  3. N00b + MQTT gw + openHAB2
26 Posts 5 Posters 9.0k Views 5 Watching
  • Q
    Q
    Qu3Uk
    I use MQTT and Openhab2 - I find it more flexible then the Ethernet GW but yes you need to have a good understanding on all systems I suppose.
    Somethings to note
    • MySensors binding doesn't support MQTT gateway as far as I know, you need to use the MQTT binding and configure your OH items accordingly.
    • MySensors binding is in the IOT market place and not openhab-addons
    • You'll need to assign node ID to your nodes manually.
    Not entirely sure what your problem is here but don't think you've got all the right pieces for the puzzle yet.
    gohanG 1 Reply Last reply
    • Q Qu3Uk
      Somethings to note
      @Qu3Uk I remember that Mysensors binding works both ethernet and MQTT, but anyway ethernet is the best solution for beginners because you can use myscontroller to debug messages while connected to controller.
      Q E 2 Replies Last reply
        Q
        Q
        Qu3Uk
        @gohan Ah really? I've loosely been following last i saw there was a proof of concept mentioned.
          E
          E
          ericvdb
          wrote on last edited by ericvdb
          @gohan said in N00b + MQTT gw + openHAB2:
          With MQTT you can also debug using MQTT-Spy or MQTTLens or various other MQTT apps.
          MQTT is easy in interconnecting various systems without they have to know about each-other.
          As long as you have a MQTT broker (RabbitMQ, Mosquitto, ActiveMQ, ...) you're all set.
          In OpenHab in conf/services create a file called mqtt.cfg, and past the following:
          mqtt:broker.url=tcp://ip-address-of-mqttbroker:1883
          mqtt:broker.clientId=openhab
          mqtt:broker.retain=true
          mqtt:broker.async=false
          Then in your items file you can do:
          Switch Light_GV_Hall    			"Ceiling"       	(GV_Hall, Lights) {mqtt=">[broker:myhome/room/switch1:command:ON:1],>[broker:myhome/room/switch1:command:OFF:0],<[broker:myhome/room/switch1:state:ON:1],<[broker:myhome/room/switch1:state:OFF:0"}
          And now you can turn on/off the light from OpenHab as wel as from any other device that publishes to the same toppic (yes, even from MQTT-Spy and MQTTLens)
          • E ericvdb
            @ericvdb I know, I am talking for a beginner perspective. The more advanced users know how to debug over mqtt and stuff
            • MasMatM
              MasMatM
              MasMat
              Update.
              After much trying the Ethernet gw would not connect to Domoticz.
              Then, tried my mqtt sketch again and presto! I have connection AND I can control the two relays on board the mqtt-gw.
              Had a cold one...or four!
              Thanks for the recommendations and help. I'm sure I will need more later on. Now I'm going to explore the Domoticz forum for answers.
              Unless someone with the same setup can tell me why the lights are crossed (on = off in reality and off=light on)?
                Depends on relay board
                • MasMatM
                  MasMatM
                  MasMat
                  I just have the modules. low=relay on.
                  I think it would be easier to change it in Domoticz or do I have to change it in the sketches (I think this will be more work when I add new sensors and relays)?
                    Just do everything in code so you present relay status not pin status
                    MasMatM 1 Reply Last reply
                      MasMatM
                      MasMatM
                      MasMat
                      @gohan How do I do that? I tried reversing the:
                      #define RELAY_ON 0 // GPIO value to write to turn on attached relay
                      I switched around the 0 and 1 but no real change...
                        Did you get a debug log where you actually see the node receiving the message to change the relay status? Because setting the defines as you said should be correct
                        • MasMatM
                          MasMatM
                          MasMat
                          I see the mqtt message going out. I have to double check the 0 vs 1 in the messages.
                          I'm about to build another sensor that has only relays. So I will troubleshoot this code & mqtt to make it match.
                            Actually I mean the serial debug of the node, not the mqtt log
                              MasMatM
                              MasMatM
                              MasMat
                              @gohan gonna examine that too before actually hooking it up. Thanks
