  3. Secure 5-button keyfob with enclosure (was: 8-button keyfob)
72 Posts 5 Posters 25.1k Views 7 Watching
  • AnticimexA Anticimex
    @elcaron the atsha ID is completely separated from the hmac calculation circuitry. The atsha204a calculates a symmetrical hmac (symmetrical in a non cryptography-meaning). It has to, or another atsha would not be able to redo the same calculation. So no, the serial of an atsha is not included in a hmac calculation. This is done externally as documented in the signing documentation. Therefore blacklisting is not an option, and the whitelisting feature has been developed, so that it is possible to revoke nodes without changing all hmac/PSK keys in the network. This is also the reason for why whitelisting is a completely optional feature (but highly recommended if you have nodes that are publicly accessible).
    E
    E
    elcaron
    @Anticimex Ok, I see my misunderstanding. But that would mean that a lost node (to obtain the ATSHA) and an accessible node (to extract a whitelisted ID but then left in place) combined would give access, wouldn't it?
    AnticimexA 1 Reply Last reply
    • E elcaron
      AnticimexA
      AnticimexA
      Anticimex
      @elcaron yes, until you remove that nodes entry in the whitelist on the receiving side
      E 1 Reply Last reply
        E
        E
        elcaron
        @Anticimex The idea is to let one accessible node alone. Just get the id out and leave it where it is. So there would be no reason to take that node's id off the whitelist.
        • E elcaron
          AnticimexA
          AnticimexA
          Anticimex
          @elcaron I don't understand. Why would the attacker leave your node alone?
          • E
            E
            elcaron
            This post is deleted!
              E
              E
              elcaron
              @Anticimex Oh, forget what I said. I thought that the whitelisting was on network access basis. But the doorlock has to trust the id via whitelisting, and of course it wouldn't trust a patio motion sensor.
              • E elcaron
                AnticimexA
                AnticimexA
                Anticimex
                @elcaron then we are on the same page :)
                • E elcaron
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @elcaron whitelisting is on a per-node basis.
                  • E
                    E
                    elcaron
                    So apparently it it will be a while until I can do active testing. Right now I am struggling to get my network running at all.
                    I'll quickly post it here in case someone has an idea, else I'll open a thread next week when I actually have time to react to suggestions.
                    I have flashed the GatewayESP8266MQTT sketch to my gateway (Wemos D1 Mini + RFM69HCW). This is the output:
                    0;255;3;0;9;TSF:LRT:OK
                    0;255;3;0;9;TSM:INIT
                    0;255;3;0;9;TSF:WUR:MS=0
                    0;255;3;0;9;TSM:INIT:TSP OK
                    0;255;3;0;9;TSM:INIT:GW MODE
                    scandone
                    f 0, scandone
                    state: 0 -> 2 (b0)
                    state: 2 -> 3 (0)
                    state: 3 -> 5 (10)
                    add 0
                    aid 3
                    cnt
                    connected with MySSID, channel 1
                    dhcp client start...
                    ...ip:192.168.2.127,mask:255.255.255.0,gw:192.168.2.1
                    .IP: 192.168.2.127
                    0;255;3;0;9;MCO:BGN:STP
                    IP: 192.168.2.127
                    0;255;3;0;9;MQTT connected
                    0;255;3;0;9;Sending message on topic: home-le/mysensors/868/in/0/255/0/0/18
                    pm open,type:2 0
                    The message is successfully published on the MQTT server.
                    I flashed the LightSensor sketch on another breadboard node (Arduino Pro Mini + RFM69HCW). This outputs
                    0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.1
                    4 TSM:INIT
                    4 TSF:WUR:MS=0
                    8 TSM:INIT:TSP OK
                    10 TSM:FPAR
                    141 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2148 !TSM:FPAR:NO REPLY
                    2150 TSM:FPAR
                    2281 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    4290 !TSM:FPAR:NO REPLY
                    4292 TSM:FPAR
                    4423 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    6432 !TSM:FPAR:NO REPLY
                    6434 TSM:FPAR
                    6565 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    8574 !TSM:FPAR:FAIL
                    8577 TSM:FAIL:CNT=1
                    8579 TSM:FAIL:PDT
                    Which apparently indicated that no parent could be found. The gateway doesn't output anything.
                    I did not make any changes to the gateway sketch except for password and name stuff (especially no inclusion mode). Devices are a meter apart, one with a spring antenna, the other with a big screw-on antenna.
                    • MiKaM MiKa
                      @scalz THX for tip, pull-up CS to VDD solved problem! :+1:
                      @elcaron please add pull up to CS line
                      E
                      E
                      elcaron
                      @MiKa Version with pullup is pushed to Github
                      MiKaM 1 Reply Last reply
                      • E elcaron
                        MiKaM
                        MiKaM
                        MiKa
                        @elcaron Perfect, THX! :+1:
                        • MiKaM MiKa
                          E
                          E
                          elcaron
                          wrote on last edited by elcaron
                          #72
                          @MiKa If you happen to have time, could you test the range with
                          1. a stable 2.7V supply and
                          2. a 1mF cap in parallel to the battery?
                          I am really not happy with the HT7333 solution, since the shelf life of the keyfob will be limited and the quite expensive LIR2032 can easily be damaged by undervoltage.
                          If the second test works, I could fit 4 220uF 6.3V tantalums next to the LED.
                          Else I would give the step-up thing another go. There are low profile inductors, but I didn't find any for cheap (shipping) at Aliexpress.
