  2. Enclosures / 3D Printing
  3. MySensors weather station
138 Posts 16 Posters 112.8k Views 15 Watching
  • dbemowskD
    dbemowskD
    How often do people transmit their wind speed to the controller.
    • tombstoneT
      tombstoneT
      tombstone
      really looking good :+1:
      dbemowskD 1 Reply Last reply
      • tombstoneT tombstone
        dbemowskD
        dbemowskD
        @tombstone thanks.
        Trying to run some tests today. I think I have some workable code, but I don't have any sleep figured in yet. With all of the sensors being run from one pro mini, there is a lot going on and I will need to figure sleep in carefully if I even do. I have temp, humidity, rain, wind direction and wind speed. Arduino IDE says that it takes 75% of the program memory and that is not with debugging on. If I turn that on I start to get warnings, but it will compile and run.
        Getting even closer to being able to mount this on my roof.
        • dbemowskD
          dbemowskD
          So I am running into a problem with the code I am working on. Specifically the wind direction sensor. When I reset the node, the first loop of the main loop, it gets the wind direction fine, but gets an incorrect reading every time after regardless of where I position the sensor. Here is a snippet of the debug output:
          Sensor Presentation Complete
          New Sensor State... Sensor: Not Tripped
          Anemometer speed in Hz 0.00
          Current wind speed is 0
          Current average wind speed is 0.00
          Wind position: 231
          Wind direction: 52
          Temperature is: 74.84
          Humidity is: 53.20
          Humidity is: 53.50
          Wind position: 179
          Wind direction: 0
          Wind position: 179
          Wind direction: 0
          As you can see, the initial reading shows the following:
          Wind position: 231
          Wind direction: 52
          After that, every reading shows:
          Wind position: 179
          Wind direction: 0
          All sensor readings are getting transmitted back to my Vera controller fine. Here is the full sketch for the node:
           Arduino Tipping Bucket Rain Gauge
           April 26, 2015
           Version 2.0
           Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
           gateway you can measure and sense local rain.  This sketch will create two devices on your
           Vera controller.  One will display your total precipitation for the last 5 days.  The other,
           a sensor that changes state if there is recent rain (up to last 120 hours)  above a threshold.
           Both these settings are user definable.
           There is a build overview video here: https://youtu.be/1eMfKQaLROo
           This sketch features the following:
           * Allows you to set the rain threshold in mm
           * Allows you to determine the tripped indicator window up to 120 hours.
           * Displays the last 5 days of rain in Variable1 through Variable5
             of the Rain Sensor device
           * Configuration changes to Sensor device updated every hour
           * Should run on any Arduino
           * Will retain Tripped/Not Tripped status and data in a power interruption, saving small amount
             of data to EEPROM (Circular Buffer to maximize life of EEPROM)
           * LED status indicator
           * Optional Temp/Humidity (DHT-22 or DHT-11) and Light LUX (BH1750) sensors. To use, uncomment
             #define DHT_ON  and/or #define LUX_ON
           * Optionally send total accumulation of each day's rainfall or send only individual days rainfall totals.
             Uncomment #define USE_DAILY to display individual daily rainfall.  If it is commented out it will display
             a cumulative total rainfall (day4 = day1+day2+day3+day4 etc)
           by @BulldogLowell and @PeteWill for free public use
          //#define MY_DEBUG // Enable MySensors debug prints to serial monitor
          //#define MY_NODE_ID 7 //uncomment this line to assign a static ID
          #include "AS5047.h"
          #include <math.h>
          #include <TimeLib.h>
          #define SKETCH_NAME "Weather Station"
          #define SKETCH_VERSION "2.0"
          #define DWELL_TIME 40  // this allows for radio to come back to power after a transmission, ideally 0
          #define DEBUG_ON  // Rain gauge specific debug messages.
          #define RAIN_ON // uncomment out this line to enable the rain sensor
          #define DHT_ON // uncomment out this line to enable DHT sensor
          //#define LUX_ON // uncomment out this line to enable BH1750 sensor
          #define ANEMOMETER_ON // uncomment out this line to enable anemometer sensor
          #define AS5047_ON // uncomment out this line to enable AS5047 wind direction sensor
          #define USE_DAILY // Uncomment to display individual daily rainfall totals in the variables sent to your controller. If it's commented it will add each day to the next for a cumulative total.
          #define NORTH_SWITCH_PIN 7 //The north calibration switch
          #define AS5047_CHIP_SELECT_PIN 5 //The north calibration switch
          #define ANEMOMETER_PIN 2 //The wind speed sensor
          #define TIP_SENSOR_PIN 3 //The tipping bucket rain sensor
          #define CALIBRATE_FACTOR 60 // amount of rain per rain bucket tip e.g. 5 is .05mm
          #define DHT_LUX_DELAY 3000  //Delay in milliseconds that the DHT and LUX sensors will wait before sending data
          #define WIND_DIR_DELAY 5000  //Delay in milliseconds that the wind direction sensor will wait before sending data
          #define NORTH_OFFSET_BUTTON_DELAY 5000  //Delay in milliseconds that the DHT and LUX sensors will wait before sending data
          #define CHILD_ID_RAIN_LOG 3  // Keeps track of accumulated rainfall
          #define CHILD_ID_TRIPPED_INDICATOR 4  // Indicates Tripped when rain detected
          #define CHILD_ID_WIND 5  // Indicates Tripped when rain detected
          #define EEPROM_NORTH_OFFSET_LOCATION 0  // location of the EEPROM circular buffer
          #define EEPROM_BUFFER_LOCATION 2  // location of the EEPROM circular buffer
          #define E_BUFFER_LENGTH 240
          #define RAIN_BUCKET_SIZE 120
          #ifdef  DEBUG_ON
            #define DEBUG_PRINT(x)   Serial.print(x)
            #define SERIAL_START(x)  Serial.begin(x)
            #else
          MyMessage msgRainRate(CHILD_ID_RAIN_LOG, V_RAINRATE);
          MyMessage msgRain(CHILD_ID_RAIN_LOG, V_RAIN);
          MyMessage msgRainVAR1(CHILD_ID_RAIN_LOG, V_VAR1);
          MyMessage msgRainVAR2(CHILD_ID_RAIN_LOG, V_VAR2);
          MyMessage msgRainVAR3(CHILD_ID_RAIN_LOG, V_VAR3);
          MyMessage msgRainVAR4(CHILD_ID_RAIN_LOG, V_VAR4);
          MyMessage msgRainVAR5(CHILD_ID_RAIN_LOG, V_VAR5);
          MyMessage msgTripped(CHILD_ID_TRIPPED_INDICATOR, V_TRIPPED);
          MyMessage msgTrippedVar1(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
          MyMessage msgTrippedVar2(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
          #ifdef ANEMOMETER_ON
          MyMessage msgWindSpeed(CHILD_ID_WIND, V_WIND);
          MyMessage msgWindGust(CHILD_ID_WIND, V_GUST);
          #ifdef AS5047_ON
          MyMessage msgWindDirection(CHILD_ID_WIND, V_DIRECTION);
          #ifdef DHT_ON
            #include <DHT.h>
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            #define HUMIDITY_SENSOR_DIGITAL_PIN 6
            DHT dht;
            float lastTemp;
            float lastHum;
            bool metric = false;
          #ifdef LUX_ON
            //BH1750 is connected to SCL (analog input A5) and SDA (analog input A4)
            #include <BH1750.h>
            #include <Wire.h>
            #define CHILD_ID_LIGHT 2
            BH1750 lightSensor;
            unsigned int lastlux;
            uint8_t heartbeat = 10; //Used to send the light lux to gateway as soon as the device is restarted and after the DHT_LUX_DELAY has happened 10 times
          volatile unsigned long startTime = 0; //stores start time for wind speed calculation
          unsigned long dataTimer = 0; //used to track how often to communicate data
          unsigned long gustTimer = 0; //used to track how often to communicate wind gust data
          volatile float pulseTime = 0; //stores time between one anemomter relay closing and the next
          volatile float cumulativePulseTime = 0; //stores cumulative pulsetimes for averaging
          volatile bool start = true; //tracks when a new anemometer measurement starts
          volatile unsigned int averageWindCount = 0; //stores anemometer relay counts for doing average wind speed
          int16_t gustMax = 0; //stores the max reported wind speed used for the V_GUST value
          float alarmSetting = 60.0; //wind speed setting to signal alarm
          #ifdef AS5047_ON
          AS5047 myAS5047(AS5047_CHIP_SELECT_PIN); //Wind direction magnetic position sensor
          long north_offset;
          bool button;
          int wind_direction;
          int last_direction;
          long wind_position;
          unsigned long sensorPreviousMillis;
          #ifdef AS5047_ON
          unsigned long windDirPreviousMillis;
          unsigned long northButtonPreviousMillis;
          int eepromIndex;
          int tipSensorPin = 3; // Pin the tipping bucket is connected to. Must be interrupt capable pin
          int ledPin = 8; // Pin the LED is connected to.  PWM capable pin required
          #ifdef DEBUG_ON
          unsigned long dataMillis;
          unsigned long serialInterval = 600000UL;
          const unsigned long oneHour = 3600000UL;
          unsigned long lastTipTime;
          unsigned long lastRainTime; //Used for rainRate calculation
          unsigned int rainBucket [RAIN_BUCKET_SIZE] ; /* 24 hours x 5 Days = 120 hours */
          unsigned int rainRate = 0;
          uint8_t rainWindow = 72;         //default rain window in hours.  Will be overwritten with msgTrippedVar1.
          volatile int wasTippedBuffer = 0;
          int rainSensorThreshold = 50; //default rain sensor sensitivity in hundredths.  Will be overwritten with msgTrippedVar2.
          uint8_t state = 0;
          uint8_t oldState = 2; //Setting the default to something other than 1 or 0
          unsigned int lastRainRate = 0;
          int lastMeasure = 0;
          bool gotTime = false;
          uint8_t lastHour;
          uint8_t currentHour;
          void presentation()  {
            wait(DWELL_TIME);
            present(CHILD_ID_RAIN_LOG, S_RAIN);
            wait(DWELL_TIME);
            present(CHILD_ID_TRIPPED_INDICATOR, S_MOTION);
            wait(DWELL_TIME);
          #ifdef ANEMOMETER_ON OR AS5047_ON
            present(CHILD_ID_WIND, S_WIND);
            wait(DWELL_TIME);
          #ifdef DHT_ON
            present(CHILD_ID_HUM, S_HUM);
            wait(DWELL_TIME);
            wait(DWELL_TIME);
          #ifdef LUX_ON
            DEBUG_PRINTLN(F("Sensor Presentation Complete"));
            #ifndef MY_DEBUG
            SERIAL_START(115200);  //Start serial if MySensors debugging isn't enabled
            pinMode(NORTH_SWITCH_PIN, INPUT_PULLUP);
            pinMode(ANEMOMETER_PIN, INPUT_PULLUP); //set interrupt pin to input pullup
            attachInterrupt(ANEMOMETER_PIN, anemometerISR, RISING); //setup interrupt on anemometer input pin, interrupt will occur whenever falling edge is detected
            dataTimer = millis(); //reset loop timer
            gustTimer = millis(); //reset loop timer
            // Set up the IO
            pinMode(TIP_SENSOR_PIN, INPUT_PULLUP);
            attachInterrupt (digitalPinToInterrupt(TIP_SENSOR_PIN), bucketSensorTippedISR, FALLING);  // depending on location of the hall effect sensor may need CHANGE
            pinMode(ledPin, OUTPUT);
            digitalWrite(ledPin, HIGH);
            //Sync time with the server
            unsigned long functionTimeout = millis();
            while (timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL)
              requestTime();
              DEBUG_PRINTLN(F("Getting Time"));
              wait(1000); // call once per second
              DEBUG_PRINTLN(F("."));
            currentHour = hour();
            lastHour = hour();
            //retrieve from EEPROM stored values on a power cycle.
          #ifdef AS5047_ON
            //Get the north offset direction
            getNorthOffset();
            bool isDataOnEeprom = false;
            for (int i = 0; i < E_BUFFER_LENGTH; i++)
              uint8_t locator = loadState(EEPROM_BUFFER_LOCATION + i);
              if (locator == 0xFE)  // found the EEPROM circular buffer index
                eepromIndex = EEPROM_BUFFER_LOCATION + i;
                DEBUG_PRINT(F("EEPROM Index "));
                DEBUG_PRINTLN(eepromIndex);
                //Now that we have the buffer index let's populate the rainBucket[] with data from eeprom
                loadRainArray(eepromIndex);
                isDataOnEeprom = true;
                break;
            if (!isDataOnEeprom) // Added for the first time it is run on a new Arduino
              DEBUG_PRINTLN(F("I didn't find valid EEPROM Index, so I'm writing one to location 0"));
              eepromIndex = EEPROM_BUFFER_LOCATION;
              saveState(eepromIndex, 0xFE);
              saveState(eepromIndex + 1, 0xFE);
              //then I will clear out any bad data
              for (int i = 2; i <= E_BUFFER_LENGTH; i++)
                saveState(i, 0x00);
            #ifdef DEBUG_ON
            dataMillis = millis();
            lastTipTime = millis();
            request(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
            wait(DWELL_TIME);
            request(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
            wait(DWELL_TIME);
          #ifdef DHT_ON
            metric = getConfig().isMetric;
            //metric = false;
            wait(DWELL_TIME);
          #ifdef LUX_ON
            lightSensor.begin();
            transmitRainData(); //Setup complete send any data loaded from eeprom to gateway
            if (state)
              prettyFade();  // breathe if tripped
            else
              slowFlash();   // blink if not tripped
          #ifdef DEBUG_ON  // Serial Debug Block
            if ( (millis() - dataMillis) >= serialInterval)
              for (int i = 24; i <= 120; i = i + 24)
                updateSerialData(i);
          #ifdef RAIN_ON
            // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold
            int measure = 0; // Check to see if we need to show sensor tripped in this block
            for (int i = 0; i < rainWindow; i++)
              measure += rainBucket [i];
              if (measure != lastMeasure)
                //      DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
                //      DEBUG_PRINTLN(measure);
                lastMeasure = measure;
            state = (measure >= (rainSensorThreshold * 100));
            if (state != oldState)
              send(msgTripped.set(state));
              wait(DWELL_TIME);
              DEBUG_PRINT(F("New Sensor State... Sensor: "));
              DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
              oldState = state;
            // The radius from center to the reed switch is 27.5mm or 1.082677 inches.  This gives us a circumference of
            // 6.80266 inches traveled for every tick of the reed switch.  This converts to 0.5668883 feet per revolution.
            // That makes 9,314 revolutions per mile.  This calculates to 1 Hz = 2.5872 MPh
            if((millis() - startTime) > 2500) pulseTime = 0; //if the wind speed has dropped below 1MPH than set it to zero
             //See if it is time to transmit
            if((millis() - dataTimer) > 1800)
              detachInterrupt(ANEMOMETER_PIN); //shut off wind speed measurement interrupt until done communication
              float aWSpeed = getAvgWindSpeed(cumulativePulseTime,averageWindCount); //calculate average wind speed
              cumulativePulseTime = 0; //reset cumulative pulse counter
              averageWindCount = 0; //reset average wind count
              float aFreq = 0; //set to zero initially
              if(pulseTime > 0.0) aFreq = getAnemometerFreq(pulseTime); //calculate frequency in Hz of anemometer, only if pulsetime is non-zero
              int16_t wSpeedMPH = getWindMPH(aFreq); //calculate wind speed in MPH, note that the 2.5 comes from anemometer data sheet
              if(wSpeedMPH > gustMax) gustMax = wSpeedMPH; //Update our highest wind speed for our V_GUST value
              DEBUG_PRINTLN();
              DEBUG_PRINTLN("...................................");
              DEBUG_PRINT("Anemometer speed in Hz ");
              DEBUG_PRINTLN(aFreq);
              DEBUG_PRINT("Current wind speed is ");
              DEBUG_PRINTLN(wSpeedMPH);
              DEBUG_PRINT("Current average wind speed is ");
              DEBUG_PRINTLN(aWSpeed);
              send(msgWindSpeed.set(wSpeedMPH));
              wait(DWELL_TIME);
              start = true; //reset start variable in case we missed wind data while communicating current data out
              attachInterrupt(digitalPinToInterrupt(ANEMOMETER_PIN), anemometerISR, RISING); //turn interrupt back on
            //Send the wind gust speed every minute
            if((millis() - gustTimer) > 60000)
              send(msgWindGust.set(gustMax));
              wait(DWELL_TIME);
              DEBUG_PRINT("Current wind gust speed is ");
              DEBUG_PRINTLN(gustMax);
              gustMax = 0; //Reset for the next wind gust speed
          #ifdef AS5047_ON
            button = digitalRead(NORTH_SWITCH_PIN);
            if (!button && (millis() - northButtonPreviousMillis > NORTH_OFFSET_BUTTON_DELAY)) {
              setNorthOffset();
              northButtonPreviousMillis = millis();
            getNorthOffset();
            wind_position = myAS5047.sensor_read();
            long value = (359*wind_position)/16383;
            wind_direction = ((value - north_offset) < 0) ? 360 - abs(value - north_offset) : value - north_offset;
            if (millis() - windDirPreviousMillis > WIND_DIR_DELAY)
              DEBUG_PRINT("Wind position: ");
              DEBUG_PRINTLN(value);
              DEBUG_PRINT("Wind direction: ");
              DEBUG_PRINTLN(wind_direction);
              if (wind_direction != last_direction)
                send(msgWindDirection.set((int) wind_direction));
                wait(DWELL_TIME);
              last_direction = wind_direction;
              windDirPreviousMillis = millis();
          #ifdef RAIN_ON
            unsigned long tipDelay = millis() - lastRainTime;
            if (wasTippedBuffer) // if was tipped, then update the 24hour total and transmit to Vera
              DEBUG_PRINTLN(F("Sensor Tipped"));
              DEBUG_PRINT(F("rainBucket [0] value: "));
              DEBUG_PRINTLN(rainBucket [0]);
              send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); //Calculate the total rain for the day
              wait(DWELL_TIME);
              wasTippedBuffer--;
              rainRate = ((oneHour) / tipDelay);
              if (rainRate != lastRainRate)
                send(msgRainRate.set(rainRate, 1));
                wait(DWELL_TIME);
                DEBUG_PRINT(F("RainRate= "));
                DEBUG_PRINTLN(rainRate);
                lastRainRate = rainRate;
              lastRainTime = lastTipTime;
            if (currentHour != lastHour)
              DEBUG_PRINTLN(F("One hour elapsed."));
              send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); // send today's rainfall
              wait(DWELL_TIME);
              saveState(eepromIndex, highByte(rainBucket[0]));
              saveState(eepromIndex + 1, lowByte(rainBucket[0]));
              DEBUG_PRINT(F("Saving rainBucket[0] to eeprom. rainBucket[0] = "));
              DEBUG_PRINTLN(rainBucket[0]);
              for (int i = RAIN_BUCKET_SIZE - 1; i >= 0; i--)//cascade an hour of values back into the array
                rainBucket [i + 1] = rainBucket [i];
              wait(DWELL_TIME);
              wait(DWELL_TIME);
              rainBucket[0] = 0;
              eepromIndex = eepromIndex + 2;
              if (eepromIndex > EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH)
              DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
              requestTime(); // sync the time every hour
              wait(DWELL_TIME);
              transmitRainData();
              rainRate = 0;
              wait(DWELL_TIME);
              DEBUG_PRINTLN(F("Sending rainRate is 0 to controller"));
              lastHour = hour();
            if (millis() - sensorPreviousMillis > DHT_LUX_DELAY)
              #ifdef DHT_ON  //DHT Code
                doDHT();
              #ifdef LUX_ON
                doLUX();
              sensorPreviousMillis = millis();
          #ifdef AS5047_ON
          void getNorthOffset()
            north_offset =  (loadState(EEPROM_NORTH_OFFSET_LOCATION+1) << 8) | loadState(EEPROM_NORTH_OFFSET_LOCATION);
          void setNorthOffset()
            DEBUG_PRINT("Direction value: ");
            DEBUG_PRINT("North offset: ");
            DEBUG_PRINTLN(north_offset);
            if (north_offset != wind_direction)
              saveState(EEPROM_NORTH_OFFSET_LOCATION, lowByte(wind_direction));
              saveState(EEPROM_NORTH_OFFSET_LOCATION+1, highByte(wind_direction));
              north_offset = wind_direction;
              DEBUG_PRINT("North offset set to: ");
          //using time between anemometer pulses calculate frequency of anemometer
          float getAnemometerFreq(float pTime)
            return (1/pTime);
          //Use anemometer frequency to calculate wind speed in MPH, note 2.5 comes from anemometer data sheet
          float getWindMPH(float freq)
            return (freq*2.5872);
          //uses wind MPH value to calculate KPH
          int16_t getWindKPH(float wMPH)
            return (wMPH*1.61);
          //Calculates average wind speed over given time period
          float getAvgWindSpeed(float cPulse,int period)
            if(period) return getWindMPH(getAnemometerFreq((float)(cPulse/period)));
            else return 0; //average wind speed is zero and we can't divide by zero
          //This is the interrupt service routine (ISR) for the anemometer input pin
          //it is called whenever a falling edge is detected
          void anemometerISR()
            unsigned long currentTime = millis(); //get current time
            if(!start) { //This is not the first pulse and we are not at 0 MPH so calculate time between pulses
             // test = currentTime - startTime;
              pulseTime = (float)(currentTime - startTime)/1000;
              cumulativePulseTime += pulseTime; //add up pulse time measurements for averaging
              averageWindCount++; //anemomter went around so record for calculating average wind speed
            startTime = currentTime; //store current time for next pulse time calculation
            start = false; //we have our starting point for a wind speed measurement
          #ifdef DHT_ON
          void doDHT(void)
              if (isnan(temperature))
                DEBUG_PRINTLN("-----------------------------------");
                DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
              } else if (temperature != lastTemp)
                lastTemp = temperature;
                if (!metric)
                wait(DWELL_TIME);
                DEBUG_PRINT(F("Temperature is: "));
                DEBUG_PRINTLN(temperature);
              float humidity = dht.getHumidity();;
              if (isnan(humidity))
                DEBUG_PRINTLN("===================================");
                DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
              } else if (humidity != lastHum)
                lastHum = humidity;
                wait(DWELL_TIME);
                DEBUG_PRINT(F("Humidity is: "));
                DEBUG_PRINTLN(humidity);
          #ifdef LUX_ON
          void doLUX(void)
            unsigned int lux = lightSensor.readLightLevel();// Get Lux value
            DEBUG_PRINT(F("Current LUX Level: "));
            DEBUG_PRINTLN(lux);
            heartbeat++;
            if (lux != lastlux || heartbeat > 10)
              send(msg.set(lux));
              lastlux = lux;
            if (heartbeat > 10)
              heartbeat = 0;
          void bucketSensorTippedISR()
            unsigned long thisTipTime = millis();
            if (thisTipTime - lastTipTime > 100UL)
              rainBucket[0] += CALIBRATE_FACTOR; // adds CALIBRATE_FACTOR hundredths of unit each tip
              wasTippedBuffer++;
            lastTipTime = thisTipTime;
          int rainTotal(int hours)
            int total = 0;
            for ( int i = 0; i <= hours; i++)
              total += rainBucket [i];
            return total;
          #ifdef DEBUG_ON
          void updateSerialData(int x)
            DEBUG_PRINT(F("Rain last "));
            DEBUG_PRINT(x);
            DEBUG_PRINTLN(F(" hours: "));
            float tipCount = 0;
            for (int i = 0; i < x; i++)
              tipCount = tipCount + rainBucket [i];
            tipCount = tipCount / 100;
            DEBUG_PRINTLN(tipCount);
          void loadRainArray(int eValue) // retrieve stored rain array from EEPROM on powerup
            for (int i = 1; i < RAIN_BUCKET_SIZE; i++)
              eValue = eValue - 2;
              if (eValue < EEPROM_BUFFER_LOCATION)
                eValue = EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH;
              DEBUG_PRINT(F("EEPROM location: "));
              DEBUG_PRINTLN(eValue);
              uint8_t rainValueHigh = loadState(eValue);
              uint8_t rainValueLow = loadState(eValue + 1);
              unsigned int rainValue = rainValueHigh << 8;
              rainValue |= rainValueLow;
              rainBucket[i] = rainValue;
              DEBUG_PRINT(F("rainBucket[ value: "));
              DEBUG_PRINT(i);
              DEBUG_PRINT(F("] value: "));
              DEBUG_PRINTLN(rainBucket[i]);
          void transmitRainData(void)
            DEBUG_PRINT(F("In transmitRainData. currentHour = "));
            DEBUG_PRINTLN(currentHour);
            int rainUpdateTotal = 0;
            for (int i = currentHour; i >= 0; i--)
              rainUpdateTotal += rainBucket[i];
              DEBUG_PRINT(F("Adding rainBucket["));
              DEBUG_PRINT(i);
              DEBUG_PRINTLN(F("] to rainUpdateTotal."));
            DEBUG_PRINT(F("TX Day 1: rainUpdateTotal = "));
            DEBUG_PRINTLN((float)rainUpdateTotal / 100.0);
            send(msgRainVAR1.set((float)rainUpdateTotal / 100.0, 1)); //Send current day rain totals (resets at midnight)
            wait(DWELL_TIME);
          #ifdef USE_DAILY
            for (int i = currentHour + 24; i > currentHour; i--)
              DEBUG_PRINT(i);
            DEBUG_PRINT(F("TX Day 2: rainUpdateTotal = "));
            send(msgRainVAR2.set((float)rainUpdateTotal / 100.0, 1));
            wait(DWELL_TIME);
          #ifdef USE_DAILY
            for (int i = currentHour + 48; i > currentHour + 24; i--)
              DEBUG_PRINT(i);
            DEBUG_PRINT(F("TX Day 3: rainUpdateTotal = "));
            send(msgRainVAR3.set((float)rainUpdateTotal / 100.0, 1));
            wait(DWELL_TIME);
          #ifdef USE_DAILY
            for (int i = currentHour + 72; i > currentHour + 48; i--)
              DEBUG_PRINT(i);
            DEBUG_PRINT(F("TX Day 4: rainUpdateTotal = "));
            send(msgRainVAR4.set((float)rainUpdateTotal / 100.0, 1));
            wait(DWELL_TIME);
          #ifdef USE_DAILY
            for (int i = currentHour + 96; i > currentHour + 72; i--)
              DEBUG_PRINT(i);
            DEBUG_PRINT(F("TX Day 5: rainUpdateTotal = "));
            send(msgRainVAR5.set((float)rainUpdateTotal / 100.0, 1));
            wait(DWELL_TIME);
            if (message.sensor == CHILD_ID_RAIN_LOG)
              // nothing to do here
            else if (message.sensor == CHILD_ID_TRIPPED_INDICATOR)
              if (message.type == V_VAR1)
                rainWindow = atoi(message.data);
                if (rainWindow > 120)
                  rainWindow = 120;
                else if (rainWindow < 1)
                  rainWindow = 1;
                if (rainWindow != atoi(message.data))   // if I changed the value back inside the boundries, push that number back to Vera
                  send(msgTrippedVar1.set(rainWindow));
              else if (message.type == V_VAR2)
                rainSensorThreshold = atoi(message.data);
                if (rainSensorThreshold > 10000)
                  rainSensorThreshold = 10000;
                else if (rainSensorThreshold < 1)
                  rainSensorThreshold = 1;
                if (rainSensorThreshold != atoi(message.data))  // if I changed the value back inside the boundries, push that number back to Vera
                  send(msgTrippedVar2.set(rainSensorThreshold));
          void prettyFade(void)
            float val = (exp(sin(millis() / 2000.0 * PI)) - 0.36787944) * 108.0;
            analogWrite(ledPin, val);
          void slowFlash(void)
            static bool ledState = true;
            static unsigned long pulseStart = millis();
            if (millis() - pulseStart < 100UL)
              digitalWrite(ledPin, !ledState);
          void receiveTime(unsigned long newTime)
            DEBUG_PRINTLN(F("Time received..."));
            setTime(newTime);
            char theTime[6];
            sprintf(theTime, "%d:%2d", hour(), minute());
            DEBUG_PRINTLN(theTime);
          I have tried disabling different pieces of the code to see if something from one of the other sensors was causing it, but I cannot seem to find why this is happening.
          Just to note, if I run this test sketch, it works fine for the direction sensor:
          #include "AS5047.h"
          #include <EEPROM.h>
          #define SWITCH_PIN 7 //The north calibration switch
          AS5047 myAS5047(5); // SS pin
          int address = 0;      //EEPROM address counter
          int north_offset = 0;
          long value;
          int dir;
          bool button;
            Serial.begin(115200);
            pinMode(SWITCH_PIN, INPUT_PULLUP);
            north_offset = EEPROM.read(address);
            value=(360*myAS5047.sensor_read())/16383;
            dir = ((value - north_offset) < 0) ? 360 - abs(value - north_offset) : value - north_offset;
            Serial.print("measured direction: ");
            Serial.println(dir);
            Serial.print("north_offset: ");
            Serial.println(north_offset);
            button = digitalRead(SWITCH_PIN);
            if (!button && north_offset != value) {
              EEPROM.write(address, value);
              north_offset = value;
              Serial.println("Button pressed");
            delay(1000);
          I am hoping that someone notices something that I am not seeing.
          Thanks in advance.
          • dbemowskD
            dbemowskD
            I think I at least partially figured out the problem. As mentioned earlier, I may need to use transactions for this. Being that I have never used SPI, much less SPI transactions before, I have limited knowledge of how this works. My little understanding of what I have read about transactions, you call :
            SPI.beginTransaction( [SPI SETTINGS HERE] );
               {device SPI code} ...
            SPI.endTransaction();
            If I understand this, you can use SPI settings specific to a device with [SPI SETTINGS HERE] while leaving things alone for other devices, correct?
            So I started looking at the library for the AS5047P sensor and I see this line in the constructor:
            SPCR = (1<<SPE) | (1<<MSTR) | (1<<CPHA) | (1<<SPR1) | (1<<SPR0); // slow down clock speed, set up spi
            I am assuming that this defines the settings that I would need for the beginTransaction(). If so, how do I decipher this into the settings I need to include in the beginTransaction() call?
            What I did as a test is to move the above SPCR... line into the read_register function of the library like this:
            uint32_t AS5047::read_register(uint32_t thisRegister)
                    byte inByte = 0;   // incoming byte from the SPI
                    long result = 0;   // result to return
                    byte lowbyte = thisRegister & 0b0000000011111111;
                    byte highbyte = (thisRegister >> 8);
                    digitalWrite(_ss, LOW);
                    SPI.transfer(highbyte); // first byte in
                    result = SPI.transfer(lowbyte); // first byte out
                    digitalWrite(_ss, HIGH);
                    delayMicroseconds(10);
                    int bytesToRead = 2;
                    while (bytesToRead-- > 0) {
                            // shift the first byte left, then get the second byte:
                            result = result << 8;
                            inByte = SPI.transfer(0x00);
                            // combine the byte with the previous one:
                            result = result | inByte;
                    // take the chip select high to de-select:
                    result = result & 0b0011111111111111;
                    return(result);
            Now I appear to be getting correct wind direction data, but I feel that this is not the correct approach to doing it.
            Can anyone help?
            YveauxY 1 Reply Last reply
            • dbemowskD dbemowsk
                      return(result);
              Can anyone help?
              YveauxY
              YveauxY
              @dbemowsk you're right about the need for spi transactions on this one.
              The sensor's spi interface gets initialized in the constructor and is overwritten by the radio. I understand your 'fix' will work, as you reinitialize the SPI bus everytime, as the transactions do in a portable way.
              I have no time atm but I'll try to figure out the transaction settings when possible.
              • YveauxY Yveaux
                dbemowskD
                dbemowskD
                @Yveaux Thanks. I have been trying to research it in the mean time, buy as of yet have not figured out how to do it. If you know of any websites that explain how to do it, it would help.I try to figure things out on my own because then I understand them better.
                Thanks for all of the help you have given me on this.
                  YveauxY
                  YveauxY
                  #128
                  @dbemowsk Let's break that line down, using the ATmega328P datasheet (pg. 221,222):
                  • SPCR : SPI Control Register 0
                  • Bits not explicitly stated are 0, and can be read as (0<<xxx)
                  • (1<<SPE) : Enable SPI
                  • (0<<DORD) : Data order; here 0 to indicate MSB first
                  • (1<<MSTR) : Master/slave select; here 1 to indicate master
                  • (0<<CPOL): Clock polarity; here 0 to indicate SCK is low when idle
                  • (1<<CPHA) : Clock phase; here 1 to indicate sample on trailing edge
                  • (1<<SPR1) | (1<<SPR0) : Clock rate select; here 011 indicating Fosc/128
                  The SPISettings is used as follows:
                  SPISettings(clockrate, order, mode)
                  • Let's start with the easy one: clockrate.
                    The driver above uses Fosc/128, which is 16000000/128=125000 for a 16MHz crystal. This seems a safe value as the AS5047 datasheet states tclk=100ns, so it can handle 10MHz.
                  • Order is just the DORD parameter, so MSBFIRST.
                  • Then the tricky one: SPI_MODE
                    Here's an extensive explanation. It's a combination of clock phase and clock polarity. Luckily the datasheet states explicitly: "The AS5047D SPI uses mode=1 (CPOL=0, CPHA=1) to exchange data.", so use SPI_MODE1
                  Putting things together and wrapping SPI communication with transactions the result should be be:
                      SPI.beginTransaction( SPISettings(125000, MSBFIRST, SPI_MODE1) );
                  The clockrate can be increased if you like.
                  • YveauxY Yveaux
                    dbemowskD
                    dbemowskD
                    @Yveaux I cannot thank you enough. I tried these transaction settings and this worked perfectly. My hat is off to you.
                      YveauxY
                      YveauxY
                      @dbemowsk great to hear!
                      I hope I managed to explain to you how to get to these values, as you wanted to learn from the process :+1:
                      • YveauxY Yveaux
                        dbemowskD
                        dbemowskD
                        @Yveaux Yes, I did learn from that. Thanks again.
                        • nicofly974N
                          nicofly974N
                          nicofly974
                          Hello
                          A friend send me an old weather station in 868mhz, I want to hack it for using it in domoticz
                          Your project is similar as I want, where can I find your code?
                          Thank's
                          • nicofly974N nicofly974
                            Hello
                            Thank's
                            dbemowskD
                            dbemowskD
                            @nicofly974 Unfortunately I put this on hold for a while as I have been having a bit of trouble with my power option for the node. I am actually working on a solar power setup with a small charge controller and a 2x18650 battery pack. The solar panel setup will be on a servo controlled solar tracker that I will run from a separate pro mini. My two issues right now are that I am having some issues with the charge controller, possibly user error. The other issue is designing and 3D printing the parts that will hold the charge controller, battery pack and tracker. If this cheap charge controller is an issue and I have to get a different one, it may alter my design. Shipping on this controller took forever to come on the boat from China.
                            I haven't looked at my code for the sensors in a while, but maybe in the next day or two I'll post what I have with the understanding that it is in Alpha stage.
                              dbemowskD
                              dbemowskD
                              @dbemowsk Here are some pics of the dual axis solar tracker that I am working on for the weather station. In the 4 corners are the CDS photo cells for the tracker.
                              0_1510205656379_upload-a467911a-1ed7-4573-b114-e80d4e78e8d9
                              0_1510205719255_upload-221b7633-4eef-4788-8814-4bbbfbb0a7ee
                              0_1510205821046_upload-a7c4990e-8301-4d6b-940a-1700d9cb3942
                              0_1510205877977_upload-e592dcb5-e2ac-4dcd-a3af-f47b4120bb39
                              0_1510206015816_upload-f49898a9-d6c7-4c23-8575-dada20305400
                              gohanG 1 Reply Last reply
                                @dbemowsk is the solar tracker really necessary?
                                  dbemowskD
                                  dbemowskD
                                  @gohan Not sure, just thought it might be an addition that could maximize battery charging.
                                    it sure does, my question is if it is really needed. A lot depends on how much energy it uses :)
                                    • nicofly974N
                                      nicofly974N
                                      nicofly974
                                      For a project wtih a fablab, we have using a Li-Polymer Charge Management Controllers MCP73831
                                      You can have free "sample" for prototype if you ask directly to the factory, perhaps it could be faster.
