  3. OpenHAB
  4. Openhab MQTT Example
openhab mqtt ex
49 Posts 8 Posters 74.9k Views 1 Watching
  • b0rmannB
    b0rmannB
    b0rmann
    MQTT-Ethernet-Gateway is mqtt brocker, not client :(
    to connect mosquitto try use MQTTClientGateway http://forum.mysensors.org/topic/524/mqtt-client-gateway
      Marcus
      wrote on last edited by Marcus
      #34
      @b0rmann Please read the whole thread and tell me what to do now!!! I only want openhab and mysensors work together. But i want to use my mqtt-ethernet-gateway. Not the serial way.
      b0rmannB 1 Reply Last reply
      • M Marcus
        Thank u for your answers.
        I love the look of openhab. So i will try the it with mosquitto.
        If it will not work then i will try pidome and serial gateway.
        If i have new infos i will post them here!
        JohnJ
        JohnJ
        John
        @Marcus PiDome also supports the mqtt gateway next to the serial gateway, so no need to switch. As far as i know, but i'm not an openhab expert, it should work fine as a mqtt client to connect to the mysensors mqtt gateway.
        See this thread for some examples: http://forum.mysensors.org/topic/303/mqtt-broker-gateway
        The developer of the MQTT gateway has posted some examples in the above thread on how you should be able to use it.
        Cheers!
          Marcus
          @John Thank u very much. I think i will stop with Openhab and give PiDome a try. it seems to be better described what to do to get it run.
          In the thread u mentioned i looked for some examples but didnt get them to work and no one could help.
          JohnJ 1 Reply Last reply
          • M Marcus
            b0rmannB
            b0rmannB
            b0rmann
            @Marcus mqtt client gateway is not serial way :)
            i have mqtt-client-gateway + raspi (mosquitto + openhab + nodered)
            • M Marcus
              JohnJ
              JohnJ
              John
              @Marcus Wish i could help, too bad it doesn't work. Others are using it successfully as far as i know. Maybe different openhab version install. Well, let me know if there are any issues or help needed with PiDome.
              • T
                tboha
                @Marcus: Sorry I'm in a hurry so...
                But what to do now??? -> is your broker really ok?
                1. open two terminal windows on your Raspberry.
                2. one window:
                  mosquitto_sub -t /test -v
                3. second window:
                  mosquitto_pub -t /test -m "test message"
                If it's all fine, the test message should show up in the first window.
                How do i connect mosquitto to Openhab?
                OpenHab -> mosquitto
                If your still got the OpenHab sitemap from above, the swtiches 1+3 should be functional like desribed, switch 2 will result in an errormessage in the log (as "intended").
                Reverse direction (mosquitto -> Openhab).
                You may populate your broker with some messages for the given topic.
                e.g. mosquitto_pub -t MyMQTT/20/255/V_SKETCH_NAME -m "fake sketch name"
                I use the serial Gateway connected via USB to my Raspberry and a little Node.js script.
                If you are interested - let me know.
                  Marcus
                  Thank u anyway for your help @tboha . I think this is too much complicated. I tried ur last idea, but i got connection refused error. Really frustrating.... I want to see results. I hope pidome gave me faster results than openhab.
                  • T
                    tboha
                    Connection refused means (in 99%) your broker is not up or you got the wrong address.
                    I supposed you to run mosquitto_sub/pub on the same machine your broker runs on.
                    On a different machine you have to add the host address like:
                    mosquitto_sub -h 192.168.1.10 -t /topic -m "message".
                    No - at last its not really complicated, but I think you had just a bad start. MySensors and OpenHab tend to start right out of the box - but you need the right box......
                      Marcus
                      #42
                      Please stop helping me now. Now i have pidome and the first sensor is running after 30 minutes with my ethernet mqtt gateway ;-)
                      That is what i want. Maybe one day there are nice tutorials for Openhab. Thank u very much for trying to help. If i now start with mosquitto to get openhab run is the same as when i make a patch for a patch....
                      It seems that pidome has wait for me it is really nice and not much complicated.
                      C 1 Reply Last reply
                      • M Marcus
                        C
                        C
                        C.r.a.z.y.
                        @Marcus Try Tim's files and JAR file for serial openHab http://forum.mysensors.org/topic/655/serial-gateway-connection-to-openhab/2
                        I added a motion sensor and its fine.
                        • C C.r.a.z.y.
                          JohnJ
                          JohnJ
                          John
                          wrote on last edited by John
                          #44
                          @Marcus Good to see you have it working! The MySensors MQTT plugin and serial drivers are quite stable. Some parts of the server can behave a little strange, cause still in heavy development.
                          • JohnJ John
                            C
                            C
                            C.r.a.z.y.
                            @John There was a problem with serial....1.6.1.jar it doesnt show this correctly;
                            ArduinoUpdate -> 0;0;3;0;9;read: 14-14-0 s=1,c=1,t=16,pt=0,l=1:0
                            14;1;1;0;16;0
                            i think its related with baud rate for jar file because i saw  these kind of things in terminal ����BO�"U��²e��B&��i�
                            • C C.r.a.z.y.
                              14;1;1;0;16;0
                              JohnJ
                              JohnJ
                              John
                              @C.r.a.z.y. That's highly possible, or there was a wrong choice of encoding at the wrong moment.
                              • H
                                H
                                Hacker007
                                Hi.
                                I have OpenHAB, MQTT and battery powered units (http://iot-playground.com/2-uncategorised/10-low-power-door-window-sensor). I cannot receive battery status in Openhab (other things from the same unit are transmitted OK). What is wrong?
                                1. I send: gw.sendBatteryLevel(batLevel);
                                2. Number node4_bat "Bat [%.1f %%]" <temperature> (node4, GBattery) {mqtt="<[mysensor:MyMQTT/4/255/50:state:default]"}
                                I have seen somewhere that battery state is transmitted via '50'?!?
                                • H
                                  H
                                  Hacker007
                                  wrote on last edited by Hacker007
                                  #48
                                  Hi. I have figured it out. It is presented as "mysensor:MyMQTT/4/255/V_:state:default". No number in current version from mysensors!!!
                                  The next step was to edit MyMQTT.cpp: char V_50[] PROGMEM = ""; into char V_50[] PROGMEM = "50";. Now I get battery status via "mysensor:MyMQTT/4/255/V_50:state:default".
                                  So in conclusion I have answered my own questions and have solved them...
                                  • F
                                    F
                                    francis
                                    coming back to the initial issue, is there anyone that can post items and maps configuration to test the binary switch example of mysensors? my configuration is arduino uno+w5100 and mqtt gateway, opnhab on windows pc on the same network
