  3. Jeedom on RaspberryPI with Arduino Uno on USB and remote Arduino pro mini
9 Posts 2 Posters 11.4k Views 1 Watching
  • technoantT Offline
    technoantT Offline
    technoant
    wrote on last edited by technoant
    Dear All,
    i'm doing a project with Jeedom and Mysensors.
    Raspberry PI 2 B [Jeedom] ---(usb)---> Arduino Uno [Serial Gateway] ---(nrf24)--> 433Mhz <---(nrf24)--- Arduino pro mini Sparkfun ---> dht11
    I use Mysensors Framework v2.1.1 for both Arduinos.
    I hope to manage several Arduino pro mini through Jeedom.
    I used tutorial Jeedom
      technoantT Offline
      technoant
      Arduino pro mini sketch.
       * Version 1.0: Henrik EKblad
       * sensor using a DHT11/DHT-22.
      // Enable debug prints
      //#define MY_RS485
       * @def MY_NODE_ID
      //#define MY_NODE_ID 1
      #if F_CPU == 8000000L
      #define MY_BAUD_RATE 38400
      #define DHT_DATA_PIN 3
      #define SENSOR_TEMP_OFFSET 0
      static const uint64_t UPDATE_INTERVAL = 60000;
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      float lastTemp;
      float lastHum;
      uint8_t nNoUpdatesTemp;
      uint8_t nNoUpdatesHum;
      bool metric = true;
      DHT dht;
        sendSketchInfo("TemperatureAndHumidity", "1.1");
        present(CHILD_ID_HUM, S_HUM);
        dht.readSensor(true);
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          // Reset no updates counter
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          Serial.print("T: ");
          nNoUpdatesTemp++;
        if (isnan(humidity)) {
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
          nNoUpdatesHum++;
        sleep(UPDATE_INTERVAL);
        technoantT Offline
        technoant
        Arduino Uno [Gateway] sketch.
        * LEDs (OPTIONAL):
        * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
        // Enable serial gateway
        #define MY_GATEWAY_SERIAL
        // Enable inclusion mode
        // Set blinking period
        // Flash leds on rx/tx/err
          technoantT Offline
          technoant
          Mysensors.org Jeedom Plugin status.
          [2017-05-26 23:23:06][INFO] : Arrêt du service mySensors
          [2017-05-26 23:23:07][INFO] : Arrêt du service mySensors
          [2017-05-26 23:23:07][INFO] : Lancement du démon mySensors : Gateway /dev/ttyAMA0
          [2017-05-26 23:23:07][DEBUG] : Lancement démon mySensors : nice -n 19 nodejs /var/www/html/plugins/mySensors/node/mysensors.js http://192.XXX.XXX.XXX:80/plugins/mySensors/core/api/jeeSensors.php?apikey=XXXXXXXXXXXXXXXXXXXXXX master /dev/ttyAMA0 serial debug
          [2017-05-26 23:23:07][INFO] : Démon mySensors lancé
          Mysensors.org Jeedom plugin node server log.
          Fri May 26 2017 23:23:08 GMT+0200 (CEST) - Jeedom url : http://192.168.0.38:80/plugins/mySensors/core/api/jeeSensors.php?apikey=tdI13Ma1kRL4TGXyeuU9NIcgZU9CeHsOmGEseNYmAph5MdE3&gateway=master, gwAddress : /dev/ttyAMA0
          DEPRECATION: Please use `require('serialport')` instead of `require('serialport').SerialPort`
          Fri May 26 2017 23:23:08 GMT+0200 (CEST) - server bound on 8019
          Fri May 26 2017 23:23:08 GMT+0200 (CEST) - connected to serial gateway at /dev/ttyAMA0
          Fri May 26 2017 23:23:08 GMT+0200 (CEST) : http://192.XXX.XXX.XXX:80/plugins/mySensors/core/api/jeeSensors.php?apikey=XXXXXXXXXXXXXXXXXXXXXX&gateway=master&messagetype=saveGateway&sender=0&sensor=0&type=0&payload=1
          Arduino pro mini serial monitoring.
          Message below explain that NRF24 module doesn't work properly, due to VCC voltage issue or wiring issue (in my case that was vcc voltage issue)
          45210327 TSM:FAIL:RE-INIT
          45210333 TSM:INIT
          45210343 !TSM:INIT:TSP FAIL
          45210351 TSM:FAIL:CNT=7
          45210359 TSM:FAIL:PDT
          Arduino Uno [Gateway] serial monitoring.
          ;2550;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;TSF:WUR:MS=0
          0;255;3;0;9;TSM:INIT:TSP OK
          0;255;3;0;9;TSM:INIT:GW MODE
          0;255;0;0;18;2.1.1
          0;255;3;0;9;MCO:BGN:STP
          • S Offline
            could you give us more info about your arduino pro mini node (how it is powered etc)? or a pic?
            Looks like you may have a bad radio wiring..
            Also, have you added a capacitor for nrf?
            https://www.mysensors.org/build/connect_radio
            This should work out of the box.
            technoantT 2 Replies Last reply
            • S scalz
              technoantT Offline
              technoantT Offline
              technoant
              @scalz My Arduino pro mino is currently powered through USB-TTL with 3.3v as it is a 3.3v arduino pro mini.
              I though it was a wiring issue but i re-wired it several time looking at the tutorial to connect radio and i had no chance to work.
              I didn't put yet capacitor.
              • S scalz
                technoantT Offline
                technoantT Offline
                technoant
                @scalz I have added capacitor on both nrf24 the one on the Arduino Uno [SerialGateway] and the one on Arduino pro mini.
                I still have the same messages on the Arduino pro mini..
                technoantT 1 Reply Last reply
                • technoantT technoant
                  technoantT Offline
                  technoantT Offline
                  technoant
                  I removed the DHT11 from the Arduino pro mini and it seems to work.
                  I guess it is due to parallal plug on VCC for DHT11 and NRF24.
                  Arduino pro mini:
                  4468 MCO:SLP:WUP=-1
                  4493 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  4526 MCO:SLP:TPD
                  4530 MCO:SLP:WUP=-1
                  4556 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  4587 MCO:SLP:TPD
                  4591 MCO:SLP:WUP=-1
                  4618 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  4648 MCO:SLP:TPD
                  Arduino Uno [SerialGateway]:
                  0;255;3;0;9;TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
                  2;255;0;0;17;2.1.1
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  2;255;3;0;6;0
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
                  2;255;3;0;11;TemperatureAndHumidity
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                  2;255;3;0;12;1.1
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=0,c=0,t=7,pt=0,l=0,sg=0:
                  2;0;0;0;7;
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=1,c=0,t=6,pt=0,l=0,sg=0:
                  2;1;0;0;6;
                  0;255;3;0;9;TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  0;255;3;0;9;TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  0;255;3;0;5;1
                  0;255;3;0;9;TSM:READY:NWD REQ
                  0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                  0;255;3;0;5;0
                    technoantT Offline
                    technoant
                    I successed to include the arduino micro in Mysensors plugin of Jeedom.
                    Now everything work.
                    I plugged the DHT11 vcc on FTDI Header vcc pin.
                    I plugged the USB ttl vcc on raw pin.
                    And now everything work fine.
                    arduino pro micro pin
                    12.2k
