  3. Node sending req packets constantly (Packet type 2 on MQTT)
reqmqtttype 2
16 Posts 3 Posters 5.1k Views 2 Watching
  • sundberg84S sundberg84
    @Samuel235 - I use Domoticz on a EthernetGW.
    Yes, maybe its different.
    • I do have a stored value, but Domoticz logs does not show me anything. In gw log I see the value is beeing sent.
    • Just as you, both send and recieve led is beeing lit for a second and then i get the error led after < 0.5sec maybe but not simultaneous.
    • We use the same code (request, if not recieved, request again).
    • Sometimes I have had this run for 12 hours as well, and I have moved the node and restarted it which helped.
    Do you have a repeater?
    We should collect some logs simulatanoius from:
    -Node
    -Gw
    -Controller
    -Repeater
    Samuel235
    @sundberg84 I have just found your website linked on your profile, so i realised that domoticz is what you run, may i ask how you find their dashboard? The only reason i like openhab is the dashboard feel, the setup is a little ass about backwards as i would call it and would be tempted to try domonicz (maybe this would solve my issue, very much doubt it though).
    I will grab my log from the gateway and controller (if openhab shows any issues in the log for this problem that is).
    I have no repeater, its just a node connecting directly to the gateway.
    My node is literally setting itself up, presenting itself to the gateway and sending a request message:
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:STATID=16
    15 TSF:SID:OK,ID=16
    17 TSM:FPAR
    53 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    438 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    443 TSF:MSG:FPAR OK,ID=0,D=1
    513 TSF:MSG:READ,4-4-16,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    2060 TSM:FPAR:OK
    2061 TSM:ID
    2062 TSM:ID:OK
    2064 TSM:UPL
    2067 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2077 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2082 TSF:MSG:PONG RECV,HP=1
    2085 TSM:UPL:OK
    2086 TSM:READY:ID=16,PAR=0,DIS=1
    2092 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2099 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2106 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    2115 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4123 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:Energy Meter
    4132 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    4141 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
    4147 MCO:REG:REQ
    4151 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    4169 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    4174 MCO:PIM:NODE REG=1
    4177 MCO:BGN:STP
    4180 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    4187 MCO:BGN:INIT OK,TSP=1
    14189 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    MySensors 2.1.1
    • S Samuel235
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      15 TSF:SID:OK,ID=16
      17 TSM:FPAR
      2060 TSM:FPAR:OK
      2061 TSM:ID
      2062 TSM:ID:OK
      2064 TSM:UPL
      2085 TSM:UPL:OK
      4147 MCO:REG:REQ
      4177 MCO:BGN:STP
      sundberg84S
      sundberg84S
      @Samuel235 - My logs from the node:
      Not working:
      0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
      4 TSM:INIT
      4 TSF:WUR:MS=0
      12 TSM:INIT:TSP OK
      14 TSM:INIT:STATID=8
      16 TSF:SID:OK,ID=8
      18 TSM:FPAR
      55 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2062 !TSM:FPAR:NO REPLY
      2064 TSM:FPAR
      2101 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2738 TSF:MSG:READ,100-100-8,s=255,c=3,t=8,pt=1,l=1,sg=0:1
      2744 TSF:MSG:FPAR OK,ID=100,D=2
      4110 TSM:FPAR:OK
      4110 TSM:ID
      4112 TSM:ID:OK
      4114 TSM:UPL
      4122 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      6131 TSM:UPL
      6135 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      8146 TSM:UPL
      8148 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      10158 TSM:UPL
      10166 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      12175 !TSM:UPL:FAIL
      12177 TSM:FPAR
      12214 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      14221 !TSM:FPAR:NO REPLY
      14223 TSM:FPAR
      14260 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      16269 !TSM:FPAR:NO REPLY
      16271 TSM:FPAR
      16308 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      18317 !TSM:FPAR:NO REPLY
      18319 TSM:FPAR
      18356 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      20365 !TSM:FPAR:FAIL
      20367 TSM:FAIL:CNT=1
      20369 TSM:FAIL:PDT
      30373 TSM:FAIL:RE-INIT
      30375 TSM:INIT
      30384 TSM:INIT:TSP OK
      30386 TSM:INIT:STATID=8
      30388 TSF:SID:OK,ID=8
      30390 TSM:FPAR
      30427 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      31139 TSF:MSG:READ,100-100-8,s=255,c=3,t=8,pt=1,l=1,sg=0:1
      31148 TSF:MSG:FPAR OK,ID=100,D=2
      32436 TSM:FPAR:OK
      32438 TSM:ID
      32438 TSM:ID:OK
      32440 TSM:UPL
      32444 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      34453 TSM:UPL
      34457 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      36466 TSM:UPL
      36468 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      36501 TSF:MSG:READ,0-100-8,s=255,c=3,t=25,pt=1,l=1,sg=0:2
      36507 TSF:MSG:PONG RECV,HP=2
      36509 TSM:UPL:OK
      36511 TSM:READY:ID=8,PAR=100,DIS=2
      36517 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
      38531 TSF:MSG:SEND,8-8-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
      38545 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:100
      40597 !TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=NACK:Energy Meter #8
      40607 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=OK:1.4
      40617 TSF:MSG:SEND,8-8-100-0,s=1,c=0,t=10,pt=0,l=0,sg=0,ft=0,st=OK:
      40626 MCO:REG:REQ
      40642 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
      42655 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
      44662 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
      46684 TSF:MSG:SEND,8-8-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
      48693 MCO:BGN:STP
      49197 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      49203 MCO:BGN:INIT OK,TSP=1
      54216 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      59217 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      64219 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      69208 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      74211 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      79210 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      84224 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      89214 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      94214 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      99215 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      104216 TSF:MSG:SEND,8-8-100-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      ... Continues
      Working:
      4 TSM:INIT
      4 TSF:WUR:MS=0
      12 TSM:INIT:TSP OK
      16 TSF:SID:OK,ID=8
      18 TSM:FPAR
      1013 TSF:MSG:READ,0-0-8,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      1019 TSF:MSG:FPAR OK,ID=0,D=1
      1212 TSF:MSG:READ,99-99-8,s=255,c=3,t=8,pt=1,l=1,sg=0:1
      1630 TSF:MSG:READ,100-100-8,s=255,c=3,t=8,pt=1,l=1,sg=0:1
      2062 TSM:FPAR:OK
      2062 TSM:ID
      2064 TSM:ID:OK
      2066 TSM:UPL
      2103 !TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
      4112 TSM:UPL
      4122 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=OK:1
      4141 TSF:MSG:READ,0-0-8,s=255,c=3,t=25,pt=1,l=1,sg=0:1
      4147 TSF:MSG:PONG RECV,HP=1
      4149 TSM:UPL:OK
      4151 TSM:READY:ID=8,PAR=0,DIS=1
      4190 !TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
      4198 TSF:MSG:READ,0-0-8,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      4206 TSF:MSG:SEND,8-8-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=OK:2.1.0
      4218 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
      5181 TSF:MSG:READ,0-0-8,s=255,c=3,t=6,pt=0,l=1,sg=0:M
      5193 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=OK:Energy Meter #8
      5208 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.4
      5234 TSF:MSG:SEND,8-8-0-0,s=1,c=0,t=10,pt=0,l=0,sg=0,ft=0,st=OK:
      5242 MCO:REG:REQ
      5249 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
      5277 TSF:MSG:READ,0-0-8,s=255,c=3,t=27,pt=1,l=1,sg=0:1
      5283 MCO:PIM:NODE REG=1
      5285 MCO:BGN:STP
      5795 TSF:MSG:SEND,8-8-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      5804 MCO:BGN:INIT OK,TSP=1
      10819 TSF:MSG:SEND,8-8-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
      11212 TSF:MSG:READ,0-0-8,s=1,c=2,t=24,pt=0,l=8,sg=0:21911518
      Received last pulse count from gw:21911518
      11220 MCO:SLP:MS=780000,SMS=0,I1=255,M1=255,I2=255,M2=255
      11229 MCO:SLP:TPD
      As seen in the first logs the node is also struggling with finding its parent (No reply) so my guess so far (as always) is the radio. But what bothers me is that the first logs uses a repeater and it doesnt work (because of that?)
      But we need simultanoius logs from GW and node atleast (and repeater in my case).
      S 1 Reply Last reply
        Not working:
        4 TSM:INIT
        4 TSF:WUR:MS=0
        12 TSM:INIT:TSP OK
        16 TSF:SID:OK,ID=8
        18 TSM:FPAR
        2064 TSM:FPAR
        4110 TSM:FPAR:OK
        4110 TSM:ID
        4112 TSM:ID:OK
        4114 TSM:UPL
        6131 TSM:UPL
        8146 TSM:UPL
        10158 TSM:UPL
        12175 !TSM:UPL:FAIL
        12177 TSM:FPAR
        14223 TSM:FPAR
        16271 TSM:FPAR
        18319 TSM:FPAR
        20369 TSM:FAIL:PDT
        30375 TSM:INIT
        30390 TSM:FPAR
        32436 TSM:FPAR:OK
        32438 TSM:ID
        32438 TSM:ID:OK
        32440 TSM:UPL
        34453 TSM:UPL
        36466 TSM:UPL
        36509 TSM:UPL:OK
        40626 MCO:REG:REQ
        48693 MCO:BGN:STP
        ... Continues
        Working:
        4 TSM:INIT
        4 TSF:WUR:MS=0
        12 TSM:INIT:TSP OK
        16 TSF:SID:OK,ID=8
        18 TSM:FPAR
        2062 TSM:FPAR:OK
        2062 TSM:ID
        2064 TSM:ID:OK
        2066 TSM:UPL
        4112 TSM:UPL
        4149 TSM:UPL:OK
        5242 MCO:REG:REQ
        5285 MCO:BGN:STP
        11229 MCO:SLP:TPD
        Samuel235
        @sundberg84 - I have a fix for mine.
        My issue was simply that it was asking for a value that wasn't there. If i manually put the value on the mqtt topic, then the node starts working beautifully (from what i can see).
        I, however, doubt that is your case though as its working without the repeater. I now need to solve the reason why the value is not 0 if there has been no input, instead its just empty. I will take a look into how OpenHAB needs to define a 0 by default.
        I will attempt to help your issue though still if you want me too, not sure how much help i can be though....
        MySensors 2.1.1
          Samuel235
          I will report back with my solution for the OpenHAB value fix soon as i find out.
          MySensors 2.1.1
          • S Samuel235
            sundberg84S
            sundberg84S
            @Samuel235 - it's most likely my radio with range/power issues but the node communication works 100% except for this... i will continue investigate.
              Samuel235
              If you turn the node off and then grab the serial output from all 3 (GW, Repeater and Node) while you power the node up and then drop them in here, i will be a second pair of eyes for you :)
              MySensors 2.1.1
              • S Samuel235
                sundberg84S
                sundberg84S
                @Samuel235 - that has been my main problem - how to grab serial output for three nodes at different locations at the same time :) but thank you! I appreciate it and will do as soon as i have it.
                S gohanG 2 Replies Last reply
                  Samuel235
                  @sundberg84 - TBH, i would be tempted to do it in two phases, not as accurate but should be good enough.
                  If you have a laptop and a desktop, i would have the gateway connected to one and the node connected to the other and then restart the node (leaving the gateway up) and then change the device the node is connected to and put it on the repeated and then restart the node. As we don't need to restart the gateway or the repeater really, just the node.
                  Does that make any sense?
                  MySensors 2.1.1
                    @sundberg84 said in Node sending req packets constantly (Packet type 2 on MQTT):
                    I guess this is where esp8266 come in handy with their remote debug :)
                      Samuel235
                      I'm still getting my issue, everytime i restart the node i must manually send a "0" on Gateway1-in/16/1/1/0/24. I've even attempted to have this as an item so persistence holds the value and that isn't working either....
                      MySensors 2.1.1
                        Samuel235
                        I have posted a question regarding what i think could be the fix to my issue over at: https://community.openhab.org/t/push-state-of-one-mqtt-topic-to-another/27597
                        Not sure if it will become of anything though. If anyone else has any experience with MQTT and openhab2 over here, then please be sure to shout a thought. It seems that not many people have got this sketch to work with openhab, google searches are bringing up posts from a year or two ago made on our forum here regarding this issue with no clear/simple solution.
                        MySensors 2.1.1
