  3. openhab mysensors ethernet gateway value missing
6 Posts 2 Posters 2.3k Views 2 Watching
  • T
    Tommas
    wrote on last edited by Tommas
    Dear All!
    My problem is, that openhab 2.2 (snapshot) show my gateway + temp + hum things online, but values are missing.
    (additional info, that first I installed openhab2 stable (same results) with apt, after it i change the repo to snapshot and installed it with apt upgrade)
    The sensor node sends the temp and hum values to gateway, and i see that the gateway receive these., but in openhab no values.
    I followed these:
    https://www.mysensors.org/build/ethernet_gateway
    https://github.com/tobof/openhab2-addons/wiki
    Gateway monitor:
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:28.0
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 100.100.1.41
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:26.0
    IP: 100.100.1.41
    IP: 100.100.1.41
    • T
      TimO
      Looks like your gateway is in a boot loop. Try downgrading the board definition in the arduino IDE. :smile:
      T 4 Replies Last reply
      • T TimO
        Tommas
        @TimO
        Dear TimO!
        What does downgrafing the board definition means?
        Im beginner sorry
        Have a good day!
        • T TimO
          Tommas
          @TimO
          I found the answer to my question:) https://forum.mysensors.org/topic/4462/gatewayw5100-unable-to-get-working-w-v2-0-0/2
          But why the downgrade should be a solution? The latest version Arduino AVR board doesnt compatible with all clone?
          Thanks, T
          • T TimO
            Tommas
            @TimO
            I downgraded to 1.6.11 , and it seems working:
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:28.0
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:24.0
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:19.0
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:25.0
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:29.0
            Im trying to troubleshoot openhab, because the temprature and humidity values are 0 .
            Thank you very much for the idea!
            • T TimO
              Tommas
              @TimO
              Deat TimO!
              Its working now! I had to restart openhab service
              Thanks again!
              Best regards
