  3. OpenHAB
  4. openHAB 2.2 binding
openHAB 2.2 binding
132 Posts 32 Posters 89.6k Views 34 Watching
  • mythbaiM
    mythbaiM
    mythbai
    After upgrade OH to 2.2 stable release. (2.2_01). I'm having the same issue that zwave binding not working. After Mysensors binding is installed and gateway configured. There is only one serial port visiable in PaperUI, which is /dev/ttyUSB0 that is configured for the serial gateway. I'm using org.openhab.binding.mysensors-2.2.0-SNAPSHOT-serial-fix.jar.
    Also the old 2.1 snapshot version doesn't work either. anyone else experience this issue?
    mythbaiM 1 Reply Last reply
    • jocke4uJ
      jocke4uJ
      jocke4u
      I have issues with MySensors and specifically Energy Sensors where they request latest value.
      See this thread for details: https://forum.mysensors.org/topic/8833/power-sensors-stopped-working
      Any idea how to solve it?
      • L
        L
        lesockz
        iam using "openHAB 2.2.0-1 (Release Build)" as openhabian on a PI3.
        i've installed "org.openhab.binding.mysensors-2.2.0-SNAPSHOT.jar" as explained in the instructions.
        configured the thing "MySensors Serial Gateway" to use "/dev/ttyACM0" with Baudrate "38400" because i'm using a pro micro with 8Mhz which isn't capable of 115200 (as far as i know).
        the Items got discovered fine.
        Atm i have only one item with
        #define CHILD_ID_TEMP 0
        unsigned long SLEEP_TIME = 3 * 1000; // Sleep time between reads (in milliseconds)
        MyMessage tempMsg(CHILD_ID_TEMP, S_TEMP);
        Presentation:
          sendSketchInfo("Temp/Hum/Pre Sensor", "1.2");
        and Loop:
          unsigned long currentTime = millis();
          temperature++;//bme.readTemperature();
            lastSend = currentTime;
            send(tempMsg.set(temperature, 2));
            lastTemp = temperature;
          sleep(SLEEP_TIME);
        This is my debug from "openhab-cli showlogs"
        2018-01-07 13:59:17.676 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;6;109.00
        2018-01-07 13:59:17.680 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
        2018-01-07 13:59:17.683 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
        2018-01-07 13:59:17.687 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
        And this from Log Viewer
        2018-01-07 14:00:18.836 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
        2018-01-07 14:00:18.841 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
        2018-01-07 14:00:18.846 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
        2018-01-07 14:00:27.561 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=6,pt=7,l=5,sg=0:117.00
        2018-01-07 14:00:27.566 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;6;117.00
        2018-01-07 14:00:27.572 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
        2018-01-07 14:00:27.577 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
        2018-01-07 14:00:27.582 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
        2018-01-07 14:00:36.301 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=6,pt=7,l=5,sg=0:118.00
        2018-01-07 14:00:36.308 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;6;118.00
        2018-01-07 14:00:36.311 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
        2018-01-07 14:00:36.315 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
        2018-01-07 14:00:36.318 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
        2018-01-07 14:00:45.034 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=6,pt=7,l=5,sg=0:119.00
        2018-01-07 14:00:45.037 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;6;119.00
        2018-01-07 14:00:45.039 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
        2018-01-07 14:00:45.042 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
        2018-01-07 14:00:45.045 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_RAIN not present
        So from log i can see Temp is counting up. but in "Paper Ui"
        i always get "Temperature -NaN °C" or "Temperature 0 °C"
        Please correct me if this is the wrong place for this question.
        Greets Andi
        T 1 Reply Last reply
        • mythbaiM mythbai
          mythbaiM
          mythbaiM
          mythbai
          @mythbai said in openHAB 2.2 binding:
          Up my own post. Not many users are using Zwave dongle and Mysensors at the same time? I feel this forum or trend is dead... This problem is driving me crazy, render all my mysensors useless. I'm trying to build a ethernet gateway now...
          T 2 Replies Last reply
          • mythbaiM mythbai
            TimO
            Hey @mythbai !
            Could you please download and install the most recent version of the binding? I've not changed anything at the serial code, but while we're trying to figure out the problem, we should be on the same base of code. :-)
            I too have two serial devices connected to my OpenHAB box, one serial MySensors gateway and one Ebus-Adapter to Ebusd.
            You may need to execute:
            feature:install esh-io-transport-mqtt
            Because the most current version of the binding now supports MQTT gateways.
            • L lesockz
              Presentation:
              and Loop:
                sleep(SLEEP_TIME);
              Greets Andi
              TimO
              Hello @lesockz !
              Well your node is sending V_RAIN instead of V_TEMP, so OpenHAB is not able to work with that.
              Try:
              MyMessage tempMsg(CHILD_ID_TEMP, V_TEMP);
              For presentation S_TEMP (== 6) is used, while for set messages V_TEMP (==0) is used.
              • mythbaiM mythbai
                TimO
                wrote on last edited by TimO
                #87
                @mythbai While the code for the serial connection in the binding was unchanged for a while it definatly issn't working now together with zwave binding.
                Some time ago I've prepared a change of the serial library the binding is using. A few first tests looked promising but I didn't find the time to test it. So lets give it a new try: could you please test this binding: OH2 Binding with Serial Refactoring
                Please remove the old binding with bundle:list, bundle:remove ID before installing the new one.
                • jocke4uJ
                  jocke4uJ
                  jocke4u
                  I am moving the topic here as more appropriate :) (old ref)
                  I have OH v2.2 and latest MySensors 2.2.0 binding and my power sensors have stopped working.
                  After some investigation it seems they cannot receive the old pulse count value and by that cannot start working.
                  MySensors GW running 2.1.1 and the one power sensor I am testing also 2.1.1 (the rest 1.5.x)
                  The debug (serial monitor) of the sensor shows that
                  3 TSM:INIT
                  4 TSF:WUR:MS=0
                  11 TSM:INIT:TSP OK
                  13 TSM:INIT:STATID=5
                  14 TSF:SID:OK,ID=5
                  16 TSM:FPAR
                  52 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2060 !TSM:FPAR:NO REPLY
                  2062 TSM:FPAR
                  2098 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2983 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  2989 TSF:MSG:FPAR OK,ID=0,D=1
                  4106 TSM:FPAR:OK
                  4107 TSM:ID
                  4108 TSM:ID:OK
                  4110 TSM:UPL
                  4147 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  6154 TSM:UPL
                  6159 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=OK:1
                  6168 TSF:MSG:READ,0-0-5,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  6173 TSF:MSG:PONG RECV,HP=1
                  6175 TSM:UPL:OK
                  6177 TSM:READY:ID=5,PAR=0,DIS=1
                  6182 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  6189 TSF:MSG:READ,0-0-5,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  6232 !TSF:MSG:SEND,5-5-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
                  6243 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=OK:0
                  6259 TSF:MSG:READ,0-0-5,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  6305 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=NACK:Heater Energy
                  6349 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=NACK:2.0
                  6391 !TSF:MSG:SEND,5-5-0-0,s=0,c=0,t=13,pt=0,l=0,sg=0,ft=2,st=NACK:
                  6397 MCO:REG:REQ
                  6435 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=NACK:2
                  8476 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=NACK:2
                  10486 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=OK:2
                  10493 TSF:MSG:READ,0-0-5,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  10499 MCO:PIM:NODE REG=1
                  10501 MCO:BGN:STP
                  10528 TSF:MSG:SEND,5-5-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                  Got Pulse
                  10534 MCO:BGN:INIT OK,TSP=1
                  Got Pulse
                  Got Pulse
                  Got Pulse
                  Got Pulse
                  Got Pulse
                  Got Pulse
                  No count received. Try requesting it again
                  30570 !TSF:MSG:SEND,5-5-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=NACK:
                  Got Pulse
                  Got Pulse
                  Got Pulse
                  Got Pulse
                  Got Pulse
                  Got Pulse
                  Got Pulse
                  50546 TSF:MSG:SEND,5-5-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=1,st=OK:
                  Got Pulse
                  The sketch looks like this:
                   * Version 1.0 - Henrik EKblad
                   * This sketch provides an example how to implement a distance sensor using HC-SR04
                   * Use this sensor to measure KWH and Watt of your house meeter
                   * You need to set the correct pulsefactor of your meeter (blinks per KWH).
                   * The sensor starts by fetching current KWH value from gateway.
                   * Reports both KWH and Watt back to gateway.
                   * Unfortunately millis() won't increment when the Arduino is in
                   * sleepmode. So we cannot make this sensor sleep if we also want
                   * to calculate/report watt-number.
                   * http://www.mysensors.org/build/pulse_power
                  // Enable debug prints
                  #define MY_NODE_ID 5
                  #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                  #define PULSE_FACTOR 1000       // Nummber of blinks per KWH of your meeter
                  #define MAX_WATT 10000          // Max watt value to report. This filetrs outliers.
                  #define CHILD_ID 0              // Id of the sensor child
                  unsigned long SEND_FREQUENCY =
                      20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                  double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
                  bool pcReceived = false;
                  volatile unsigned long watt = 0;
                  unsigned long oldWatt = 0;
                  double oldKwh;
                  unsigned long lastSend;
                  MyMessage wattMsg(CHILD_ID,V_WATT);
                  MyMessage kwhMsg(CHILD_ID,V_KWH);
                    request(CHILD_ID, V_VAR1);
                    // Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
                    // If no pullup is used, the reported usage will be too high because of the floating pin
                    pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                    attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                    lastSend=millis();
                    sendSketchInfo("Heater Energy", "2.0");
                    present(CHILD_ID, S_POWER);
                    unsigned long now = millis();
                    bool sendTime = now - lastSend > SEND_FREQUENCY;
                    if (pcReceived && sendTime) {
                      // New watt value has been calculated
                      if (watt != oldWatt) {
                        // Check that we dont get unresonable large watt value.
                        // could hapen when long wraps or false interrupt triggered
                        if (watt<((unsigned long)MAX_WATT)) {
                          send(wattMsg.set(watt));  // Send watt value to gw
                        Serial.print("Watt:");
                        Serial.println(watt);
                        oldWatt = watt;
                      // Pulse cout has changed
                      if (pulseCount != oldPulseCount) {
                        send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                        double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                        oldPulseCount = pulseCount;
                        if (kwh != oldKwh) {
                          send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                          oldKwh = kwh;
                      lastSend = now;
                    } else if (sendTime && !pcReceived) {
                      // No count received. Try requesting it again
                      Serial.println("No count received. Try requesting it again");
                      lastSend=now;
                    Serial.print("MessageType:");
                    Serial.println(message.type);
                    Serial.print("Message:");
                    Serial.println(message.getLong());
                    if (message.type==V_VAR1) {
                      Serial.println(pulseCount);
                      pcReceived = true;
                  void onPulse()
                    Serial.println("Got Pulse");
                    unsigned long interval = newBlink-lastBlink;
                    if (interval<10000L) { // Sometimes we get interrupt on RISING
                      return;
                    watt = (3600000000.0 /interval) / ppwh;
                    lastBlink = newBlink;
                    pulseCount++;
                  Today I realized that I likely need to have item(s) created in OH to save the values - so created Var1 (and then added one after another with no success). Currently it looks like:
                  Number CellarAirHeaterSensorWatt   "Airheater Watt" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:watt", mqtt=">[rabbitmq:/myhouse/airpump/sensor/power:state:*:Power,sensor=${itemName},location=airpump watt=${state} ]" }
                  Number CellarAirHeaterSensorKwh    "Airheater Kwh" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:kwh", mqtt=">[rabbitmq:/myhouse/airpump/sensor/power:state:*:Power,sensor=${itemName},location=airpump kwh=${state} ]" }
                  Number CellarAirHeaterSensorVar   "Airheater Var" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:var" }
                  Number CellarAirHeaterSensorVar1   "Airheater Var1" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:var1" }
                  Number CellarAirHeaterSensorVA   "Airheater VA" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:va" }
                  Still no success!
                  Do you have any idea what's wrong?
                  • T TimO
                    mythbaiM
                    mythbaiM
                    mythbai
                    @timo said in openHAB 2.2 binding:
                    @TimO Thank you very much! Here is what I got with the new jar:
                    Initial bundle:uninstall, and replace jar works. But after server reboot, the MySensor binding is not loading due to some "Multiexception" on framework level (sorry didn't capture that log).
                    I tried to restart binding in console:
                    openhab> bundle:restart 233
                    Error executing command: Error restarting bundles:
                            Unable to start bundle 233: Could not resolve module: org.openhab.binding.mysensors [233]
                      Unresolved requirement: Import-Package: org.eclipse.smarthome.io.transport.mqtt
                    This is an easy fix by "feature:install openhab-transport-mqtt". And after that bundle works! (why do I have to install mqtt transport here .... )
                    2). After fix above, did a server reboot. Got MySensors thing discovery related exceptions, but both zwave and mysensors binding loaded, and things got online. The fix actually works!!! just with some minor glitch:
                    09:04:38.710 [ERROR] [org.openhab.binding.mysensors        ] - [org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService(221)] Error during instantiation of the implementation object
                    java.lang.InstantiationException: org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService
                            at java.lang.Class.newInstance(Class.java:427) [?:?]
                            at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:237) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [42:org.apache.felix.scr:2.0.12]
                            at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
                            at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
                            at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
                            at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
                            at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
                            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
                            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
                            at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
                            at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2201) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1714) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1699) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:372) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:320) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [42:org.apache.felix.scr:2.0.12]
                            at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
                            at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
                            at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
                            at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
                            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
                            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
                            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
                            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
                            at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
                            at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [42:org.apache.felix.scr:2.0.12]
                            at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [42:org.apache.felix.scr:2.0.12]
                            at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
                            at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
                            at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
                            at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
                            at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
                            at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
                            at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
                            at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
                            at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
                            at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
                            at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
                            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
                            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
                            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
                            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
                            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
                            at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
                    Caused by: java.lang.NoSuchMethodException: org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService.<init>()
                            at java.lang.Class.getConstructor0(Class.java:3082) ~[?:?]
                            at java.lang.Class.newInstance(Class.java:412) ~[?:?]
                            ... 70 more
                    09:04:39.069 [WARN ] [org.openhab.binding.mysensors        ] - FrameworkEvent WARNING - org.openhab.binding.mysensors
                    org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
                            at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) [?:?]
                    It's a good start, I now have all my sensors working now!
                    • mythbaiM mythbai
                              ... 70 more
                      TimO
                      @mythbai Thank you for reporting back! I'm glad it is working now.
                      The transport-mqtt feature is now needed because the support for MQTT GW is now part of the binding and the fix I've provided to you is based on the current code base.
                      The exception is completely unrelated to your problem and will do no harm. It only occures on startup and will soon be fixed!
                      • jocke4uJ jocke4u
                        3 TSM:INIT
                        4 TSF:WUR:MS=0
                        11 TSM:INIT:TSP OK
                        14 TSF:SID:OK,ID=5
                        16 TSM:FPAR
                        2062 TSM:FPAR
                        4106 TSM:FPAR:OK
                        4107 TSM:ID
                        4108 TSM:ID:OK
                        4110 TSM:UPL
                        6154 TSM:UPL
                        6175 TSM:UPL:OK
                        6397 MCO:REG:REQ
                        10501 MCO:BGN:STP
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        Got Pulse
                        double oldKwh;
                          lastSend=millis();
                              oldWatt = watt;
                                oldKwh = kwh;
                            lastSend = now;
                            lastSend=now;
                            pcReceived = true;
                        void onPulse()
                            return;
                          pulseCount++;
                        Still no success!
                        TimO
                        #91
                        @jocke4u The request needs to be handled with rules because it is not allowed to access the value of an item via the binding API :smirk:.
                        Please post the request (from the OpenHAB log, enable DEBUG with log:set DEBUG org.openhab.binding.mysensors if not already done in the karaf console) and we'll figure out the rule.
                        NickBuilderN jocke4uJ 2 Replies Last reply
                        • T TimO
                          NickBuilderN
                          NickBuilderN
                          NickBuilder
                          wrote on last edited by NickBuilder
                          #92
                          @timo regarding the issue with the pulse power node, the same as @jocke4u. I'm using a version of the same sketch and also the latest snapshot jar.
                          This is the feedback in my openhab.log while looking att the debug level messages from the binding.
                          15:59:15.829 [WARN ] [ors.internal.gateway.MySensorsGateway] - Request received, but variable state is not yet defined
                          15:59:15.834 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 50;1;2;0;24;
                          15:59:15.839 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 50 found in gateway
                          15:59:15.844 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 50
                          15:59:15.849 [WARN ] [ors.internal.gateway.MySensorsGateway] - Request received, but variable state is not yet defined
                          15:59:15.854 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 50;1;2;0;24;
                          15:59:15.859 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 50 found in gateway
                          15:59:15.864 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 50
                          15:59:15.869 [WARN ] [ors.internal.gateway.MySensorsGateway] - Request received, but variable state is not yet defined
                          15:59:15.874 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 50;1;2;0;24;
                          15:59:15.879 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 50 found in gateway
                          As you can see the messages are quite frequent making it quite tedious for me to extract the relevant log messages. I'm no expert in browsing and searching text files from the command line.
                          I guess because I'm using a version of the standard sketch my node does not wait for a response to the request before starting to count. I'm not sure how the node can neglect the response. Anyhow I restarted my node and now it tried to SET a new count instead.
                          2018-01-10 16:26:22.341 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
                          2018-01-10 16:26:22.571 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
                          2018-01-10 16:26:22.791 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
                          2018-01-10 16:26:23.011 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
                          2018-01-10 16:26:23.230 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
                          Hopefully this is useful feedback.
                          jocke4uJ 1 Reply Last reply
                          • T TimO
                            jocke4uJ
                            jocke4uJ
                            jocke4u
                            Hi @timo ,
                            Here is the log when restarting the sensor:
                            17:27:58.562 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;0;0;17;2.1.1
                            17:27:58.573 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Presentation Message received
                            17:27:58.583 [WARN ] [ors.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                            17:27:58.593 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;3;0;6;0
                            17:27:58.603 [DEBUG] [ors.internal.gateway.MySensorsGateway] - I_CONFIG request received from M, answering: (is imperial?)false
                            17:27:58.614 [DEBUG] [orsAbstractConnection$MySensorsWriter] - Sending to MySensors: 5;255;3;0;6;M
                            17:27:58.674 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;3;0;11;Heater Energy
                            17:27:58.682 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;3;0;12;2.0
                            17:27:58.690 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;0;0;0;13;
                            17:27:58.698 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Presentation Message received
                            17:27:58.705 [WARN ] [ors.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                            17:27:58.719 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;0;2;0;24;
                            17:27:58.727 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 5 found in gateway
                            17:27:58.735 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 0 found in node 5
                            17:27:58.743 [WARN ] [ors.internal.gateway.MySensorsGateway] - Request received, but variable state is not yet defined
                            • NickBuilderN NickBuilder
                              jocke4uJ
                              jocke4uJ
                              jocke4u
                              @nickbuilder Check the code here and there is a SEND_FREQUENCY of 20 sec - would reduce the load quite a lot :)
                              • T
                                TimO
                                @jocke4u & @NickBuilder :
                                Thank you! This will help me to find a solution. For reference, here is the corresponding issue on github: https://github.com/tobof/openhab2-addons/issues/69
                                • T TimO
                                  jocke4uJ
                                  jocke4uJ
                                  jocke4u
                                  @timo Ok, so there is a plan to solve it in a better way than using rules?
                                  Do you have any guidance of using rules until then?
                                  T NickBuilderN 2 Replies Last reply
                                  • jocke4uJ jocke4u
                                    TimO
                                    @jocke4u I'll try to document an example for using rules tomorrow. I'm not yet sure about the best final solution. Maybe I'll experiment with persistence within the binding.
                                    • L
                                      L
                                      LastSamurai
                                      wrote on last edited by LastSamurai
                                      #98
                                      @TimO Today I decided to finally read into how Openhab binding development works. And just when I started I saw that you finally fixed some of the problems that I reported via github (thank you very much for that). Had to laugh a little at that coincidence :rolling_on_the_floor_laughing:
                                      I just started a pullrequest where I tried to implement pure white colors for RGBW values fixing one of my problems left open. If you find the time please have a look at it. I did not yet write any tests for it or test it on my actual RGBW nodes but I will do that as soon as possible
                                      • K
                                        K
                                        kwull
                                        wrote on last edited by kwull
                                        #99
                                        [Solved] I've solved the issue by changing docker base image. The issue described here - https://github.com/openhab/openhab-docker/issues/144
                                        I'll keep the details for others:
                                        @TimO, thanks for the great openhab binding. I've used it on openhab 2.0 and it works just great. Now I have totally fresh openhab 2.2 setup and cannot make mysensors binding working. I've tried many things but with no luck. Can you point me into direction how to fix that?
                                        The gateway works as expected:
                                        root@machine:/home/kwull# cat /dev/ttyUSB0
                                        0;1;1;0;0;22.3
                                        0;0;1;0;1;23.0
                                        0;255;0;0;18;2.1.1
                                        0;255;3;0;11;Garage Gateway
                                        0;255;3;0;12;1.0
                                        0;0;0;0;7;
                                        0;1;0;0;6;
                                        0;1;1;0;0;23.1
                                        0;0;1;0;1;22.1
                                        Bindings:
                                        25 │ Active   │  80 │ 3.12.0.OH              │ nrjavaserial
                                        210 │ Active   │  80 │ 1.0.2                  │ Paho MQTT Client
                                        211 │ Active   │  80 │ 0.10.0.b1              │ Eclipse SmartHome MQTT Transport Bundle
                                        214 │ Active   │  80 │ 2.3.0.201801160936     │ MySensors Binding
                                        openhab.log:
                                        2018-01-21 17:18:33.696 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                                        2018-01-21 17:18:33.703 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                                        2018-01-21 17:18:33.704 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
                                        2018-01-21 17:18:33.710 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
                                        2018-01-21 17:18:33.712 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
                                        2018-01-21 17:18:33.715 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=325, service.bundleid=214, service.scope=singleton} - org.openhab.binding.mysensors
                                        2018-01-21 17:18:33.716 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                                        2018-01-21 17:18:33.716 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                                        2018-01-21 17:18:36.027 [WARN ] [org.jline                           ] - Unable to create a system terminal, creating a dumb terminal (enable debug logging for more information)
                                        Exception log:
                                        Current thread (0x000055797e792800):  JavaThread "org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection" [_thread_in_native, id=641, stack(0x00007f12eb309000,0x00007f12eb409aa8)]
                                        siginfo: si_signo: 11 (SIGSEGV), si_code: 1 (SEGV_MAPERR), si_addr: 0x00000000000037a6
                                        Registers:
                                        RAX=0x0000000000000000, RBX=0x00007f12e7403940, RCX=0x00007f13197e3f04, RDX=0x00007f131934828c
                                        RSP=0x00007f12eb407d48, RBP=0x0000000000000001, RSI=0x0000000000000900, RDI=0x000055797ccb99a0
                                        R8 =0x000055797ccb99ac, R9 =0x000055797ccb99a0, R10=0x00000006d600e9d0, R11=0x0000000000000206
                                        R12=0x000055797ccb99a0, R13=0x000055797e7929e0, R14=0x00007f12eb407ec8, R15=0x0000000000000082
                                        RIP=0x00000000000037a6, EFLAGS=0x0000000000010202, CSGSFS=0x0000000000000033, ERR=0x0000000000000014
                                          TRAPNO=0x000000000000000e
                                        Top of Stack: (sp=0x00007f12eb407d48)
                                        0x00007f12eb407d48:   00007f12e64e0965 00007f12eb407de8
                                        0x00007f12eb407d58:   00007f1300000001 00007f12e7403940
                                        0x00007f12eb407d68:   000055797e792800 00007f12e7403940
                                        0x00007f12eb407d78:   d85a256e98c0817f 00007f12eb407de8
                                        0x00007f12eb407d88:   00007f1318b46afc 00007f12eb407de8
                                        0x00007f12eb407d98:   00007f12eb407dc8 00007f12eb407de8
                                        0x00007f12eb407da8:   00007f1318b46b68 000055797e792800
                                        0x00007f12eb407db8:   00007f1318c99928 0000557981a9a5f0
                                        0x00007f12eb407dc8:   000055797e792800 000055797e792800
                                        0x00007f12eb407dd8:   00007f12e7403940 000055797e792800
                                        0x00007f12eb407de8:   00007f12e7403940 000055797e792800
                                        0x00007f12eb407df8:   d85a256e98c0817f 00007f12e7403940
                                        0x00007f12eb407e08:   00007f12e7403940 00007f12eb407ea0
                                        0x00007f12eb407e18:   0000000000000000 00007f12e7403940
                                        0x00007f12eb407e28:   00007f12eb407ed0 000055797e792800
                                        0x00007f12eb407e38:   00007f1308ccd7f4 00007f12eb407ea0
                                        0x00007f12eb407e48:   00007f1308ccd579 fffffffe00000000
                                        0x00007f12eb407e58:   00007f1308ccd542 00007f12eb407e60
                                        0x00007f12eb407e68:   00007f12e7403940 00007f12eb407ed0
                                        0x00007f12eb407e78:   00007f12e7405c28 0000000000000000
                                        0x00007f12eb407e88:   00007f12e7403940 0000000000000000
                                        0x00007f12eb407e98:   00007f12eb407ec0 00007f12eb407f18
                                        0x00007f12eb407ea8:   00007f1308cbd7d0 0000000000000000
                                        0x00007f12eb407eb8:   00007f1308cc7260 0000000000000001
                                        0x00007f12eb407ec8:   00000006d600e9a8 00000006d600b490
                                        0x00007f12eb407ed8:   00007f12eb407ed8 00007f12e7404122
                                        0x00007f12eb407ee8:   00007f12eb407f98 00007f12e7405c28
                                        0x00007f12eb407ef8:   0000000000000000 00007f12e7404270
                                        0x00007f12eb407f08:   00007f12eb407ec0 00007f12eb407f80
                                        0x00007f12eb407f18:   00007f12eb407fe0 00007f1308cbdffd
                                        0x00007f12eb407f28:   0000000000000000 0000000000000000
                                        0x00007f12eb407f38:   0000000000000000 00000006d600e9a8
                                        Instructions: (pc=0x00000000000037a6)
                                        0x0000000000003786:
                                        [error occurred during error reporting (printing registers, top of stack, instructions near pc), id 0xb]
                                        Register to memory mapping:
                                        RAX=0x0000000000000000 is an unknown value
                                        RBX={method} {0x00007f12e7403940} 'testRead' '(Ljava/lang/String;I)Z' in 'gnu/io/RXTXCommDriver'
                                        RCX=0x00007f13197e3f04: getpid+0x7 in /lib/ld-musl-x86_64.so.1 at 0x00007f131978d000
                                        RDX=0x00007f131934828c: gHotSpotVMStructs+0x218f4 in /usr/lib/jvm/java-1.8-openjdk/jre/lib/amd64/server/libjvm.so at 0x00007f1318861000
                                        RSP=0x00007f12eb407d48 is pointing into the stack for thread: 0x000055797e792800
                                        RBP=0x0000000000000001 is an unknown value
                                        RSI=0x0000000000000900 is an unknown value
                                        RDI=0x000055797ccb99a0 is an unknown value
                                        R8 =0x000055797ccb99ac is an unknown value
                                        R9 =0x000055797ccb99a0 is an unknown value
                                        R10=0x00000006d600e9d0 is pointing into object: 0x00000006d600e9c0
                                        [C
                                         - klass: {type array char}
                                         - length: 12
                                        R11=0x0000000000000206 is an unknown value
                                        R12=0x000055797ccb99a0 is an unknown value
                                        R13=0x000055797e7929e0 is an unknown value
                                        R14=0x00007f12eb407ec8 is pointing into the stack for thread: 0x000055797e792800
                                        R15=0x0000000000000082 is an unknown value
                                        Stack: [0x00007f12eb309000,0x00007f12eb409aa8],  sp=0x00007f12eb407d48,  free space=1019k
                                        Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
                                        C  0x00000000000037a6
                                        Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
                                        j  gnu.io.RXTXCommDriver.testRead(Ljava/lang/String;I)Z+0
                                        j  gnu.io.RXTXCommDriver.registerValidPorts([Ljava/lang/String;[Ljava/lang/String;I)V+202
                                        j  gnu.io.RXTXCommDriver.registerScannedPorts(I)V+1466
                                        j  gnu.io.RXTXCommDriver.initialize()V+35
                                        j  gnu.io.CommPortIdentifier.getPortIdentifiers()Ljava/util/Enumeration;+53
                                        j  gnu.io.NativeResource.testNativeCode()V+0
                                        j  gnu.io.NativeResource.inJarLoad(Ljava/lang/String;)V+37
                                        j  gnu.io.NativeResource.loadLib(Ljava/lang/String;)V+54
                                        j  gnu.io.NativeResource.load(Ljava/lang/String;)V+138
                                        j  gnu.io.SerialManager.<init>()V+23
                                        j  gnu.io.SerialManager.getInstance()Lgnu/io/SerialManager;+10
                                        j  gnu.io.RXTXCommDriver.<clinit>()V+39
                                        v  ~StubRoutines::call_stub
                                        J 1368  java.lang.Class.forName0(Ljava/lang/String;ZLjava/lang/ClassLoader;Ljava/lang/Class;)Ljava/lang/Class; (0 bytes) @ 0x00007f1309151eba [0x00007f1309151e40+0x7a]
                                        J 3010 C1 java.lang.Class.forName(Ljava/lang/String;)Ljava/lang/Class; (15 bytes) @ 0x00007f13096ee94c [0x00007f13096ee7a0+0x1ac]
                                        j  gnu.io.CommPortIdentifier.<clinit>()V+12
                                        j  org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialConnection.establishConnection()Z+32
                                        j  org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.connect()Z+2
                                        j  org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.run()V+46
                                        J 10253 C2 java.util.concurrent.Executors$RunnableAdapter.call()Ljava/lang/Object; (14 bytes) @ 0x00007f1309884cac [0x00007f1309884c60+0x4c]
                                        J 9236 C1 java.util.concurrent.FutureTask.runAndReset()Z (128 bytes) @ 0x00007f130a4cd17c [0x00007f130a4ccf00+0x27c]
                                        J 9408 C1 java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run()V (59 bytes) @ 0x00007f130a57bb8c [0x00007f130a57b600+0x58c]
                                        J 8894 C1 java.util.concurrent.ThreadPoolExecutor.runWorker(Ljava/util/concurrent/ThreadPoolExecutor$Worker;)V (225 bytes) @ 0x00007f130a3b8e3c [0x00007f130a3b7e00+0x103c]
                                        j  java.util.concurrent.ThreadPoolExecutor$Worker.run()V+5
                                        J 11172 C1 java.lang.Thread.run()V (17 bytes) @ 0x00007f1308f58584 [0x00007f1308f58440+0x144]
                                        Additional logs:
                                        2018-01-08 20:55:18.426 [ERROR] [org.openhab.binding.mysensors       ] - [org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService(195)] Error during instantiation of the implementation object
                                        	at java.lang.Class.newInstance(Class.java:427) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:237) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) ~[?:?]
                                        	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
                                        	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
                                        	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
                                        	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
                                        	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) ~[?:?]
                                        	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
                                        	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) ~[?:?]
                                        	at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
                                        	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
                                        	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
                                        	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
                                        	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
                                        	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
                                        	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
                                        	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) ~[?:?]
                                        	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
                                        	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
                                        	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
                                        	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
                                        	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
                                        	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
                                        	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) ~[?:?]
                                        	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) ~[?:?]
                                        	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) ~[?:?]
                                        	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) ~[?:?]
                                        	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) ~[?:?]
                                        	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) ~[?:?]
                                        	at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) ~[?:?]
                                        	at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) ~[?:?]
                                        	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
                                        	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
                                        	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
                                        	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
                                        	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) ~[?:?]
                                        	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
                                        	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
                                        	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
                                        	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) ~[?:?]
                                        	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
                                        	at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
                                        	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
                                        	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[?:?]
                                        	at org.eclipse.smarthome.extensionservice.marketplace.internal.BindingExtensionHandler.install(BindingExtensionHandler.java:82) ~[?:?]
                                        	at org.eclipse.smarthome.extensionservice.marketplace.internal.MarketplaceExtensionService.install(MarketplaceExtensionService.java:222) ~[?:?]
                                        	at org.eclipse.smarthome.io.rest.core.internal.extensions.ExtensionResource.lambda$0(ExtensionResource.java:157) ~[?:?]
                                        	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:?]
                                        	at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:?]
                                        	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:?]
                                        	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:?]
                                        	at java.lang.Thread.run(Thread.java:748) [?:?]
                                        	... 65 more
                                        2018-01-08 20:55:18.450 [WARN ] [org.openhab.binding.mysensors       ] - FrameworkEvent WARNING - org.openhab.binding.mysensors
                                        	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
                                        Any ideas where to look?
                                        K 1 Reply Last reply
                                        • K kwull
                                          0;1;1;0;0;22.3
                                          0;0;1;0;1;23.0
                                          0;255;0;0;18;2.1.1
                                          0;255;3;0;12;1.0
                                          0;0;0;0;7;
                                          0;1;0;0;6;
                                          0;1;1;0;0;23.1
                                          0;0;1;0;1;22.1
                                          Bindings:
                                          openhab.log:
                                          Exception log:
                                          Registers:
                                          0x0000000000003786:
                                          [C
                                           - length: 12
                                          Additional logs:
                                          	... 65 more
                                          K
                                          K
                                          kwull
                                          @kwull, @TimO - I've solved the issue by changing docker base image. The issue described here - https://github.com/openhab/openhab-docker/issues/144
