  3. 💬 NModule DC Fan / PWM shield
contest2017fanmysensorspwmnmodule
4 Posts 3 Posters 1.4k Views 2 Watching
  • openhardware.ioO Offline
    openhardware.io
    https://www.openhardware.io/view/405/NModule-DC-Fan-PWM-shield
    • Nca78N Offline
      Nca78N Offline
      The 2 projects this "shield" was intended for (control fan in fridge furniture and kitchen LED lighting) run so I remove the "work in progress" flag.
      I'll post more on the projects, assembly instructions and scripts later.
      • T Offline
        T Offline
        Toyman
        Can the FET withstand continious 2A load? I have one meter long 5050 strip
        Nca78N 1 Reply Last reply
        • T Toyman
          Nca78N Offline
          Nca78N Offline
          @toyman said in 💬 NModule DC Fan / PWM shield:
          FDD8447L is rated for 15A continuous load. You don't want to try that because it's possible only with a big pad and 2oz copper PCB, but 2A will not be a problem on this board, there's plenty of margin :)
          https://isojed.nl/blog/wp-content/uploads/2013/06/FDD8447L.pdf
