  3. OpenHAB
  4. Openhab MQTT Example
openhab mqtt ex
49 Posts 8 Posters 74.9k Views 1 Watching
    Marcus
    @John Thank u very much. I think i will stop with Openhab and give PiDome a try. it seems to be better described what to do to get it run.
    In the thread u mentioned i looked for some examples but didnt get them to work and no one could help.
    JohnJ 1 Reply Last reply
    • M Marcus
      @b0rmann Please read the whole thread and tell me what to do now!!! I only want openhab and mysensors work together. But i want to use my mqtt-ethernet-gateway. Not the serial way.
      b0rmannB
      b0rmannB
      b0rmann
      @Marcus mqtt client gateway is not serial way :)
      i have mqtt-client-gateway + raspi (mosquitto + openhab + nodered)
      • M Marcus
        JohnJ
        JohnJ
        John
        @Marcus Wish i could help, too bad it doesn't work. Others are using it successfully as far as i know. Maybe different openhab version install. Well, let me know if there are any issues or help needed with PiDome.
        • T
          tboha
          @Marcus: Sorry I'm in a hurry so...
          But what to do now??? -> is your broker really ok?
          1. open two terminal windows on your Raspberry.
          2. one window:
            mosquitto_sub -t /test -v
          3. second window:
            mosquitto_pub -t /test -m "test message"
          If it's all fine, the test message should show up in the first window.
          How do i connect mosquitto to Openhab?
          OpenHab -> mosquitto
          If your still got the OpenHab sitemap from above, the swtiches 1+3 should be functional like desribed, switch 2 will result in an errormessage in the log (as "intended").
          Reverse direction (mosquitto -> Openhab).
          You may populate your broker with some messages for the given topic.
          e.g. mosquitto_pub -t MyMQTT/20/255/V_SKETCH_NAME -m "fake sketch name"
          I use the serial Gateway connected via USB to my Raspberry and a little Node.js script.
          If you are interested - let me know.
            Marcus
            Thank u anyway for your help @tboha . I think this is too much complicated. I tried ur last idea, but i got connection refused error. Really frustrating.... I want to see results. I hope pidome gave me faster results than openhab.
            • T
              tboha
              Connection refused means (in 99%) your broker is not up or you got the wrong address.
              I supposed you to run mosquitto_sub/pub on the same machine your broker runs on.
              On a different machine you have to add the host address like:
              mosquitto_sub -h 192.168.1.10 -t /topic -m "message".
              No - at last its not really complicated, but I think you had just a bad start. MySensors and OpenHab tend to start right out of the box - but you need the right box......
                Marcus
                wrote on last edited by Marcus
                #42
                Please stop helping me now. Now i have pidome and the first sensor is running after 30 minutes with my ethernet mqtt gateway ;-)
                That is what i want. Maybe one day there are nice tutorials for Openhab. Thank u very much for trying to help. If i now start with mosquitto to get openhab run is the same as when i make a patch for a patch....
                It seems that pidome has wait for me it is really nice and not much complicated.
                C 1 Reply Last reply
                • M Marcus
                  C
                  C
                  C.r.a.z.y.
                  @Marcus Try Tim's files and JAR file for serial openHab http://forum.mysensors.org/topic/655/serial-gateway-connection-to-openhab/2
                  I added a motion sensor and its fine.
                  • C C.r.a.z.y.
                    JohnJ
                    JohnJ
                    John
                    wrote on last edited by John
                    #44
                    @Marcus Good to see you have it working! The MySensors MQTT plugin and serial drivers are quite stable. Some parts of the server can behave a little strange, cause still in heavy development.
                    • JohnJ John
                      C
                      C
                      C.r.a.z.y.
                      @John There was a problem with serial....1.6.1.jar it doesnt show this correctly;
                      ArduinoUpdate -> 0;0;3;0;9;read: 14-14-0 s=1,c=1,t=16,pt=0,l=1:0
                      14;1;1;0;16;0
                      i think its related with baud rate for jar file because i saw  these kind of things in terminal ����BO�"U��²e��B&��i�
                      • C C.r.a.z.y.
                        14;1;1;0;16;0
                        JohnJ
                        JohnJ
                        John
                        @C.r.a.z.y. That's highly possible, or there was a wrong choice of encoding at the wrong moment.
                        • H
                          H
                          Hacker007
                          Hi.
                          I have OpenHAB, MQTT and battery powered units (http://iot-playground.com/2-uncategorised/10-low-power-door-window-sensor). I cannot receive battery status in Openhab (other things from the same unit are transmitted OK). What is wrong?
                          1. I send: gw.sendBatteryLevel(batLevel);
                          2. Number node4_bat "Bat [%.1f %%]" <temperature> (node4, GBattery) {mqtt="<[mysensor:MyMQTT/4/255/50:state:default]"}
                          I have seen somewhere that battery state is transmitted via '50'?!?
                          • H
                            H
                            Hacker007
                            wrote on last edited by Hacker007
                            #48
                            Hi. I have figured it out. It is presented as "mysensor:MyMQTT/4/255/V_:state:default". No number in current version from mysensors!!!
                            The next step was to edit MyMQTT.cpp: char V_50[] PROGMEM = ""; into char V_50[] PROGMEM = "50";. Now I get battery status via "mysensor:MyMQTT/4/255/V_50:state:default".
                            So in conclusion I have answered my own questions and have solved them...
                            • F
                              F
                              francis
                              coming back to the initial issue, is there anyone that can post items and maps configuration to test the binary switch example of mysensors? my configuration is arduino uno+w5100 and mqtt gateway, opnhab on windows pc on the same network
