  3. Secure 5-button keyfob with enclosure (was: 8-button keyfob)
72 Posts 5 Posters 25.7k Views 7 Watching
  • AnticimexA Anticimex
    @elcaron yes, until you remove that nodes entry in the whitelist on the receiving side
    E
    E
    elcaron
    @Anticimex The idea is to let one accessible node alone. Just get the id out and leave it where it is. So there would be no reason to take that node's id off the whitelist.
    AnticimexA 1 Reply Last reply
    • E elcaron
      AnticimexA
      AnticimexA
      Anticimex
      @elcaron I don't understand. Why would the attacker leave your node alone?
      E 1 Reply Last reply
      • E
        E
        elcaron
          E
          E
          elcaron
          @Anticimex Oh, forget what I said. I thought that the whitelisting was on network access basis. But the doorlock has to trust the id via whitelisting, and of course it wouldn't trust a patio motion sensor.
          • E elcaron
            AnticimexA
            AnticimexA
            Anticimex
            @elcaron then we are on the same page :)
            • E elcaron
              AnticimexA
              AnticimexA
              Anticimex
              @elcaron whitelisting is on a per-node basis.
              • E
                E
                elcaron
                So apparently it it will be a while until I can do active testing. Right now I am struggling to get my network running at all.
                I'll quickly post it here in case someone has an idea, else I'll open a thread next week when I actually have time to react to suggestions.
                I have flashed the GatewayESP8266MQTT sketch to my gateway (Wemos D1 Mini + RFM69HCW). This is the output:
                0;255;3;0;9;TSF:LRT:OK
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSF:WUR:MS=0
                0;255;3;0;9;TSM:INIT:TSP OK
                0;255;3;0;9;TSM:INIT:GW MODE
                scandone
                f 0, scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 5 (10)
                add 0
                aid 3
                cnt
                connected with MySSID, channel 1
                dhcp client start...
                ...ip:192.168.2.127,mask:255.255.255.0,gw:192.168.2.1
                .IP: 192.168.2.127
                0;255;3;0;9;MCO:BGN:STP
                IP: 192.168.2.127
                0;255;3;0;9;MQTT connected
                0;255;3;0;9;Sending message on topic: home-le/mysensors/868/in/0/255/0/0/18
                pm open,type:2 0
                The message is successfully published on the MQTT server.
                I flashed the LightSensor sketch on another breadboard node (Arduino Pro Mini + RFM69HCW). This outputs
                4 TSM:INIT
                4 TSF:WUR:MS=0
                8 TSM:INIT:TSP OK
                10 TSM:FPAR
                141 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2148 !TSM:FPAR:NO REPLY
                2150 TSM:FPAR
                2281 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                4290 !TSM:FPAR:NO REPLY
                4292 TSM:FPAR
                4423 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                6432 !TSM:FPAR:NO REPLY
                6434 TSM:FPAR
                6565 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                8574 !TSM:FPAR:FAIL
                8577 TSM:FAIL:CNT=1
                8579 TSM:FAIL:PDT
                Which apparently indicated that no parent could be found. The gateway doesn't output anything.
                I did not make any changes to the gateway sketch except for password and name stuff (especially no inclusion mode). Devices are a meter apart, one with a spring antenna, the other with a big screw-on antenna.
                • MiKaM MiKa
                  @scalz THX for tip, pull-up CS to VDD solved problem! :+1:
                  @elcaron please add pull up to CS line
                  E
                  E
                  elcaron
                  @MiKa Version with pullup is pushed to Github
                  MiKaM 1 Reply Last reply
                  • E elcaron
                    MiKaM
                    MiKaM
                    MiKa
                    @elcaron Perfect, THX! :+1:
                    • MiKaM MiKa
                      E
                      E
                      elcaron
                      wrote on last edited by elcaron
                      #72
                      @MiKa If you happen to have time, could you test the range with
                      1. a stable 2.7V supply and
                      2. a 1mF cap in parallel to the battery?
                      I am really not happy with the HT7333 solution, since the shelf life of the keyfob will be limited and the quite expensive LIR2032 can easily be damaged by undervoltage.
                      If the second test works, I could fit 4 220uF 6.3V tantalums next to the LED.
                      Else I would give the step-up thing another go. There are low profile inductors, but I didn't find any for cheap (shipping) at Aliexpress.
