  3. domoticz Error sending switch command](check device/hardware !)
10 Posts 3 Posters 4.6k Views 3 Watching
  • tombstoneT Offline
    tombstoneT Offline
    tombstone
    Re: [Error sending switch command](check device/hardware !)
    Hi I getting the same error msg (Error sending switch command](check device/hardware !)). I got my 1st serial Gateway started last night and just built a irrigation controller made from bulldog. Irrigation control
    I have promini for the serial Gateway and a pro mini for the irrigation controller.
    I get 2 nodis on domoticz one as my sprinkler and the other as unknown.
    I get 5 children as lights
    One mysensor 2.2. on the my sprinkler
    One unknowing
    On the unknowing
    The error comes up when turning on or off.
    Sorry if this is a easy fix but I'm just learning.
    D 1 Reply Last reply
    • tombstoneT tombstone
      One unknowing
      On the unknowing
      @tombstone One thing to note with the irrigation controller and Domoticz. The irrigation controller sketch looks for 3 variables from the controller for each irrigation zone, V-VAR1,V-VAR2 and V-VAR3. It has been a while since I used Domoticz, but unless there has been some recent change, these are not supported by Domoticz. What these values are are configuration values as follows:
      V-VAR1 =The amount of time that the particular zone will run when "Run all zones" is called
      V-VAR2 = The amount of time that the particular zone will run when the zone is triggered as a single zone
      V-VAR3 = The name for the zone
      Back when I used Domoticz, I was working on a way to deal with this. If you look at this post from me, I had a sketch that would deal with this in Domoticz. That sketch is quite old as it was written for MySensors 1.5.4, but looking it over may give you some ideas.
      Maybe someone else has a more up to date sketch with a different way of doing this. Your last resort option is to hard code the values on the irrigation controller, but then all you can do from Domoticz is turn the zones on and off. You won't be able to change how long a zone runs unless you re-program the irrigation controller.
      tombstoneT 1 Reply Last reply
      • D dbemowsk
        tombstoneT Offline
        tombstoneT Offline
        tombstone
        @dbemowsk
        I happy to change from domoticz.
        As I just starting out. What one you use now?
          @dbemowsk
          @tombstone I have a Vera Plus controller which is a hardware based controller that costs around $150 US. http://getvera.com/controllers/veraplus/
          There may be other free controllers out there that support the V-VAR variables, but I don't know which ones.
          • D dbemowsk
            tombstoneT Offline
            tombstoneT Offline
            tombstone
            @dbemowsk
            Yes it's has limited functionality. Looks like openhub, Home Assistant, MyController.org and my nodes works find.
            It be good to know if it's been fixed on Domoticz.
            Will have to find out but if not I have to change to one of the above.
            Which one do you recommend
              @dbemowsk
              @tombstone I have never used any of the others, so I cannot make a recommendation, sorry.
              • P Offline
                P Offline
                pjr
                So your node can get messages thru to gw but gw cant get them always to node..
                Have you added capacitor to your gateway radio? For me this looks like power issue of the radio.
                You could try this on your gateway: #define MY_RF24_PA_LEVEL RF24_PA_LOW (or RF24_PA_MIN) before mysensors include.
                • P pjr
                  @pjr No, his problem is in trying to use the irrigation controller sketch with Domoticz. Domoticz does not support the use of V-VARx values from MySensors which are used in the irrigation controller sketch to adjust the watering times of zones and to set the zone names.
                  • P Offline
                    P Offline
                    pjr
                    @dbemowsk Yes thats true that domoticz doesnt handle the VARX the way the irrigation code expects. But about the error message written on topic I'm pretty sure it actually is his problem since I'm using domoticz and have faced the same error message..
                    He stated:
                    "[Error sending switch command](check device/hardware !)"
                    "The error comes up when turning on or off."
                    With default settings RF24_PA_HIGH or RF24_PA_MAX (have to check the default from MyConfig.h) is used and with this setting the radio needs good power source. Especially the clone radios..
                    • P pjr
                      He stated:
                      @pjr OK, I didn't realize about the error message. I just assumed it had to do with the V-VARx problem.
