  3. OpenHAB
  4. Openhab MQTT Example
openhab mqtt ex
49 Posts 8 Posters 74.6k Views 1 Watching
  • T
    tboha
    Connection refused means (in 99%) your broker is not up or you got the wrong address.
    I supposed you to run mosquitto_sub/pub on the same machine your broker runs on.
    On a different machine you have to add the host address like:
    mosquitto_sub -h 192.168.1.10 -t /topic -m "message".
    No - at last its not really complicated, but I think you had just a bad start. MySensors and OpenHab tend to start right out of the box - but you need the right box......
      Marcus
      wrote on last edited by Marcus
      #42
      Please stop helping me now. Now i have pidome and the first sensor is running after 30 minutes with my ethernet mqtt gateway ;-)
      That is what i want. Maybe one day there are nice tutorials for Openhab. Thank u very much for trying to help. If i now start with mosquitto to get openhab run is the same as when i make a patch for a patch....
      It seems that pidome has wait for me it is really nice and not much complicated.
      C 1 Reply Last reply
      • M Marcus
        C
        C
        C.r.a.z.y.
        @Marcus Try Tim's files and JAR file for serial openHab http://forum.mysensors.org/topic/655/serial-gateway-connection-to-openhab/2
        I added a motion sensor and its fine.
        JohnJ 1 Reply Last reply
        • C C.r.a.z.y.
          JohnJ
          JohnJ
          John
          wrote on last edited by John
          #44
          @Marcus Good to see you have it working! The MySensors MQTT plugin and serial drivers are quite stable. Some parts of the server can behave a little strange, cause still in heavy development.
          • JohnJ John
            C
            C
            C.r.a.z.y.
            @John There was a problem with serial....1.6.1.jar it doesnt show this correctly;
            ArduinoUpdate -> 0;0;3;0;9;read: 14-14-0 s=1,c=1,t=16,pt=0,l=1:0
            14;1;1;0;16;0
            i think its related with baud rate for jar file because i saw  these kind of things in terminal ����BO�"U��²e��B&��i�
            • C C.r.a.z.y.
              14;1;1;0;16;0
              JohnJ
              JohnJ
              John
              @C.r.a.z.y. That's highly possible, or there was a wrong choice of encoding at the wrong moment.
              • H
                H
                Hacker007
                Hi.
                I have OpenHAB, MQTT and battery powered units (http://iot-playground.com/2-uncategorised/10-low-power-door-window-sensor). I cannot receive battery status in Openhab (other things from the same unit are transmitted OK). What is wrong?
                1. I send: gw.sendBatteryLevel(batLevel);
                2. Number node4_bat "Bat [%.1f %%]" <temperature> (node4, GBattery) {mqtt="<[mysensor:MyMQTT/4/255/50:state:default]"}
                I have seen somewhere that battery state is transmitted via '50'?!?
                • H
                  H
                  Hacker007
                  wrote on last edited by Hacker007
                  #48
                  Hi. I have figured it out. It is presented as "mysensor:MyMQTT/4/255/V_:state:default". No number in current version from mysensors!!!
                  The next step was to edit MyMQTT.cpp: char V_50[] PROGMEM = ""; into char V_50[] PROGMEM = "50";. Now I get battery status via "mysensor:MyMQTT/4/255/V_50:state:default".
                  So in conclusion I have answered my own questions and have solved them...
                  • F
                    F
                    francis
                    coming back to the initial issue, is there anyone that can post items and maps configuration to test the binary switch example of mysensors? my configuration is arduino uno+w5100 and mqtt gateway, opnhab on windows pc on the same network
