  3. Jeedom on RaspberryPI with Arduino Uno on USB and remote Arduino pro mini
9 Posts 2 Posters 11.6k Views 1 Watching
  • technoantT
    technoantT
    technoant
    wrote on last edited by technoant
    Dear All,
    i'm doing a project with Jeedom and Mysensors.
    Raspberry PI 2 B [Jeedom] ---(usb)---> Arduino Uno [Serial Gateway] ---(nrf24)--> 433Mhz <---(nrf24)--- Arduino pro mini Sparkfun ---> dht11
    I use Mysensors Framework v2.1.1 for both Arduinos.
    I hope to manage several Arduino pro mini through Jeedom.
    I used tutorial Jeedom
    • technoantT
      technoantT
      technoant
      Arduino pro mini sketch.
       * Version 1.0: Henrik EKblad
      // Enable debug prints
      //#define MY_RS485
       * @def MY_NODE_ID
       * @brief Node id defaults to AUTO (tries to fetch id from controller).
      //#define MY_NODE_ID 1
      // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
      #if F_CPU == 8000000L
      #define MY_BAUD_RATE 38400
      #include <DHT.h>
      #define DHT_DATA_PIN 3
      #define SENSOR_TEMP_OFFSET 0
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      float lastTemp;
      float lastHum;
      uint8_t nNoUpdatesTemp;
      uint8_t nNoUpdatesHum;
      bool metric = true;
      DHT dht;
        sendSketchInfo("TemperatureAndHumidity", "1.1");
        present(CHILD_ID_HUM, S_HUM);
        dht.readSensor(true);
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          // Reset no updates counter
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          Serial.print("T: ");
          Serial.println(temperature);
        } else {
          nNoUpdatesTemp++;
        if (isnan(humidity)) {
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
        } else {
          nNoUpdatesHum++;
        sleep(UPDATE_INTERVAL);
      • technoantT
        technoantT
        technoant
        Arduino Uno [Gateway] sketch.
        * The ArduinoGateway prints data received from sensors on the serial link.
        * The gateway accepts input on seral which will be sent out on radio network.
        * The GW code is designed for Arduino Nano 328p / 16MHz
        * Wire connections (OPTIONAL):
        * - Inclusion button should be connected between digital pin 3 and GND
        * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
        * LEDs (OPTIONAL):
        * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
        // Enable serial gateway
        #define MY_GATEWAY_SERIAL
        // Enable inclusion mode
        // Set blinking period
        // Flash leds on rx/tx/err
        • technoantT
          technoantT
          technoant
          Mysensors.org Jeedom Plugin status.
          [2017-05-26 23:23:06][INFO] : Arrêt du service mySensors
          [2017-05-26 23:23:07][INFO] : Arrêt du service mySensors
          [2017-05-26 23:23:07][INFO] : Lancement du démon mySensors : Gateway /dev/ttyAMA0
          [2017-05-26 23:23:07][DEBUG] : Lancement démon mySensors : nice -n 19 nodejs /var/www/html/plugins/mySensors/node/mysensors.js http://192.XXX.XXX.XXX:80/plugins/mySensors/core/api/jeeSensors.php?apikey=XXXXXXXXXXXXXXXXXXXXXX master /dev/ttyAMA0 serial debug
          [2017-05-26 23:23:07][INFO] : Démon mySensors lancé
          Mysensors.org Jeedom plugin node server log.
          Fri May 26 2017 23:23:08 GMT+0200 (CEST) - Jeedom url : http://192.168.0.38:80/plugins/mySensors/core/api/jeeSensors.php?apikey=tdI13Ma1kRL4TGXyeuU9NIcgZU9CeHsOmGEseNYmAph5MdE3&gateway=master, gwAddress : /dev/ttyAMA0
          DEPRECATION: Please use `require('serialport')` instead of `require('serialport').SerialPort`
          Fri May 26 2017 23:23:08 GMT+0200 (CEST) - server bound on 8019
          Fri May 26 2017 23:23:08 GMT+0200 (CEST) - connected to serial gateway at /dev/ttyAMA0
          Fri May 26 2017 23:23:08 GMT+0200 (CEST) : http://192.XXX.XXX.XXX:80/plugins/mySensors/core/api/jeeSensors.php?apikey=XXXXXXXXXXXXXXXXXXXXXX&gateway=master&messagetype=saveGateway&sender=0&sensor=0&type=0&payload=1
          Arduino pro mini serial monitoring.
          Message below explain that NRF24 module doesn't work properly, due to VCC voltage issue or wiring issue (in my case that was vcc voltage issue)
          45210327 TSM:FAIL:RE-INIT
          45210333 TSM:INIT
          45210343 !TSM:INIT:TSP FAIL
          45210351 TSM:FAIL:CNT=7
          45210359 TSM:FAIL:PDT
          Arduino Uno [Gateway] serial monitoring.
          ;2550;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;TSF:WUR:MS=0
          0;255;3;0;9;TSM:INIT:TSP OK
          0;255;3;0;9;TSM:INIT:GW MODE
          0;255;0;0;18;2.1.1
          0;255;3;0;9;MCO:BGN:STP
          • scalzS
            scalzS
            could you give us more info about your arduino pro mini node (how it is powered etc)? or a pic?
            Looks like you may have a bad radio wiring..
            Also, have you added a capacitor for nrf?
            https://www.mysensors.org/build/connect_radio
            This should work out of the box.
            technoantT 2 Replies Last reply
            • scalzS scalz
              technoantT
              technoantT
              technoant
              @scalz My Arduino pro mino is currently powered through USB-TTL with 3.3v as it is a 3.3v arduino pro mini.
              I though it was a wiring issue but i re-wired it several time looking at the tutorial to connect radio and i had no chance to work.
              I didn't put yet capacitor.
              • scalzS scalz
                technoantT
                technoantT
                technoant
                @scalz I have added capacitor on both nrf24 the one on the Arduino Uno [SerialGateway] and the one on Arduino pro mini.
                I still have the same messages on the Arduino pro mini..
                technoantT 1 Reply Last reply
                • technoantT technoant
                  technoantT
                  technoantT
                  technoant
                  I removed the DHT11 from the Arduino pro mini and it seems to work.
                  I guess it is due to parallal plug on VCC for DHT11 and NRF24.
                  Arduino pro mini:
                  4468 MCO:SLP:WUP=-1
                  4493 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  4526 MCO:SLP:TPD
                  4530 MCO:SLP:WUP=-1
                  4556 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  4587 MCO:SLP:TPD
                  4591 MCO:SLP:WUP=-1
                  4618 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  4648 MCO:SLP:TPD
                  Arduino Uno [SerialGateway]:
                  0;255;3;0;9;TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
                  2;255;0;0;17;2.1.1
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  2;255;3;0;6;0
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
                  2;255;3;0;11;TemperatureAndHumidity
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                  2;255;3;0;12;1.1
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=0,c=0,t=7,pt=0,l=0,sg=0:
                  2;0;0;0;7;
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=1,c=0,t=6,pt=0,l=0,sg=0:
                  2;1;0;0;6;
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  0;255;3;0;9;TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  0;255;3;0;5;1
                  0;255;3;0;9;TSM:READY:NWD REQ
                  0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                  0;255;3;0;5;0
                  • technoantT
                    technoantT
                    technoant
                    I successed to include the arduino micro in Mysensors plugin of Jeedom.
                    Now everything work.
                    I plugged the DHT11 vcc on FTDI Header vcc pin.
                    I plugged the USB ttl vcc on raw pin.
                    And now everything work fine.
                    arduino pro micro pin
