  3. How to burn fuses so that pro mini 3.3v would go down to 1.8v [SOLVED]
19 Posts 4 Posters 21.7k Views 5 Watching
  • D
    D
    dakipro
    wrote on last edited by dakipro
    can someone please provide some link with info about burning the fusses, I found two on the web, with one I cannot upload anything to the board after burning fusses, with second tutorial I cannot even start :(
    So far I was able to write fusses to
    Low fuse: 0x62
    High fuse: 0xDB
    Extended fuse: 0x05 (no BOD)
    But... then i get stuck at testing the blink or any other sketch
    Nca78N 1 Reply Last reply
    • D dakipro
      Low fuse: 0x62
      High fuse: 0xDB
      Nca78N
      Nca78N
      @dakipro said in 💬 Easy/Newbie PCB for MySensors:
      Low fuse: 0x62
      High fuse: 0xDB
      Check this, you need to update the bootloader too so there's not much interest in writing the fuses "alone" as it's done each time you update the bootloader from Arduino menu item.
      https://www.openhardware.io/view/33/Various-bootloader-files-based-on-Optiboot-62
      • D
        D
        dakipro
        Thanks, and for pro mini, without BOD (or really low BOD), i guess I could use "optiboot_atmega328_01M_004800_NOLED.hex" file?
        There are also similar files
        optiboot_atmega328_01M_004800_D5.hex
        optiboot_atmega328_01M_004800_D8.hex
        optiboot_atmega328_01M_004800_D13.hex
        optiboot_atmega328_01M_009600_D5.hex
        optiboot_atmega328_01M_009600_D8.hex
        optiboot_atmega328_01M_009600_D13.hex
        optiboot_atmega328_01M_009600_NOLED.hex
        I guess I also need to tune boards.txt to work with some of these, but I hope I can manage that down the road
        Nca78N sundberg84S 2 Replies Last reply
        • D dakipro
          Nca78N
          Nca78N
          wrote on last edited by Nca78
          use optiboot_atmega328_01M_009600_NOLED.hex, no interest in using the 4800bauds version as it's just half the speed to transfer scripts when 9600 is just fine (and it's the speed used by default for debug in many arduino sketches so it's also more convenient).
          I suggest 1.8V BOD as in some (rare) cases low voltage can corrupt memory (and then sketch, bootloader,...). Rare but 1.8V is too low for >95% of sensors and too low for radio so it won't block you for anything so it's better not to take risks.
          • D dakipro
            @dakipro - you should be able to pretty much lower bod in the boards file for the standard pro mini bootloader as well.
            • D
              D
              dakipro
              I did it (i think :) ) somehow fallowing the tutorial Nca78 posted. And once I change the board (of fusses) I must always use avrIsp to upload sketches?
              • D dakipro
                @dakipro - that depends if the bootloader has ftdi upload enabled or not I think.
                • D
                  D
                  dakipro
                  Success! I fallowed your advice @sundberg84 and just changed boards.txt and got it to work! Simple and without custom bootloaders etc.
                  I will certainly forget how to do this again after few months, so here is how to burn fuses so that pro mini 3.3v would go down to 1.8v:
                  I just changed the boards.txt file that I found in folder c:\Program Files (x86)\Arduino\hardware\arduino\avr\boards.txt
                  What I did is duplicate lines defining existing pro mini. So I searched the file for "pro mini", and there I found 4 "groups" of lines defining different pro mini boards/processors. I copied one of the groups defining Pro Mini (3.3V, 8 MHz) w/ ATmega328 and changed the name of the group from 8MHzatmega328 to (f.eks.) 8MHzatmega328bod1v8. Then change extended_fuses to 0x06 for 1.8v BOD limit. Also changed the title of the board type. The complete block looks like
                  ## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328 BOD at 1.7v
                  pro.menu.cpu.8MHzatmega328bod1v8=ATmega328 (3.3V, 8 MHz, 1v7 BOD)
                  pro.menu.cpu.8MHzatmega328bod1v8.upload.maximum_size=30720
                  pro.menu.cpu.8MHzatmega328bod1v8.upload.maximum_data_size=2048
                  pro.menu.cpu.8MHzatmega328bod1v8.upload.speed=57600
                  pro.menu.cpu.8MHzatmega328bod1v8.bootloader.low_fuses=0xFF
                  pro.menu.cpu.8MHzatmega328bod1v8.bootloader.high_fuses=0xDA
                  pro.menu.cpu.8MHzatmega328bod1v8.bootloader.extended_fuses=0x06
                  pro.menu.cpu.8MHzatmega328bod1v8.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                  pro.menu.cpu.8MHzatmega328bod1v8.build.mcu=atmega328p
                  pro.menu.cpu.8MHzatmega328bod1v8.build.f_cpu=8000000L
                  And in my boards.txt file it starts on line 735
                  This is the old line for extended_fuses that we are updating/replacing
                  #pro.menu.cpu.8MHzatmega328bod1v8.bootloader.extended_fuses=0xFD
                  After restarting Arduino IDE you should see new type of the "processor" of the board in IDE Tools menu. Select the new one we just created "ATmega328 (3.3V, 8 MHz, 1v7 BOD)" and burn the bootloader on the pro mini.
                  I used Arduino as ISP to burn bootloader, and there are tutorials for that on arduino.cc. If you have real ISP, then it is a bit easier, but you need to figure out your method of uploading bootloader. Check PeteB's video mentioned bellow.
                  After that you can check that the fuzes are changed properly, by using Avrdude in the method explained in PeteB's video here https://www.mysensors.org/about/fota . You can also just try to power the mini with 2.0v and see if it works :)
                  This is the only time we use this newly created processor, it is not used in uploading sketches. So after bootloader is uploaded, you will be able to program pro mini "as if nothing happened", meaning you just connect FTDI and compile. But (this is very important!) dont forget to select the regular processor when uploading sketches, the "Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328", not the new one we just created. If you try using new processor, I think it will stop at compile process, so just change to regular processor.
                  Now you can connect the pro mini directly to batteri and have it run down to 1.8v (in theory, radio goes down to 1.9 if all is "perfect")
                  I just tested one sensor and it goes down to 2.0v without complaining, that is much better then 2.7 from before :)
                  • D dakipro
                    @dakipro great work and explanation. Can I use this and link from the EasyPCB site about changing BOD?
                    • D
                      D
                      dakipro
                      Of course, you and Nca78 did all the thinking anyway :)
                      I renamed the thread to "How to burn fuses so that pro mini 3.3v would go down to 1.8v [SOLVED]" :) ( or if you have a better suggestion for the topic please write)
                      • NeverDieN
                        NeverDieN
                        There's a big advantage to running with no BOD and with no external crystal (internal resonator only): under those conditions the atmega328p can wake from sleep in less than 4usec. Over time, if running from battery or a supercap, that can save you a lot of power.
                        • Nca78N
                          Nca78N
                          The problem is if you have a low/no BOD and keep the 8MHz at some point the atmega won't be able to run with the low voltage. Also, it's better to run from internal oscillator instead of external (lower power consumption but less precise, so you should use it only if you do not need precise timing) and you need to have bootloader matching the fuse settings in board.txt for the frequency if you don't want your board to have all it's timing wrong.
                          @NeverDie reactivating BOD takes around 60uS, if we believe the datasheet. Not much to worry about IMHO, that's one minute of on time after 1 million wake ups (so, 2 years if you wake up every minute), if running at 1MHz that's around 1mA so that's a total of 1/60 = 0.016mAh for 2 years.
                          • D
                            D
                            dakipro
                            ok, my happiness was a short lasting one then :(
                            Is it possible to have 1MHz and low BOD, while still being able to program pro mini with ftdi? Do you @Nca78 perhaps posses such a magical bootloader?
                            If only ISP can be used, then it makes more sense to upload FOTA enabled one, then you can at least change sketch over the air... I just didn't find 1MHz bootloader with low BOD that is fota enabled (but I could ask Tekka for help if I do not manage to make it)
                            • D dakipro
                              Nca78N
                              Nca78N
                              @dakipro as long as you have a bootloader, then you can program using FTDI, that's the purpose of the bootloader ;)
                              What you are doing is programming without bootloader. If you follow the tutorial I have linked earlier and use the provided bootloader files you just have to use the "write bootloader" menu (not sure about exact text in English but it's the last item in Tools menu) to update fuses and write the bootloader on the board at the same time (based on fuses and bootloader set in boards.txt). Then you should use FTDI and not use the programmer anymore, because the programmer will erase the bootloader.
                              • sundberg84S
                                I don't know the source but here is some interesting reading @dakipro: https://www.iot-experiments.com/arduino-pro-mini-1mhz-1-8v/
                                For 1.8V you need to have a maximum frequency of 4MHz.
                                What I have understood its a balance as well. If you have large calculations/sketches @ 1mhz it will take 8 times longer to process than 8mhz, which might even increase the battery usage since its so slow.
                                At the moment im running a motion detector @ 1mhz though and that code + MySensors lib has been working quick/great.
                                • D
                                  D
                                  dakipro
                                  What are you selecting as a board when you upload sketch?
                                  On mentioned manual it says "Choose your desired board which we have added before and burned the atmega328p with it."
                                  But when I do that I get something like
                                  Board apm96 (platform avr, package arduino) is unknown
                                  Error compiling for board APM Optiboot internal 1MHz 1v8BOD 9600baud.
                                  or
                                  Board 28PinBoard (platform avr, package arduino) is unknown
                                  Error compiling for board atmega328p based - 28 pin DIL.
                                  (depending on which test I try, and I tried like 10 combination of boards.txt values, fuzes and bootloaders )
                                  When I select pro mini i IDE, i get
                                  avrdude: stk500_recv(): programmer is not responding
                                  avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x35
                                  avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x35
                                  avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x35
                                  avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x35
                                  avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x35
                                  avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x35
                                  avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x35
                                  avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x35
                                  avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x35
                                  avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x35
                                  Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
                                  When I repeat all the steps with original bootloader, it all works (I am using FTDI to upload sketches, just as nothing ha happened)
                                  I really appreciate your help, I guess world is just not yet ready for my level of noobism, so I might as well just buy more batteries and use regular bootloader :)
                                  • D dakipro
                                    or
                                    @dakipro - did you see this tutorial?
                                    https://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5
                                    • D
                                      D
                                      dakipro
                                      That is the one I used, fallowed all the steps and got the results I posted above. Either it wont compile with the newly selected board (in the IDE), or it wont upload dues to getsync()-thing... I starts uploading, mini blinks 2-3 times, and then silence...
                                      I tried with exactly what says in tutorial, then I tried with some of the bootloaders from the "collection' linked above, then I tried over 10 different combinations of similar things, different fuses and bootloaders, and nothing worked further then the errors above :(
                                      • D
                                        D
                                        dakipro
                                        Success! @sundberg84 and @Nca78 you will be proud of me when I tell you that I was doing everything "correct" all the time, it is just that arudino IDE had some stupid bug or something. I had to delete everything mentioning Arduino from the pc, and reinstall the IDE, and now all works as expected!
                                        It was a stupid thing hunting me for year(s) now that I think about it. I always assumed that ftdi cannot be used with other then the original bootloader, because of stupid error noone ever heard about :(
                                        At the end, I used this repo https://github.com/joe-speedboat/Arduino-LowPower and added new definitions in the boards.txt, then copied relevant bootloaders (and files in "variants" folder). And repeated all the steps above, and everything works great now. I have a 1mhz arduino blinking correctly, and going down to 1.8v, and sending correct temperatures and all
                                        Life is worth living again!
