  3. NodeManager
  4. ds18b20 and negative temperature values
6 Posts 3 Posters 4.2k Views 3 Watching
  • fabix68F
    fabix68F
    fabix68
    hi,
    I'm having problems with negative temperatures on a node with 2 ds18b20
    if both sensors measure the positive temperature, the values ​​are correctly sent. If one of the 2 negative negative values ​​is ignored.
    everything works correctly using the example in the library.
    both positive values
    One Negative value
    • rejoe2R
      rejoe2R
      rejoe2
      As your serial output is different to the temperature sensor example, you should also post your changed code for deeper analysis.
      • fabix68F
        fabix68F
        fabix68
        wrote on last edited by fabix68
        Config.h
        #ifndef config_h
        #define config_h
         * Sketch configuration
        #define SKETCH_NAME "Temperatura"
        #define SKETCH_VERSION "1.0"
         * MySensors node configuration
        // General settings
        #define MY_BAUD_RATE 9600
        //#define MY_NODE_ID 100
        //#define MY_SMART_SLEEP_WAIT_DURATION_MS 500
        // NRF24 radio settings
        //#define MY_RF24_ENABLE_ENCRYPTION
        //#define MY_RF24_CHANNEL 76
        //#define MY_RF24_PA_LEVEL RF24_PA_HIGH
        //#define MY_DEBUG_VERBOSE_RF24
        //#define MY_RF24_DATARATE RF24_250KBPS
        // RFM69 radio settings
        //#define MY_RFM69_FREQUENCY RF69_868MHZ
        //#define MY_RFM69_FREQUENCY RFM69_868MHZ
        //#define MY_IS_RFM69HW
        //#define MY_RFM69_NEW_DRIVER
        //#define MY_RFM69_ENABLE_ENCRYPTION
        //#define MY_RFM69_NETWORKID 100
        //#define MY_DEBUG_VERBOSE_RFM69
        //#define MY_RF69_IRQ_PIN D1
        //#define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
        //#define MY_RF69_SPI_CS D2
        //#define MY_RFM69_ATC_MODE_DISABLED
        // RS485 serial transport settings
        //#define MY_RS485
        //#define MY_RS485_BAUD_RATE 9600
        //#define MY_RS485_DE_PIN 2
        //#define MY_RS485_MAX_MESSAGE_LENGTH 40
        //#define MY_RS485_HWSERIAL Serial1
        // Message signing settings
        //#define MY_SIGNING_SOFT
        //#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
        //#define MY_SIGNING_REQUEST_SIGNATURES
        //#define MY_SIGNING_ATSHA204
        // OTA Firmware update settings
        //#define MY_OTA_FIRMWARE_FEATURE
        //#define OTA_WAIT_PERIOD 300
        //#define FIRMWARE_MAX_REQUESTS 2
        //#define MY_OTA_RETRY 2
         * MySensors gateway configuration
        // Common gateway settings
        //#define MY_REPEATER_FEATURE
        // Serial gateway settings
        //#define MY_GATEWAY_SERIAL
        // Ethernet gateway settings
        //#define MY_GATEWAY_W5100
        // ESP8266 gateway settings
        //#define MY_GATEWAY_ESP8266
        //#define MY_ESP8266_SSID ""
        //#define MY_ESP8266_PASSWORD ""
        // Gateway networking settings
        //#define MY_PORT 5003
        //#define MY_GATEWAY_MAX_CLIENTS 2
        //#define MY_USE_UDP
        // Gateway MQTT settings
        //#define MY_GATEWAY_MQTT_CLIENT
        //#define MY_PORT 1883
        //#define MY_MQTT_CLIENT_ID "mysensors-1"
        //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
        //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
        // Gateway inclusion mode
        //#define MY_DEFAULT_LED_BLINK_PERIOD 300
        // Gateway Leds settings
        //#define MY_DEFAULT_ERR_LED_PIN 4
        //#define MY_DEFAULT_RX_LED_PIN  5
        //#define MY_DEFAULT_TX_LED_PIN  6
         * NodeManager configuration
        // if enabled, enable debug messages on serial port
        #define DEBUG 1
        // if enabled, enable the capability to power on sensors with the arduino's pins to save battery while sleeping
        #define POWER_MANAGER 1
        // if enabled, will load the battery manager library to allow the battery level to be reported automatically or on demand
        #define BATTERY_MANAGER 1
        // if enabled, allow modifying the configuration remotely by interacting with the configuration child id
        #define REMOTE_CONFIGURATION 1
        // if enabled, persist the remote configuration settings on EEPROM
        #define PERSIST 0
        // if enabled, a battery sensor will be created at BATTERY_CHILD_ID (201 by default) and will report vcc voltage together with the battery level percentage
        #define BATTERY_SENSOR 1
        // if enabled, a signal sensor will be created at RSSI_CHILD_ID (202 by default) and will report the signal quality of the transport layer
        #define SIGNAL_SENSOR 0
        // if enabled, send a SLEEPING and AWAKE service messages just before entering and just after leaving a sleep cycle and STARTED when starting/rebooting
        #define SERVICE_MESSAGES 0
        // Enable this module to use one of the following sensors: SENSOR_ANALOG_INPUT, SENSOR_LDR, SENSOR_THERMISTOR, SENSOR_ML8511, SENSOR_ACS712, SENSOR_RAIN, SENSOR_SOIL_MOISTURE
        #define MODULE_ANALOG_INPUT 0
        // Enable this module to use one of the following sensors: SENSOR_DIGITAL_INPUT
        #define MODULE_DIGITAL_INPUT 0
        // Enable this module to use one of the following sensors: SENSOR_DIGITAL_OUTPUT, SENSOR_RELAY, SENSOR_LATCHING_RELAY
        #define MODULE_DIGITAL_OUTPUT 0
        // Enable this module to use one of the following sensors: SENSOR_DHT11, SENSOR_DHT22
        #define MODULE_DHT 0
        // Enable this module to use one of the following sensors: SENSOR_SHT21, SENSOR_HTU21D
        #define MODULE_SHT21 0
        // Enable this module to use one of the following sensors: SENSOR_SWITCH, SENSOR_DOOR, SENSOR_MOTION
        #define MODULE_SWITCH 0
        // Enable this module to use one of the following sensors: SENSOR_DS18B20
        #define MODULE_DS18B20 1
        // Enable this module to use one of the following sensors: SENSOR_BH1750
        #define MODULE_BH1750 0
        // Enable this module to use one of the following sensors: SENSOR_MLX90614
        #define MODULE_MLX90614 0
        // Enable this module to use one of the following sensors: SENSOR_BME280
        #define MODULE_BME280 0
        // Enable this module to use one of the following sensors: SENSOR_SONOFF
        #define MODULE_SONOFF 0
        // Enable this module to use one of the following sensors: SENSOR_BMP085
        #define MODULE_BMP085 0
        // Enable this module to use one of the following sensors: SENSOR_HCSR04
        #define MODULE_HCSR04 0
        // Enable this module to use one of the following sensors: SENSOR_MCP9808
        #define MODULE_MCP9808 0
        // Enable this module to use one of the following sensors: SENSOR_MQ
        #define MODULE_MQ 0
        // Enable this module to use one of the following sensors: SENSOR_MHZ19
        #define MODULE_MHZ19 0
        // Enable this module to use one of the following sensors: SENSOR_AM2320
        #define MODULE_AM2320 0
        // Enable this module to use one of the following sensors: SENSOR_TSL2561
        #define MODULE_TSL2561 0
        // Enable this module to use one of the following sensors: SENSOR_PT100
        #define MODULE_PT100 0
        // Enable this module to use one of the following sensors: SENSOR_BMP280
        #define MODULE_BMP280 0
        // Enable this module to use one of the following sensors: SENSOR_DIMMER
        #define MODULE_DIMMER 0
        // Enable this module to use one of the following sensors: SENSOR_RAIN_GAUGE, SENSOR_POWER_METER, SENSOR_WATER_METER
        #define MODULE_PULSE_METER 0
        File
          NodeManager is intended to take care on your behalf of all those common tasks a MySensors node has to accomplish, speeding up the development cycle of your projects.
          NodeManager includes the following main components:
          - Sleep manager: allows managing automatically the complexity behind battery-powered sensors spending most of their time sleeping
          - Power manager: allows powering on your sensors only while the node is awake
          - Battery manager: provides common functionalities to read and report the battery level
          - Remote configuration: allows configuring remotely the node without the need to have physical access to it
          - Built-in personalities: for the most common sensors, provide embedded code so to allow their configuration with a single line
          Documentation available on: https://github.com/mysensors/NodeManager
        // load user settings
        #include "config.h"
        // include supporting libraries
        #ifdef MY_GATEWAY_ESP8266
        #include <ESP8266WiFi.h>
        // load MySensors library
        // load NodeManager library
        #include "NodeManager.h"
        // create a NodeManager instance
        NodeManager nodeManager;
        // before
        void before() {
          // setup the serial port baud rate
          Serial.begin(MY_BAUD_RATE);
          nodeManager.registerSensor(SENSOR_DS18B20, 3);
          nodeManager.setBatteryMin(1.8);
          nodeManager.setBatteryMin(3.2);
          nodeManager.setSleepMinutes(1);
             Register below your sensors
             Register above your sensors
          nodeManager.before();
        // presentation
        void presentation() {
          // call NodeManager presentation routine
          nodeManager.presentation();
        // setup
          // call NodeManager setup routine
          nodeManager.setup();
        // loop
          // call NodeManager loop routine
          nodeManager.loop();
        // receive
          // call NodeManager receive routine
          nodeManager.receive(message);
        // receiveTime
        void receiveTime(unsigned long ts) {
          // call NodeManager receiveTime routine
          nodeManager.receiveTime(ts);
        • rejoe2R
          rejoe2R
          rejoe2
          @fabix68 sorry, but this seems to be a problem specific to nodemanager, so I'm not able to help you wrt this.
          • fabix68F
            fabix68F
            fabix68
            I solved the problem.
            The error is in the NodeManager.cpp file in the section below here calculates the average of the detected values.
            Exactly at this point
            // process a float value
              else if (_value_type == TYPE_FLOAT && total > -1)
            the program does not send data if the average of the measurements is less than -1.
            Certainly a lapse.
            The average reading of a temperature sensor may also be negative.
            Removed control> -1 and the negative reads sell sent.
            It is necessary to analyze the behavior of the program when a sensor does not work, generating as -127 reading. I did not see if the library already does this check.
            • U
              U
              user2684
              Sorry for the delayed answer! Referencing https://github.com/mysensors/NodeManager/issues/219 to follow the resolution which as I mentioned might be a bit more complex unfortunately :)
