  3. Secure 5-button keyfob with enclosure (was: 8-button keyfob)
72 Posts 5 Posters 25.7k Views 7 Watching
    #55
    @MiKa for your USBASP programming problem, you could try to add a pullup resistor for the radio. This should fix your issue. 10k, 56k etc.. between CS line and VCC.
    MiKaM 1 Reply Last reply
    • E elcaron
      @Anticimex Ok, let's take encryption out of the equation. I still don't get it.
      As long as the PSK is not transmitted, I don't see how HMAC could be broken. If a soft-signing device is lost, the PSK could be read. But if an ATSHA device is lost, the PSK cannot be read. An attacker could only use the PSK in combination with the fixed ID of that ATSHA; that could be un-whitelisted or blacklisted (I really would like to see blacklisting because of that, I think.)
      Can you sketch a valid attack with a known Id, but without a leaked PSK, or a way how my PSK could leak if I generally only expose ATSHA devices?
      AnticimexA
      AnticimexA
      Anticimex
      @elcaron the PSK is programmed into the atsha. If it is stolen, the PSK is still in the atsha. How do you prevent someone from reprogramming your keyfob and use the atsha with your PSK in it? And if you use black listing, how do you ensure the attacker does not simply just use a different serial by customizing the firmware? The attacker does not have to know the PSK in order to use it if he has your keyfob.
      E 1 Reply Last reply
      • scalzS scalz
        MiKaM
        MiKaM
        MiKa
        @scalz THX for tip, pull-up CS to VDD solved problem! :+1:
        @elcaron please add pull up to CS line
        E 2 Replies Last reply
        • AnticimexA Anticimex
          E
          E
          elcaron
          @Anticimex
          Of course.
          My understanding was that the fixed ATSHA ID goes into the signature inside the closed signing process in the ATSHA. So one ATSHA can only provide signatures with its unique, unchangeable id. If signatures with that id are blacklisted, then the ATSHA is worthless.
          Is that not the case? Can an ATSHA be used to create a signature with an id that is not it's own?
          AnticimexA 1 Reply Last reply
          • MiKaM MiKa
            E
            E
            elcaron
            @MiKa Suspected that. Will put it in.
            • E elcaron
              @Anticimex
              Of course.
              AnticimexA
              AnticimexA
              Anticimex
              #60
              @elcaron the atsha ID is completely separated from the hmac calculation circuitry. The atsha204a calculates a symmetrical hmac (symmetrical in a non cryptography-meaning). It has to, or another atsha would not be able to redo the same calculation. So no, the serial of an atsha is not included in a hmac calculation. This is done externally as documented in the signing documentation. Therefore blacklisting is not an option, and the whitelisting feature has been developed, so that it is possible to revoke nodes without changing all hmac/PSK keys in the network. This is also the reason for why whitelisting is a completely optional feature (but highly recommended if you have nodes that are publicly accessible).
                E
                E
                elcaron
                @Anticimex Ok, I see my misunderstanding. But that would mean that a lost node (to obtain the ATSHA) and an accessible node (to extract a whitelisted ID but then left in place) combined would give access, wouldn't it?
                • E elcaron
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @elcaron yes, until you remove that nodes entry in the whitelist on the receiving side
                    E
                    E
                    elcaron
                    @Anticimex The idea is to let one accessible node alone. Just get the id out and leave it where it is. So there would be no reason to take that node's id off the whitelist.
                    • E elcaron
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @elcaron I don't understand. Why would the attacker leave your node alone?
                      • E
                        E
                        elcaron
                          E
                          E
                          elcaron
                          @Anticimex Oh, forget what I said. I thought that the whitelisting was on network access basis. But the doorlock has to trust the id via whitelisting, and of course it wouldn't trust a patio motion sensor.
                          • E elcaron
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @elcaron then we are on the same page :)
                            • E elcaron
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @elcaron whitelisting is on a per-node basis.
                              • E
                                E
                                elcaron
                                So apparently it it will be a while until I can do active testing. Right now I am struggling to get my network running at all.
                                I'll quickly post it here in case someone has an idea, else I'll open a thread next week when I actually have time to react to suggestions.
                                I have flashed the GatewayESP8266MQTT sketch to my gateway (Wemos D1 Mini + RFM69HCW). This is the output:
                                0;255;3;0;9;TSF:LRT:OK
                                0;255;3;0;9;TSM:INIT
                                0;255;3;0;9;TSF:WUR:MS=0
                                0;255;3;0;9;TSM:INIT:TSP OK
                                0;255;3;0;9;TSM:INIT:GW MODE
                                scandone
                                f 0, scandone
                                state: 0 -> 2 (b0)
                                state: 2 -> 3 (0)
                                state: 3 -> 5 (10)
                                add 0
                                aid 3
                                cnt
                                connected with MySSID, channel 1
                                dhcp client start...
                                ...ip:192.168.2.127,mask:255.255.255.0,gw:192.168.2.1
                                .IP: 192.168.2.127
                                0;255;3;0;9;MCO:BGN:STP
                                IP: 192.168.2.127
                                0;255;3;0;9;MQTT connected
                                0;255;3;0;9;Sending message on topic: home-le/mysensors/868/in/0/255/0/0/18
                                pm open,type:2 0
                                The message is successfully published on the MQTT server.
                                I flashed the LightSensor sketch on another breadboard node (Arduino Pro Mini + RFM69HCW). This outputs
                                4 TSM:INIT
                                4 TSF:WUR:MS=0
                                8 TSM:INIT:TSP OK
                                10 TSM:FPAR
                                141 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                2148 !TSM:FPAR:NO REPLY
                                2150 TSM:FPAR
                                2281 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                4290 !TSM:FPAR:NO REPLY
                                4292 TSM:FPAR
                                4423 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                6432 !TSM:FPAR:NO REPLY
                                6434 TSM:FPAR
                                6565 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                8574 !TSM:FPAR:FAIL
                                8577 TSM:FAIL:CNT=1
                                8579 TSM:FAIL:PDT
                                Which apparently indicated that no parent could be found. The gateway doesn't output anything.
                                I did not make any changes to the gateway sketch except for password and name stuff (especially no inclusion mode). Devices are a meter apart, one with a spring antenna, the other with a big screw-on antenna.
                                • MiKaM MiKa
                                  E
                                  E
                                  elcaron
                                  @MiKa Version with pullup is pushed to Github
                                  • E elcaron
                                    MiKaM
                                    MiKaM
                                    MiKa
                                    @elcaron Perfect, THX! :+1:
                                    • MiKaM MiKa
                                      E
                                      E
                                      elcaron
                                      wrote on last edited by elcaron
                                      #72
                                      @MiKa If you happen to have time, could you test the range with
                                      1. a stable 2.7V supply and
                                      2. a 1mF cap in parallel to the battery?
                                      I am really not happy with the HT7333 solution, since the shelf life of the keyfob will be limited and the quite expensive LIR2032 can easily be damaged by undervoltage.
                                      If the second test works, I could fit 4 220uF 6.3V tantalums next to the LED.
                                      Else I would give the step-up thing another go. There are low profile inductors, but I didn't find any for cheap (shipping) at Aliexpress.
