  3. SerialGateway Output
4 Posts 4 Posters 2.0k Views 1 Watching
    Mike Cayouette
    wrote on last edited by Mike Cayouette
    Hi, This is my first post, I'm quite new to MySensors. I'm just becoming familiar with the SerialGateway with a long term intention of connecting it to a RPi. What I have done is used a Arduino Pro Mini (5v version) and wired the radio as per http://mysensors.org/build/connect_radio and I uploaded the SerialGateway sketch. I then used an Arduino Pro Mini (3v3 version) and install the radio is per the link above and I uploaded the BinarySwitchSensor sketch. When I open the serial monitor on the gateway I see the the following output.
    0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    And this is the output from the sensor
    send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
    req node id
    req node id
    req node id
    req node id
    req node id
    The problem is the output does not change regardless of whether the switch is open of closed. Am I missing something? Should the output not be different based on the state of the switch?
    Any help would be appreciated , thank you.
    Mike
      Your sensor is asking gateway (or rather controller) for an id.
      You can study the serial api here: http://www.mysensors.org/build/serial_api
      • C
        C
        coricidin12
        What did you do to fix this issue? I'm a newb and having the same problem with a distance sensor.
        • ch3b7C
          ch3b7C
          ch3b7
          In the arduino serial monitor put 255;255;3;0;4;X where x is a number 1-254
