  3. help needed with multiple temp sensor data logging project
37 Posts 4 Posters 12.7k Views 5 Watching
  • M Offline
    M Offline
    MasterCATZ
    RFM69 does look promising even if
    I have to power it
    • M Offline
      M Offline
      MasterCATZ
      looks like I will have to make my own sensors that Daisy chain directly off the sensor
      https://edwardmallon.wordpress.com/2015/03/01/using-ds18b20-sensors-to-make-a-diy-thermistor-string-pt-1-the-build/
      • M Offline
        M Offline
        MasterCATZ
        wrote on last edited by MasterCATZ
        #23
        so what I think I will do is
        use a trimpot at the start so resistance can be adjusted as sensors/length are altered
        cat5 wiring
        Dry end has 2x rj11 ends
        *example
        rj11 (in) pins 1,2,3,4
        rj11 (out) pins 5,6,7,8
        Pin 1 (White/Green) - Power return or ground
        Pin 2 (Green) - +5V
        Pin 3 (White/Orange) - Power return or ground
        Pin 4 (Blue) - DQ (data in)
        Pin 5 (White/Blue) - 1-Wire return or ground
        Pin 6 (Orange) - +5V
        Pin 7 (White/Brown) Power return or ground
        Pin 8 (Brown) - DQ (data out)
        all wires join onto the DS18B20 and waterproofed
        then up at the dry end use rj11 joiners, they can be pulled apart and have resistors added if needed and if I need to take a sensor out of the daisy chain, it is just a matter of bypassing a joiner
        http://www.ebay.com.au/itm/RJ11-6P4C-Female-Modular-Telephone-Cable-Wire-Straight-Coupler-Joiner-White-/111725356245?hash=item1a0359a4d5:g:miQAAOSwWxNY2l0I
        or I just do the STUBS thing 100-150Ω resistor inside a 3 way splitter and have a normal premade waterproofed sensor used with rj11 connector
        http://www.ebay.com.au/itm/10pcs-RJ-11-RJ-14-Phone-Line-Cable-Coupler-3-Way-Splitter-Connector-Adapter-/290986642163?hash=item43c027caf3:g:LD4AAOxySy9SRSLm
        either should work in the fish room tanks are on racks stacked to each other
        so how would I go about doing a 1-wire breakout, as each rack would be pushing the length and I have 14x racks ~3m long 4 tiers
        I might be possible to do the daisy chain per 2 racks
        is their a way to do it without using multiple Arduino , is there some hardware that would allow multiple runs of 1-wire ?
        • M Offline
          M Offline
          MasterCATZ
          another thing does anyone know if putting capacitors in the daisy chain will cause any issues?
          I figured haveing a capacitor near a sensor would help keep the power stable?
          • wallyllamaW Offline
            wallyllamaW Offline
            wallyllama
            There are 1wire "hubs" that would help, they basically turn on or off parts of the network, so each run could be the max distance.
            Each network would need only 1 digital pin and resistor, i think you could define multiple pins and do a onewire.begin for each (using different names each of course) i think you would run out of memory or clock cycles before you ran out of pins even with a pro mini.
            Using a dedicated 5v line is probably better than a capacitor and parasitic power, especially with long runs and lots of sensors. Unless you can live with really slow polling times. With the complexity you are talking about, I wouldn't be surprised if takes a couple of minutes to poll everything reliably with parasitic power. If it works (i havent tried it) using several pins on the arduino, each controlling a 1wire network might help out considerably. You could service 1 network, while the others are being "charged".
              wallyllamaW Offline
              wallyllama
              If you search "1-wire hub", there are premade options, and diy.
              • M Offline
                M Offline
                MasterCATZ
                #27
                thanks for your guidance
                parts arrived yesterday and just got the probes reading
                how ever I could not get OWFS to work,
                https://www.domoticz.com/wiki/1Wire
                sudo i2cdetect -y 1
                0 1 2 3 4 5 6 7 8 9 a b c d e f
                00: -- -- -- -- -- -- -- -- -- -- -- -- --
                10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                70: -- -- -- -- -- -- -- --
                but using /sys/bus/w1/devices
                they are there
                cat w1_slave
                a2 01 4b 46 7f ff 0c 10 49 : crc=49 YES
                a2 01 4b 46 7f ff 0c 10 49 t=26125
                edit
                actually quite happy, using 5v and daisy chained a heap of cat5 cables together for testing, over 100m all working good
                wallyllamaW 1 Reply Last reply
                • M MasterCATZ
                  sudo i2cdetect -y 1
                  they are there
                  cat w1_slave
                  edit
                  wallyllamaW Offline
                  wallyllamaW Offline
                  wallyllama
                  @MasterCATZ :smiley_cat:
                  • M MasterCATZ
                    zboblamontZ Offline
                    zboblamontZ Offline
                    zboblamont
                    @MasterCATZ I'm following this with interest as looking at a WAY smaller scale use with the small 3 legged 18B20 to give individual room temperatures in the house, 4 upstairs, 6 downstairs.
                    Had originally considered individual room nodes, but this seems a slightly simpler solution (other than lifting parts of the upstairs floor).
                    M 1 Reply Last reply
                    • zboblamontZ zboblamont
                      M Offline
                      M Offline
                      MasterCATZ
                      #30
                      @zboblamont I will be able to test the lengths today, making another 20x temperature sockets and I have a heap of 20m cat5 cables to chain from
                      I am using a trim pot to adjust at the breadboard, so far still 4.7
                      if I was going to do it again would use a 5 or 10k high precision the 5% pot too dodgy
                      still yet to use resistors on each drop and I have a 10v 1000uf capacitor on each ground / vcc, no idea if it helps or not
                      you could also run a 100mbs LAN plus temp probes each using 4x of the 8 cat5 pins
                      http://www.108relays.ca/dl/1_Wire_Design_Guide_v1.0.pdf
                      edit
                      it looks like you have to keep the lengths and probe numbers equal if your splitting them off like a tree
                      if I had 1 side 6m longer with more probes than the other side a probe read 0 deg
                      added more probes on the other side and they read fine again
                      ( touch wood )
                      I have placed a probe at the end with no capacitor, can not get it to connect
                      when I make more probes tomorrow will try that spot again with a capacitor
                      for now will try the one with out capacitor at the first split near the pi to see what happens, it's pitch black now time for bed :P
                      strange thing just tried another stock probe with no capacitor and can not get that to work either and I was running these ones inside all day
                      for some reason voltmeter reads neg millivolts
                      now I just want to build another cap probe to see whats going on
                      edit , either I wired something backwards or maybe i just hit the limits adjusting trim pot now as even the DS18B20 on the bread board stopped responding
                      edit, somethings not right pulled the main link and its receiving 0 deg from sensors not even plugged in.
                      new probe and bread board temps working tho
                      set @ 4k , tried adding another probe at 1st split all died again,
                      I'd say at my limits without the 100~150 resistors trying to push 6x 20m cables
                      voltage still 4+
                      but I am sus as to why a probe felt warm where a cap was done, unsure if it was still from the soldering heat or not so I might have something miss wired as I was running as the day light was dropping fast
                      ( this setup is for monitoring tanks in my polytunnels no lights apart from the flash light in my mouth )
                      the goal was 3 x 20m on each side split at the breadboard with ~5m long branches running of each join with 2x probes about every 1 m with 1m long lengths approx 60x DS18B20 and about 210m of cable
                      unfortunately, I was 1 section short the 5th section would not work
                      so 50 probes 175m cable
                      I'll try again in a daisy chain formation later on
                      currently using raspberry pi 2 B and domoticz
                      I ended up doing rj45 as they worked out cheaper than the rj11/14
                      I paid $20 for 100 , also why I did not add the capacitor inside like I was going to so they could be used in other areas for LAN, hopefully, no one tries to plug a laptop into them
                      http://www.ebay.com.au/itm/CS-5X-US-10x-Practical-3-Way-RJ45-LAN-Network-Ethernet-Splitter-Connector-Beige/201963874318
                      • M Offline
                        M Offline
                        MasterCATZ
                        might be best to NOT buy the ones I got , just discovered 1x port of just about all of them was not working correctly
                        ( pins on slight angle off setting alignment )
                        causing the probes to be in parasitic mode
                        • M MasterCATZ
                          zboblamontZ Offline
                          zboblamontZ Offline
                          zboblamont
                          @MasterCATZ I should not have the same issues as the scale in my case is small, but will set up a test with the devices individually just in case before installing. This is the type on it's way (not from this supplier), I can only hope they are genuine components. link text
                          I will also have to read the guide again as the devices placement and harmonics were a bit of a puzzle, and on one hand they recommended Cat5e yet went on to say twisted pair was better.
                          • M Offline
                            M Offline
                            MasterCATZ
                            #33
                            anyone know the correct way I should be using an external power source
                            I powered them up directly with + - still running to the pi and blew the external 2a 5v power pack ( it also powered up the pi and I believe back-feeding this way removes surge protection )
                            then I tried with the GND and DQ connected with the pi doing the pull up , external PSU ( 30A rated 5v rail 450w 3.3v 12v 5v ) looked like it was shorting out dropping .2v per probe and changing sound as tho it was under load how ever I am currently using its 3A port
                            I then tried with just the DQ connected not much luck
                            then I moved the bread board over the PSU and had the 4.7k pull up on its end and DQ / GND connected to the pi , I seem to have some connections, but getting a lot of unknown vendor type errors
                            but PSU does not seem to be under load
                            http://datasheets.maximintegrated.com/en/ds/DS2482-100.pdf
                            I might get one of these I2C one wire bridge that can adjust the strength of the pull-up dynamically as the network grows
                            http://videos.cctvcamerapros.com/voltage-drop-calculator
                            has got me thinking I might double up on the strands 24 gauge has too much voltage drop @ 5v
                            should I just treat each pair as a wire or should I have ground on each twist ?
                            ie
                            ( p1,p2 GND) Green pair
                            ( p3,p4 VCC ) Blue pair
                            (p5.p6 DQ ) Orange pair
                            ( p6,p7 GND ) Brown pair
                            or
                            (p1 ground p2 VCC ) Green pair
                            (p3,ground p4 VCC ) Blue pair
                            (p5,ground,p6 DQ ) Orange pair
                            (p7,ground,p8 DQ ) Brown pair
                            or any other combo, I would rather use a 2amp PSU than a 30 amp .. but thats so far the only way to keep these things powered up in a daisy chain
                            https://forum.allaboutcircuits.com/threads/24-gauge-wire-if-you-double-up-strands-what-equivalence-gauge.108649/
                              wallyllamaW Offline
                              wallyllama
                              It looks like the standard for power over ethernet uses a twisted pair as a "single wire". So blue/blue-white is + and brown/brown-white is -
                              Seems like a reasonable way to do it, even though you arent wiring ethernet.
                              • M MasterCATZ
                                ie
                                or
                                zboblamontZ Offline
                                zboblamontZ Offline
                                zboblamont
                                @MasterCATZ Perhaps you are expecting too much of the network you wish to monitor, which to be fair is not small. Splitting the network into smaller more controllable and manageable segments may be counter intuitive, but can be efficient even if you derive a solution beyond your own pre-determinations.
                                • wallyllamaW wallyllama
                                  M Offline
                                  M Offline
                                  MasterCATZ
                                  #36
                                  @wallyllama thanks that is what I feared, and would have made the job a lot easier
                                  how ever I was thinking about doing it the other way to keep the other probes already made backward compatible as they used pins 1-4
                                  just trying to weigh up the pro's and cons
                                  also out of all those 3 way splitters only 15x actually have all pins functional ...
                                  so trying to think of a way to still use the dodgy ones by having redundancy's in place
                                  I think the way the PSU is wired up at the moment is the correct way
                                  things don't seem to be stressed out this time
                                  I am also raising my polling times as I think I read somewhere it takes the sensors 750ms to perform a function and uses 1.5 mA each?
                                  Sensor Poll Period: 1000 to 30000
                                  Switch Poll Period: 100 to 1000
                                  my way of thinking this should still have all 60 sensors read in 1 min?
                                  60 sec / 1000ms for Switch Poll period?
                                  edit kept my original pin out just doubling up instead of having in/out
                                  I will just change the colors to make it easier to put into the jacks
                                  with out doing A / B standard Ethernet wiring
                                  Pin 2 (Green) - +5V
                                  Pin 3 (White/Blue) - Power return or ground
                                  Pin 5 (White/Orange) - 1-Wire return or ground
                                  this way a ground will be on every twisted pair
                                  voltage is higher now
                                  and now that I just soldered everything up, I notice I don't even need the pull-up because I am using external PSU anyhow
                                  I knew I should have put in a bypass switch
                                  • M MasterCATZ
                                    Pin 2 (Green) - +5V
                                    wallyllamaW Offline
                                    wallyllamaW Offline
                                    wallyllama
                                    wrote on last edited by wallyllama
                                    #37
                                    @MasterCATZ said in help needed with multiple temp sensor data logging project:
                                    The big "con" is the risk that someone will come along and try to use it in a standard way.
                                    There is a function that tells all the sensors to start a temperature conversion, you could then read each one individually. So it would be 750ms + (60 * pollingtime) to get them all. I dont know if you trade speed for reliability or not. You may be able to interleave conversion requests and polling.
                                    Convreq1 poll30 convreq2 poll31 8convreq3 poll 32 .... convreq 60 poll29 - loop
                                    Maybe overkill if 1 reading per minute is enough
                                    12.2k
