  3. MyNodes.NET
  4. OrangePi Zero
OrangePi Zero
Scheduled Pinned Locked Moved MyNodes.NET
6 Posts 2 Posters 4.8k Views 2 Watching
  • D
    D
    dzairo
    Hi all .
    Today I install Debian in to my OrangePi Zero.
    Is possible istall MyNodes.NET to my Orange Pi Zero?
    I test MyNodes.NET with windows 7 and serial gateway and work good .
    Now I want put it all to OrangePi ZERO ..
    is possible to help with it ??
    regards.
      I can't answer that, but if you haven't looked at node-red you may consider that also
      • D
        D
        dzairo
        Hi.
        I try install alpackage from this web : http://piboards.com/2017/01/04/easy-set-up-orange-pi/
        and I will be see .. there is Node-red instalation..
        regards.
          Take a look at dietpi, they have an image for orange pi zero and it should be easy to setup.
          • D
            D
            dzairo
            Hi.
            I install node-red from https://diyprojects.io/install-node-red-orange-pi-running-armbian/#.WdDmSb3TMQW
            work.
            if try install MyNodes.NET then in step :+1: git clone git://github.com/aspnet/home.git
            sh ~/sources/aspnet5/home/dnvminstall.sh
            is problem.. dnvminstall.sh not found..
            is there any functional instalation for rpi or other ??
            I have problem with instalation ASP.NET 5
            any idea??
            • D
              D
              dzairo
              ehm.. sorry .. not read older post.. but may be..
