  3. Node sending req packets constantly (Packet type 2 on MQTT)
reqmqtttype 2
16 Posts 3 Posters 5.1k Views 2 Watching
  • S
    Samuel235
    Would there be a reason for a node to repeatedly send a req type packet? I'm not sure if its a issue or if its normal behaviour but i can't see any sensor data on my gateway-in topic on my MQTT broker, just on the Gateway-out topic is a message of /16/1/2/0/24 which is a req packet. I will investigate my controller when i'm home and report back but would like to know if there is any issue with mysensors side of this?
    I'm only posting for future reference for others if they stumble across this issue themselves.
    • S Samuel235
      @Samuel235 - ok, so lets continue the discussion here instead of the other thread. What does your code looks like? Do you have some sort of function requesting the data until you got it?
      For future reference as well then:
      Here is my old thread (ver 1.6) about node re-requesting the v_var1: https://forum.mysensors.org/topic/2116/hard-to-grab-time-and-value-sent-from-controller
      The same behavior in 2.0 with this code.
        if (!pcReceived && (currentTime - lastSend > 5000)) {
            request(CHILD_ID, V_VAR1);
      #ifdef MY_DEBUG
          Serial.println("Req p-cnt");
            lastSend=currentTime;
            return;
      (Full code here for my Pulsecounter node)
      and as I said, i have not been able to pinpoint this due to repeaters and not made the effort to do so. Sooner or later the value requested is found its way to the node and once thats done its not a problem for me since you do it once at startup.
      The node tries to request the v_var1 and I see the reqeust in the GW log. Then the error led blinks and the request-answer never reaches the node. I have tried different spaces between gw-node and that does not matter.
      S 1 Reply Last reply
      • sundberg84S sundberg84
        #ifdef MY_DEBUG
              return;
        Samuel235
        This post is deleted!
        • S
          Samuel235
          Firstly, you mentioned that you get a Error LED light on your gateway, i do not, instead i get a send and receive light simultaneously. I'm not sure if we're both facing seperate issues fundamentally but i think at heart, its because of the same issue (if that makes sense). You're getting a different output to the same error i think, is what i meant.
          Now, my node NEVER gets what its after, its been running for 12 hours and its still sending the REQ message.
          My code is the example code with a manual ID and changed LED blink value:
           * Version 1.0 - Henrik EKblad
           * This sketch provides an example how to implement a distance sensor using HC-SR04
           * Use this sensor to measure KWH and Watt of your house meeter
           * You need to set the correct pulsefactor of your meeter (blinks per KWH).
           * The sensor starts by fetching current KWH value from gateway.
           * Reports both KWH and Watt back to gateway.
           * Unfortunately millis() won't increment when the Arduino is in
           * sleepmode. So we cannot make this sensor sleep if we also want
           * to calculate/report watt-number.
           * http://www.mysensors.org/build/pulse_power
          // Enable debug prints
          // Assign NODE ID
          #define MY_NODE_ID 16
          #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
          #define PULSE_FACTOR 3200       // Nummber of blinks per KWH of your meeter
          #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
          #define MAX_WATT 10000          // Max watt value to report. This filetrs outliers.
          #define CHILD_ID 1              // Id of the sensor child
          unsigned long SEND_FREQUENCY =
              10000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
          double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
          bool pcReceived = false;
          volatile unsigned long watt = 0;
          unsigned long oldWatt = 0;
          double oldKwh;
          unsigned long lastSend;
          MyMessage wattMsg(CHILD_ID,V_WATT);
          MyMessage kwhMsg(CHILD_ID,V_KWH);
              // Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
              // If no pullup is used, the reported usage will be too high because of the floating pin
              pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
              attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
              lastSend=millis();
              sendSketchInfo("Energy Meter", "1.0");
              present(CHILD_ID, S_POWER);
              unsigned long now = millis();
              bool sendTime = now - lastSend > SEND_FREQUENCY;
              if (pcReceived && (SLEEP_MODE || sendTime)) {
                  // New watt value has been calculated
                  if (!SLEEP_MODE && watt != oldWatt) {
                      // Check that we dont get unresonable large watt value.
                      // could hapen when long wraps or false interrupt triggered
                      if (watt<((unsigned long)MAX_WATT)) {
                          send(wattMsg.set(watt));  // Send watt value to gw
                      Serial.print("Watt:");
                      Serial.println(watt);
                      oldWatt = watt;
                  // Pulse cout has changed
                  if (pulseCount != oldPulseCount) {
                      send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                      double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                      oldPulseCount = pulseCount;
                      if (kwh != oldKwh) {
                          send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                          oldKwh = kwh;
                  lastSend = now;
              } else if (sendTime && !pcReceived) {
                  // No count received. Try requesting it again
                  lastSend=now;
              if (SLEEP_MODE) {
                  sleep(SEND_FREQUENCY);
              if (message.type==V_VAR1) {
                  Serial.println(pulseCount);
                  pcReceived = true;
          void onPulse()
              if (!SLEEP_MODE) {
                  unsigned long interval = newBlink-lastBlink;
                  if (interval<10000L) { // Sometimes we get interrupt on RISING
                      return;
                  watt = (3600000000.0 /interval) / ppwh;
                  lastBlink = newBlink;
              pulseCount++;
          I can't seem to remember what controller you use, is it domonicz or openhab by any chance?
          I'm still attempting to get my head around what is actually happening here.
          • I'm getting a 6724899 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: which is showing the node is sending a request message.
          • I'm then getting what seems to be a blank message on the MQTT topic of Gateway1-out/16/1/2/0/24 which shows to me that it doesn't have a value stored for this request and the gateway is actually publishing that message. (So i think that the gateway is doing exactly as its being asked too.)
          • S Samuel235
            // Assign NODE ID
            double oldKwh;
                lastSend=millis();
                        oldWatt = watt;
                            oldKwh = kwh;
                    lastSend = now;
                    lastSend=now;
                if (SLEEP_MODE) {
                    pcReceived = true;
            void onPulse()
                if (!SLEEP_MODE) {
                        return;
                pulseCount++;
            @Samuel235 - I use Domoticz on a EthernetGW.
            Yes, maybe its different.
            • I do have a stored value, but Domoticz logs does not show me anything. In gw log I see the value is beeing sent.
            • Just as you, both send and recieve led is beeing lit for a second and then i get the error led after < 0.5sec maybe but not simultaneous.
            • We use the same code (request, if not recieved, request again).
            • Sometimes I have had this run for 12 hours as well, and I have moved the node and restarted it which helped.
            Do you have a repeater?
            We should collect some logs simulatanoius from:
            -Node
            -Gw
            -Controller
            -Repeater
              -Node
              -Gw
              -Controller
              -Repeater
              Samuel235
              @sundberg84 I have just found your website linked on your profile, so i realised that domoticz is what you run, may i ask how you find their dashboard? The only reason i like openhab is the dashboard feel, the setup is a little ass about backwards as i would call it and would be tempted to try domonicz (maybe this would solve my issue, very much doubt it though).
              I will grab my log from the gateway and controller (if openhab shows any issues in the log for this problem that is).
              I have no repeater, its just a node connecting directly to the gateway.
              My node is literally setting itself up, presenting itself to the gateway and sending a request message:
              3 TSM:INIT
              4 TSF:WUR:MS=0
              11 TSM:INIT:TSP OK
              13 TSM:INIT:STATID=16
              15 TSF:SID:OK,ID=16
              17 TSM:FPAR
              53 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              438 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              443 TSF:MSG:FPAR OK,ID=0,D=1
              513 TSF:MSG:READ,4-4-16,s=255,c=3,t=8,pt=1,l=1,sg=0:1
              2060 TSM:FPAR:OK
              2061 TSM:ID
              2062 TSM:ID:OK
              2064 TSM:UPL
              2067 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2077 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2082 TSF:MSG:PONG RECV,HP=1
              2085 TSM:UPL:OK
              2086 TSM:READY:ID=16,PAR=0,DIS=1
              2092 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2099 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              2106 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
              2115 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              4123 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:Energy Meter
              4132 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
              4141 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
              4147 MCO:REG:REQ
              4151 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              4169 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              4174 MCO:PIM:NODE REG=1
              4177 MCO:BGN:STP
              4180 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
              4187 MCO:BGN:INIT OK,TSP=1
              14189 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
              • S Samuel235
                3 TSM:INIT
                4 TSF:WUR:MS=0
                11 TSM:INIT:TSP OK
                15 TSF:SID:OK,ID=16
                17 TSM:FPAR
                2060 TSM:FPAR:OK
                2061 TSM:ID
                2062 TSM:ID:OK
                2064 TSM:UPL
                2085 TSM:UPL:OK
                4147 MCO:REG:REQ
                4177 MCO:BGN:STP
                @Samuel235 - My logs from the node:
                Not working:
                0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                4 TSM:INIT
                4 TSF:WUR:MS=0
                12 TSM:INIT:TSP OK
                14 TSM:INIT:STATID=8
                16 TSF:SID:OK,ID=8
                18 TSM:FPAR
                55 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2062 !TSM:FPAR:NO REPLY
                2064 TSM:FPAR
                2101 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2738 TSF:MSG:READ,100-100-8,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                2744 TSF:MSG:FPAR OK,ID=100,D=2
                4110 TSM:FPAR:OK
                4110 TSM:ID
                4112 TSM:ID:OK
                4114 TSM:UPL
                4122 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                6131 TSM:UPL
                6135 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                8146 TSM:UPL
                8148 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                10158 TSM:UPL
                10166 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                12175 !TSM:UPL:FAIL
                12177 TSM:FPAR
                12214 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                14221 !TSM:FPAR:NO REPLY
                14223 TSM:FPAR
                14260 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                16269 !TSM:FPAR:NO REPLY
                16271 TSM:FPAR
                16308 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                18317 !TSM:FPAR:NO REPLY
                18319 TSM:FPAR
                18356 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                20365 !TSM:FPAR:FAIL
                20367 TSM:FAIL:CNT=1
                20369 TSM:FAIL:PDT
                30373 TSM:FAIL:RE-INIT
                30375 TSM:INIT
                30384 TSM:INIT:TSP OK
                30386 TSM:INIT:STATID=8
                30388 TSF:SID:OK,ID=8
                30390 TSM:FPAR
                30427 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                31139 TSF:MSG:READ,100-100-8,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                31148 TSF:MSG:FPAR OK,ID=100,D=2
                32436 TSM:FPAR:OK
                32438 TSM:ID
                32438 TSM:ID:OK
                32440 TSM:UPL
                32444 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                34453 TSM:UPL
                34457 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                36466 TSM:UPL
                36468 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                36501 TSF:MSG:READ,0-100-8,s=255,c=3,t=25,pt=1,l=1,sg=0:2
                36507 TSF:MSG:PONG RECV,HP=2
                36509 TSM:UPL:OK
                36511 TSM:READY:ID=8,PAR=100,DIS=2
                36517 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                38531 TSF:MSG:SEND,8-8-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                38545 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:100
                40597 !TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=NACK:Energy Meter #8
                40607 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=OK:1.4
                40617 TSF:MSG:SEND,8-8-100-0,s=1,c=0,t=10,pt=0,l=0,sg=0,ft=0,st=OK:
                40626 MCO:REG:REQ
                40642 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                42655 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                44662 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                46684 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                48693 MCO:BGN:STP
                49197 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                49203 MCO:BGN:INIT OK,TSP=1
                54216 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                59217 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                64219 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                69208 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                74211 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                79210 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                84224 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                89214 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                94214 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                99215 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                104216 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                ... Continues
                Working:
                4 TSM:INIT
                4 TSF:WUR:MS=0
                12 TSM:INIT:TSP OK
                16 TSF:SID:OK,ID=8
                18 TSM:FPAR
                1013 TSF:MSG:READ,0-0-8,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                1019 TSF:MSG:FPAR OK,ID=0,D=1
                1212 TSF:MSG:READ,99-99-8,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                1630 TSF:MSG:READ,100-100-8,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                2062 TSM:FPAR:OK
                2062 TSM:ID
                2064 TSM:ID:OK
                2066 TSM:UPL
                2103 !TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                4112 TSM:UPL
                4122 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=OK:1
                4141 TSF:MSG:READ,0-0-8,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                4147 TSF:MSG:PONG RECV,HP=1
                4149 TSM:UPL:OK
                4151 TSM:READY:ID=8,PAR=0,DIS=1
                4190 !TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                4198 TSF:MSG:READ,0-0-8,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                4206 TSF:MSG:SEND,8-8-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=OK:2.1.0
                4218 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                5181 TSF:MSG:READ,0-0-8,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                5193 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=OK:Energy Meter #8
                5208 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.4
                5234 TSF:MSG:SEND,8-8-0-0,s=1,c=0,t=10,pt=0,l=0,sg=0,ft=0,st=OK:
                5242 MCO:REG:REQ
                5249 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                5277 TSF:MSG:READ,0-0-8,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                5283 MCO:PIM:NODE REG=1
                5285 MCO:BGN:STP
                5795 TSF:MSG:SEND,8-8-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                5804 MCO:BGN:INIT OK,TSP=1
                10819 TSF:MSG:SEND,8-8-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                11212 TSF:MSG:READ,0-0-8,s=1,c=2,t=24,pt=0,l=8,sg=0:21911518
                Received last pulse count from gw:21911518
                11220 MCO:SLP:MS=780000,SMS=0,I1=255,M1=255,I2=255,M2=255
                11229 MCO:SLP:TPD
                As seen in the first logs the node is also struggling with finding its parent (No reply) so my guess so far (as always) is the radio. But what bothers me is that the first logs uses a repeater and it doesnt work (because of that?)
                But we need simultanoius logs from GW and node atleast (and repeater in my case).
                  Not working:
                  4 TSM:INIT
                  4 TSF:WUR:MS=0
                  12 TSM:INIT:TSP OK
                  16 TSF:SID:OK,ID=8
                  18 TSM:FPAR
                  2064 TSM:FPAR
                  4110 TSM:FPAR:OK
                  4110 TSM:ID
                  4112 TSM:ID:OK
                  4114 TSM:UPL
                  6131 TSM:UPL
                  8146 TSM:UPL
                  10158 TSM:UPL
                  12175 !TSM:UPL:FAIL
                  12177 TSM:FPAR
                  14223 TSM:FPAR
                  16271 TSM:FPAR
                  18319 TSM:FPAR
                  20369 TSM:FAIL:PDT
                  30375 TSM:INIT
                  30390 TSM:FPAR
                  32436 TSM:FPAR:OK
                  32438 TSM:ID
                  32438 TSM:ID:OK
                  32440 TSM:UPL
                  34453 TSM:UPL
                  36466 TSM:UPL
                  36509 TSM:UPL:OK
                  40626 MCO:REG:REQ
                  48693 MCO:BGN:STP
                  ... Continues
                  Working:
                  4 TSM:INIT
                  4 TSF:WUR:MS=0
                  12 TSM:INIT:TSP OK
                  16 TSF:SID:OK,ID=8
                  18 TSM:FPAR
                  2062 TSM:FPAR:OK
                  2062 TSM:ID
                  2064 TSM:ID:OK
                  2066 TSM:UPL
                  4112 TSM:UPL
                  4149 TSM:UPL:OK
                  5242 MCO:REG:REQ
                  5285 MCO:BGN:STP
                  11229 MCO:SLP:TPD
                  Samuel235
                  @sundberg84 - I have a fix for mine.
                  My issue was simply that it was asking for a value that wasn't there. If i manually put the value on the mqtt topic, then the node starts working beautifully (from what i can see).
                  I, however, doubt that is your case though as its working without the repeater. I now need to solve the reason why the value is not 0 if there has been no input, instead its just empty. I will take a look into how OpenHAB needs to define a 0 by default.
                  I will attempt to help your issue though still if you want me too, not sure how much help i can be though....
                  • S
                    Samuel235
                    I will report back with my solution for the OpenHAB value fix soon as i find out.
                    • S Samuel235
                      @Samuel235 - it's most likely my radio with range/power issues but the node communication works 100% except for this... i will continue investigate.
                      • S
                        Samuel235
                        If you turn the node off and then grab the serial output from all 3 (GW, Repeater and Node) while you power the node up and then drop them in here, i will be a second pair of eyes for you :)
                        • S Samuel235
                          @Samuel235 - that has been my main problem - how to grab serial output for three nodes at different locations at the same time :) but thank you! I appreciate it and will do as soon as i have it.
                          S gohanG 2 Replies Last reply
                            Samuel235
                            @sundberg84 - TBH, i would be tempted to do it in two phases, not as accurate but should be good enough.
                            If you have a laptop and a desktop, i would have the gateway connected to one and the node connected to the other and then restart the node (leaving the gateway up) and then change the device the node is connected to and put it on the repeated and then restart the node. As we don't need to restart the gateway or the repeater really, just the node.
                            Does that make any sense?
                              @sundberg84 said in Node sending req packets constantly (Packet type 2 on MQTT):
                              I guess this is where esp8266 come in handy with their remote debug :)
                              • S
                                Samuel235
                                I'm still getting my issue, everytime i restart the node i must manually send a "0" on Gateway1-in/16/1/1/0/24. I've even attempted to have this as an item so persistence holds the value and that isn't working either....
                                • S
                                  Samuel235
                                  I have posted a question regarding what i think could be the fix to my issue over at: https://community.openhab.org/t/push-state-of-one-mqtt-topic-to-another/27597
                                  Not sure if it will become of anything though. If anyone else has any experience with MQTT and openhab2 over here, then please be sure to shout a thought. It seems that not many people have got this sketch to work with openhab, google searches are bringing up posts from a year or two ago made on our forum here regarding this issue with no clear/simple solution.
