  3. 💬 NRF52 Recessed Vibration+Contact sensor for door/window
doorcontactnrf52accelerometerrecessedhall effect
24 Posts 10 Posters 9.7k Views 10 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/434/NRF52-Recessed-VibrationContact-sensor-for-doorwindow
    TerrenceT 1 Reply Last reply
    • scalzS
      scalzS
      wrote on last edited by scalz
      Work in progress ;)
      I'm waiting for pcb and should get them soon as they have been shipped. can't wait to try this new board and compare range with my Aeos custom antenna board :)
      If performing well, then i may ask to a fabhouse for PCBA, as it should be a "cheap" board.
      • NeverDieN
        NeverDieN
        Nice work!
        • Nca78N
          Nca78N
          This is getting really small, it's great to get power consumption low enough to be able to use a CR1632 for a long time.
          • d00616D
            d00616D
            d00616
            Wow. Looks perfect.
            • openhardware.ioO openhardware.io
              TerrenceT
              TerrenceT
              Terrence
              @openhardware.io So, I have been looking for a way to determine if a door lock was locked. Is this that?
              • d00616D
                d00616D
                d00616
                @scalz Is your plan is to drill a hole into the window frame and put this board in?
                Most modern windows here in Germany have enough space between the inner and outer windows frame to place a flat board between. My windows have a slot of ~1,8cm and my door of ~1,2cm.
                • scalzS
                  scalzS
                  @Terrence it's for detecting intrusion, if the door is opened or not. The accelerometer for detecting vibration, if intrusion is in progress (before door is opened)
                  @d00616 yes, planning something like that for the drills: (pic from internet)
                  For my house, or some of my friends, that would work well, some others not. when that's the case, i'll use my aeos board as a common door sensor.
                  Do you mean you would need a smaller board?
                  d00616D 1 Reply Last reply
                  • scalzS scalz
                    d00616D
                    d00616D
                    d00616
                    @scalz I mean this: https://shopdelta.eu/wireless-window-opening-detector-ja-82m-jablotron_l2_p6386.html Looks like fitting in doors and windows following European standards.
                    Most new plastic doors and windows in Germany looking like this. The metal at the right side can surround the window.
                    0_1500278243527_upload-945536a0-dbd1-4fcd-a2ec-ea69fde609f6
                    Graphical view of another frame: http://www.focuswindows.com/product/eurocell-eurologik-70mm/
                    BTW. your board is perfect to put it into a little capsule and fixating it with silicone at the glass or at the frame.
                    • scalzS
                      scalzS
                      @d00616 oki. I didn't know these ones. will think about it.
                      So far my WIP enclosure for this project is:
                      • scalzS
                        scalzS
                        @d00616 the sensor you showed me above is 25mm width?? so it's bigger to fit, right?
                        • scalzS scalz
                          d00616D
                          d00616D
                          d00616
                          @scalz said in 💬 NRF52 Recessed Vibration+Contact sensor for door/window:
                          The width doesn't matter in that dimension. There is a space for an object with a with of 4cm and a height of 1cm.
                          • d00616D
                            d00616D
                            d00616
                            @scalz You don't need to change your design for me ;-)
                            This is another concept for windows.
                            http://www.eq-3.com/products/homematic/heating-and-climate-control/homematic-wireless-window-rotary-handle-sensor.html
                            • scalzS
                              scalzS
                              Here is a pic of this very tiny door sensor with accelerometer for vibration detection. crazy!
                              Handsoldered this one! and working well, yay :)
                              Need to print a box for this one and install it in a door..
                              • F
                                F
                                Fabien
                                Can't wait for pcb publishing !
                                • F
                                  F
                                  Fabien
                                  Why did you use LIS3DH ? ADXL362 seems to be better. You can have 100 mesures / second with 2uA consumption according to this : https://ez.analog.com/docs/DOC-15838
                                  Nca78N 1 Reply Last reply
                                  • F Fabien
                                    Nca78N
                                    Nca78N
                                    @Fabien said in 💬 NRF52 Recessed Vibration+Contact sensor for door/window:
                                    I asked myself the same question, then I checked the prices and if you want it in small quantities from a reputable source, LIS3DH is 1/4 of the price (1.5$ compared to 6$) while keeping a "low enough" power consumption.
                                    ADXL362 is much cheaper on AliExpress but when best price seen on octopart is over 3$ from a non authorized distributor I'm a bit suspicious when seeing prices just over 2$...
                                    • scalzS
                                      scalzS
                                      i remember of this one ;)
                                      i did this because:
                                      • i have lis3dh in stock and wanted to validate my idea.
                                      • cost. LIS3DH is one of the cheapest and low power accelerometer
                                      • fabhouse usually source at known suppliers in case of pcba, and the adxl is not very cheap.
                                      • I2C because it was really very tight to route the pcb regarding the very small size, and without signals vias on bottom touching gnd coincell (and i'm not fan of tabbed coincell.. ) . SPI would have needed more pins to route
                                      • it is mainly for detecting tilts on door intrusion or knocks. I didn't need a very precise accelerometer for motion.
                                      • I wanted to make a very cheap but reliable door sensor. I think goal is achieved :)
                                      Too much work actually, plus received some new launchpads to evaluate, i also need to assemble some of my new boards for the faire etc., so, i'm not sure yet when, but i'll take a look whether the adxl would fit, in case you really need it ;)
                                      korttomaK 1 Reply Last reply
                                      • scalzS scalz
                                        i did this because:
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        @scalz is there any chance that one could buy this device preassembled from you?
                                        I was thinking I could use something really tiny as a one button scene controller and found your design.
                                        Maybe you can even leave out some components in my case to keep the effort and cost down?
                                        Or do you have some other design that would fit my purpose (small one-button scene controller)?
                                        • Tomas
                                        • korttomaK korttoma
                                          Nca78N
                                          Nca78N
                                          @korttoma said in 💬 NRF52 Recessed Vibration+Contact sensor for door/window:
                                          Hello Tomas, I have bought one of those. They are over 20mm diameter so not as small as the one from @scalz but still pretty small and they have a physical button + a led (and an unpopulated footprint for an accelerometer, too).
                                          This is the one I bought but there are many seller, I hope with a better price as when I bought it, I paid less than 4€ and shipping included. I have received mine but not tested programming it yet, if you want me to confirm there's no problem to reprogram it I'll can check it during the week.
                                          https://www.aliexpress.com/item/2V-3-3V-NRF51822-Bluetooth-4-0-Wireless-Module-For-iBeacon-Base-Station-Intelligent-Control-System/32824004498.html
                                          korttomaK NeverDieN 2 Replies Last reply
