Battery-powered irrigation controller
@Andreas-Menzel I personally tend to replace the batteries early enough. I also have at the controller level a couple of safety checks with are ensuring 1) the "close" message is acknowledged by the sensor and if not resend it again 2) a humidity sensor in the ground checking if it is still irrigating after e.g. 2-3 hours the valve is supposed to be closed.
I've noticed if the battery is almost over and unable to close the valve once, it will likely succeed when retrying. Then of course batteries have to be changed.
Over the years I've refined this old project over and over mainly making the capacitor bigger since the valve would otherwise drain so much current to dramatically shorten the battery's life. But this is still border line for the capability of a battery powered sensor I believe. -
@user2684 I am also planning to build latching valve controller. But my valve is 2" to 4" and Its coil specifications are as follow:
V: 6-20Volt DC (optimal is above 9volt)
Capacitance Required: 4700uF
Coil inductance: 90mH
Pulse duration: 20 to 200mili seconds.Do you think h-bridge will work or do you have a better suggestion for this? My goal is also to run the controller on battery and place in farm so it must be waterproof.
@chamroeun-ou If you need to reverse polarity then a H bridge would be good - I would aim for 12V (maybe a lead acid battery with solar panel and small charge controler). This assumes a coil pules reversal to change over the relay, if it is dual coil relay then it will be different, but we don't have that info. Also note the coil resistance and therefore current needed. A 6681FNG H bridge would be good as it is rated up to 15V and handles 1A with ease...
@chamroeun-ou said in Battery-powered irrigation controller:
HI,
I'm doing quite the same project at the moment; I ordered H bridge and also some flow detectors to check if the bistable valve is really in the desired position ( open not to see a desert, closed not to flood everything)
Powered by 1 solar panel + 9v batteries + load controler + step down converters for Arduino and radio. -
Over the years I've refined this old project over and over mainly making the capacitor bigger since the valve would otherwise drain so much current to dramatically shorten the battery's life. But this is still border line for the capability of a battery powered sensor I believe.@user2684 I've just been tinkering on a project like this, so happy to find this and learn from you. Wondering if you've made any significant changes to your circuit and code that you could share so we can learn from your updated experience. How long at you getting from 3AA batteries typically? Love the project.
Hi @ciaocibai, no big changes to the code, maybe just MY_SMART_SLEEP_WAIT_DURATION_MS set to 1000 to ensure the valve is not impacting receiving/transmitting when triggering. All the rest is the same, just using the latest version of NodeManager. Ah, I also added a push button for turning irrigation on/off directly from the device.
Difficult to say regarding battery usage: since I've placed it far away I had to do some changes in the radio management piece which is draining battery considerably. With this setup 3 AA batteries last for around 2 months which is nothing but I believe this is mainly due to the radio settings.
Just for reference this is the latest version of the code:/********************************** * MySensors node configuration */ // General settings #define SKETCH_NAME "Irrigation" #define SKETCH_VERSION "3.2" //#define MY_DEBUG #define MY_NODE_ID 6 // RFM69 radio settings #define MY_RADIO_RFM69 #define MY_IS_RFM69HW #define MY_RFM69_NEW_DRIVER #define MY_RFM69_ATC_MODE_DISABLED #define MY_RFM69_TX_POWER_DBM (10) #define MY_RFM69_MAX_POWER_LEVEL_DBM (10) // Advanced settings #define MY_BAUD_RATE 9600 #define MY_SMART_SLEEP_WAIT_DURATION_MS 1000 #define MY_SPLASH_SCREEN_DISABLED #define MY_SIGNAL_REPORT_ENABLED /*********************************** * NodeManager configuration */ #define NODEMANAGER_DEBUG ON #define NODEMANAGER_INTERRUPTS ON #define NODEMANAGER_SLEEP ON #define NODEMANAGER_RECEIVE ON #define NODEMANAGER_DEBUG_VERBOSE OFF #define NODEMANAGER_POWER_MANAGER OFF #define NODEMANAGER_CONDITIONAL_REPORT OFF #define NODEMANAGER_EEPROM OFF #define NODEMANAGER_TIME OFF #define NODEMANAGER_RTC OFF #define NODEMANAGER_SD OFF #define NODEMANAGER_HOOKING ON #define NODEMANAGER_OTA_CONFIGURATION OFF #define NODEMANAGER_SERIAL_INPUT OFF // import NodeManager library (a nodeManager object will be then made available) #include <MySensors_NodeManager.h> /*********************************** * Add your sensors */ //PowerManager power(5,6); #include <sensors/SensorBattery.h> SensorBattery battery; #include <sensors/SensorSignal.h> SensorSignal signal; #include <sensors/SensorInterrupt.h> SensorInterrupt button(3); #include <sensors/SensorLatchingRelay2Pins.h> SensorLatchingRelay2Pins valve(5,6); /*********************************** * Main Sketch */ void toggleValve(Sensor* sensor) { valve.toggleStatus(); } // before void before() { /*********************************** * Configure your sensors */ // battery sensor battery.setMinVoltage(3.2); battery.setMaxVoltage(4.6); battery.setBatteryInternalVcc(false); battery.setBatteryPin(A0); battery.setBatteryVoltsPerBit(0.00459433); battery.setReportIntervalMinutes(30); //signal sensor signal.setReportIntervalMinutes(30); // button button.setInterruptHook(&toggleValve); button.setInterruptMode(FALLING); button.setInvertValueToReport(true); nodeManager.setInterruptDebounce(1000); // valve valve.setSafeguard(120); valve.setWaitAfterSet(2000); valve.setLegacyMode(true); valve.children.get(1)->setChildId(4); // node configuration nodeManager.setSleepBetweenSendSleepOrWait(true); nodeManager.setSleepSeconds(60*5); // call NodeManager before routine nodeManager.before(); } // presentation void presentation() { // call NodeManager presentation routine nodeManager.presentation(); } // setup void setup() { // call NodeManager setup routine nodeManager.setup(); } // loop void loop() { // call NodeManager loop routine nodeManager.loop(); } #if NODEMANAGER_RECEIVE == ON // receive void receive(const MyMessage &message) { // call NodeManager receive routine nodeManager.receive(message); } #endif #if NODEMANAGER_TIME == ON // receiveTime void receiveTime(unsigned long ts) { // call NodeManager receiveTime routine nodeManager.receiveTime(ts); } #endif -
I have already done all the same plus a flow control to check whether the valve is open or not and... it works perfectly.
