
26 Posts 5 Posters 9.0k Views 5 Watching
    Just do everything in code so you present relay status not pin status
    MasMatM 1 Reply Last reply
      MasMatM
      MasMatM
      MasMat
      @gohan How do I do that? I tried reversing the:
      #define RELAY_ON 0 // GPIO value to write to turn on attached relay
      #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
      I switched around the 0 and 1 but no real change...
        Did you get a debug log where you actually see the node receiving the message to change the relay status? Because setting the defines as you said should be correct
        • MasMatM
          MasMatM
          MasMat
          I see the mqtt message going out. I have to double check the 0 vs 1 in the messages.
          I'm about to build another sensor that has only relays. So I will troubleshoot this code & mqtt to make it match.
            Actually I mean the serial debug of the node, not the mqtt log
              MasMatM
              MasMatM
              MasMat
              @gohan gonna examine that too before actually hooking it up. Thanks
