  3. Troubleshooting sketch
4 Posts 3 Posters 1.4k Views 3 Watching
  • Cliff KarlssonC Offline
    Cliff Karlsson
    I am trying to use two ultrasonic-sensors and one PIR with this sketch but I get this error:
    PIR_dual_ultrasonic_sensor:49: error: 'getConfig' was not declared in this scope
       metric = getConfig().isMetric;
    exit status 1
    Can anyone tell me what I am doing wrong?
    // Enable debug prints
    #define MY_BAUD_RATE 115200
    #include <NewPing.h>
    #define SONAR_A_CHILD_ID 1
    #define SONAR_B_CHILD_ID 2
    #define MOTION_A_CHILD_ID 3
    #define SONAR_A_TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define SONAR_A_ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MOTION_A_TRIGGER_PIN  2
    #define SONAR_B_TRIGGER_PIN  8  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define SONAR_B_ECHO_PIN     7  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    unsigned long SLEEP_TIME = 200; // Sleep time between reads (in milliseconds)
    unsigned long MOTION_SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    #define INTERRUPT MOTION_A_TRIGGER_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    NewPing sonar_A(SONAR_A_TRIGGER_PIN, SONAR_A_ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    NewPing sonar_B(SONAR_B_TRIGGER_PIN, SONAR_B_ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    MyMessage SONAR_A_msg(SONAR_A_CHILD_ID, V_DISTANCE);
    int SONAR_A_lastDist;
    MyMessage SONAR_B_msg(SONAR_B_CHILD_ID, V_DISTANCE);
    int SONAR_B_lastDist;
    MyMessage MOTION_A_msg(MOTION_A_CHILD_ID, V_TRIPPED);
    boolean metric = true;
      pinMode(MOTION_A_TRIGGER_PIN, INPUT);      // sets the motion sensor digital pin as input
    void presentation() {
      sendSketchInfo("Distance+Motion Sensor", "1.0");
      present(SONAR_A_CHILD_ID, S_DISTANCE);
      present(SONAR_B_CHILD_ID, S_DISTANCE);
      present(MOTION_A_TRIGGER_PIN, S_MOTION);
      boolean tripped = digitalRead(MOTION_A_TRIGGER_PIN) == HIGH;
      Serial.println(tripped);
      send(MOTION_A_msg.set(tripped?"1":"0"));  // Send tripped value to gw
     if(tripped)  {
      unsigned long time = millis()+30000;
      while (millis() < time){
          int SONAR_A_dist = metric?sonar_A.ping_cm():sonar_A.ping_in();
          Serial.print("Ping Sonar A: ");
          Serial.print(SONAR_A_dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
          Serial.println(metric?" cm":" in");
      if (SONAR_A_dist != SONAR_A_lastDist) {
          send(SONAR_A_msg.set(SONAR_A_dist));
          SONAR_A_lastDist = SONAR_A_dist;
      wait(100);
          int SONAR_B_dist = metric?sonar_B.ping_cm():sonar_B.ping_in();
          Serial.print("Ping Sonar B: ");
          Serial.print(SONAR_B_dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      if (SONAR_B_dist != SONAR_B_lastDist) {
          send(SONAR_B_msg.set(SONAR_B_dist));
          SONAR_B_lastDist = SONAR_B_dist;
      sleep(SLEEP_TIME);
    //else{
      sleep(INTERRUPT,CHANGE, MOTION_SLEEP_TIME);
      exit status 1
       if(tripped)  {
        wait(100);
        sleep(SLEEP_TIME);
      //else{
      mfalkviddM Online
      mfalkviddM Online
      @Cliff-Karlsson
      https://forum.mysensors.org/topic/5841/getconfig-was-not-declared-in-this-scope-v2-1-1-fixed/
      https://forum.mysensors.org/post/57843
      https://forum.mysensors.org/post/58390
      https://forum.mysensors.org/post/58182
      https://forum.mysensors.org/post/57669
      https://forum.mysensors.org/post/58305
      https://forum.mysensors.org/post/58880
      You would have gotten a faster answer by searching
      gohanG 1 Reply Last reply
        @Cliff-Karlsson
        @mfalkvidd it is a deleted post
          mfalkviddM Online
          mfalkviddM Online
          @gohan which one?
