  3. Connecting grid-eye sensor
3 Posts 2 Posters 2.7k Views 2 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I accidently ordered the wrong kind of sensor and got Grid-eye one wire instead of Grid-eye usb. The one I got have two RJ11-connectors and from what I understand uses onewire for communication. alt text
    Schematic
    Datasheet
    I tried to understand the schematic to determine if I could use the TPx connectors at the top to connect and found that TP6 is 1-wire out and TP1 looks like GND, but I do not understand where VCC should go.
    So my questions is
    1: can I connect it to arduino using onewire and the TPx connections, and how would I connect it in that case.
    2: Can I use a FTDI-adapter in some way to be able to connect it to a PC to use the windows-demo-software?
    It looks like you're supposed to use some kind of additional hardware or shield between the sensor and the arduino but is there some way to connect it directly?
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      I managed to connect the sensor using the SDA and SCL and found some example code. I have only connected SDA,SCL, GND, and VCC. There where some more pins mentioned in the info but I guess they where not needed.
      I tried some software and it showed all temeratures correctly in a graphical gui but when I tried the arduino code the serial monitor wass willed with "garbage" even tho I used the the specified baudrate in the serial monitor.
      But I clearly see that the serial monitor reacts to my hand and other warm objects. Can I change anything in the code to have a clearer output?
      #include <Wire.h>       /*** including the Wire libary needed for the I2C communication ***/
      #include <Arduino.h>    /*** including the standard Arduino libary ***/
      #define AD_SELECT 19    /*** Define the address select pin ***/
      #define INT 18          /*** Define the interrupt pin ***/
      #define Hz10  85        /*** Define the delay time [ms] for the 10Hz mode ***/
      #define Hz1   985       /*** Define the delay time [ms] for the 1Hz mode ***/
      #define ADDR  0x68      /*** Define the I2C address for the Grid-EYE ***/
        /*** join the I2C bus as master ***/
        Wire.begin();
        /*** start the serial Communication with 57600 Bauts ***/
        Serial.begin(57600);
        /*** Set the address pin as an output and set the Grid-EYE ***/
        /*** Slave address to 0x68 (0110 1000) ***/
        pinMode(AD_SELECT, OUTPUT);
        digitalWrite(AD_SELECT,LOW);
        /*** Set interrupt pin as an input pin ***/
        pinMode(INT, INPUT);
        /*** Variable declaration ***/
        byte pixelAddL;
        byte lowerLevel[64];
        byte upperLevel[64];
        byte lowerLevelTherm;
        byte upperLevelTherm;
        short Maindelay = Hz10;
        while(1)
          /*** read out the Thermister tremperature ***/
          Wire.beginTransmission(ADDR);
          Wire.write(0x0E);
          Wire.endTransmission();
          Wire.requestFrom(ADDR, 2);
          lowerLevelTherm = Wire.read();
          upperLevelTherm = Wire.read();
          /*** set pixel address on the first Pixel (low) address ***/
          pixelAddL = 0x80;
          /*** read out the temperature of all 64 Pixel ***/
          for (int pixel = 0; pixel < 64; pixel++)
            Wire.write(pixelAddL);
            lowerLevel[pixel] = Wire.read();
            upperLevel[pixel] = Wire.read();
            pixelAddL = pixelAddL + 2;
          /*** end of read out ***/
          /*** Start Serial communication the temperature readout ***/
          /*** header ***/
          Serial.print('*');
          Serial.print('*');
          Serial.print('*');
          /*** send the thermistor temerature ***/
          Serial.print((char)lowerLevelTherm);
          Serial.print((char)upperLevelTherm);
          /*** send the temperature of the Pixel array ***/
            Serial.print((char)lowerLevel[pixel]);
            Serial.print((char)upperLevel[pixel]);
          /*** check if data was send to the EVB ***/
          if(Serial.available() > 0)
            int command = Serial.read();
            int freq = Serial.read();
            if(freq == 10)  //Set the Grid-EYE to the 10 Hz mode
              Wire.write(0x02);
              Wire.write(0x00);
              Maindelay = Hz10;
            else if(freq == 1) //Set the Grid-EYE to the 1 Hz mode
              Wire.write(0x02);
              Wire.write(0x01);
              Maindelay = Hz1;
            else if(freq == 2) //Set the output Mode of the Grid-EYE to normal
              Wire.write(0x1F);
              Wire.write(0x50);
              Wire.write(0x1F);
              Wire.write(0x45);
              Wire.write(0x1F);
              Wire.write(0x57);
              Wire.write(0x07);
              Wire.write(0x00);
              Wire.write(0x1F);
              Wire.write(0x00);
            else if(freq == 3)  //Set the output Mode of the Grid-EYE to moving average
              Wire.write(0x1F);
              Wire.write(0x50);
              Wire.write(0x1F);
              Wire.write(0x45);
              Wire.write(0x1F);
              Wire.write(0x57);
              Wire.write(0x07);
              Wire.write(0x20);
              Wire.write(0x1F);
              Wire.write(0x00);
          /*** termination of Serial ***/
          Serial.print("\r");
          Serial.print("\n");
          /*** delay for refresh of Grid-EYE data ***/
          delay(Maindelay);
      YveauxY 1 Reply Last reply
          Wire.begin();
          byte pixelAddL;
          while(1)
            Wire.write(0x0E);
            pixelAddL = 0x80;
            /*** header ***/
            Serial.print('*');
            Serial.print('*');
            Serial.print('*');
                Wire.write(0x02);
                Wire.write(0x00);
                Maindelay = Hz10;
                Wire.write(0x02);
                Wire.write(0x01);
                Maindelay = Hz1;
                Wire.write(0x1F);
                Wire.write(0x50);
                Wire.write(0x1F);
                Wire.write(0x45);
                Wire.write(0x1F);
                Wire.write(0x57);
                Wire.write(0x07);
                Wire.write(0x00);
                Wire.write(0x1F);
                Wire.write(0x00);
                Wire.write(0x1F);
                Wire.write(0x50);
                Wire.write(0x1F);
                Wire.write(0x45);
                Wire.write(0x1F);
                Wire.write(0x57);
                Wire.write(0x07);
                Wire.write(0x20);
                Wire.write(0x1F);
                Wire.write(0x00);
            Serial.print("\r");
            Serial.print("\n");
            delay(Maindelay);
        YveauxY
        YveauxY
        @Cliff-Karlsson Very interested to see what you'll be building with this sensor! (http://www.pureengineering.com/projects/grid-eye-breakout)
        Maybe this sketch can help? https://github.com/kriswiner/AMG8833
