  3. RPI gateway (GPIO) - Segmentation fault
1 Posts 1 Posters 1.2k Views 1 Watching
  • B
    B
    bilbolodz
    wrote on last edited by bilbolodz
    I've playing with OTA using MYSController. I've noticed that sometime after OTA node upgrade or "reboot" command from MYSController node has problem with connecting to controller and finally gateway process on RPI got "Segmentation fault" and dies. Restarting gateway process won't fix it (still seg faults). Only way to get GW running is physical NODE reset.
    My hardware is: RPI3 and NRF24L01+PA, decent power supply, Mysensors 2.1.1 (git clone from https://github.com/mysensors/MySensors.git). Without "OTA"/reset GW is running stable. Any ideas? I've already opened issue on github.
    Logs from GW:
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG-SQ,VER=2.1.1
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: Listening for connections on 0.0.0.0:5003
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:FPAR REQ,ID=1
    mysgw: TSF:CKU:OK,FCTRL
    mysgw: TSF:MSG:GWL OK
    mysgw: !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    Segmentation fault
