  3. No luck with ethernet Gateway
8 Posts 5 Posters 3.3k Views 4 Watching
    A Former User
    Hello, i'trying to move from a working serial GW to ethernet GW but can not get it to work.
    Please have a look at my code.
       The MySensors Arduino library handles the wireless radio link and protocol
       between your home built sensors/actuators and HA controller of choice.
       The sensors forms a self healing radio network with optional repeaters. Each
       repeater and gateway builds a routing tables in EEPROM which keeps track of the
       network topology allowing messages to be routed to nodes.
       Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
       Copyright (C) 2013-2015 Sensnology AB
       Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
       Documentation: http://www.mysensors.org
       Support Forum: http://forum.mysensors.org
       This program is free software; you can redistribute it and/or
       modify it under the terms of the GNU General Public License
       version 2 as published by the Free Software Foundation.
       REVISION HISTORY
       Version 1.0 - Henrik EKblad
       Contribution by a-lurker and Anticimex,
       Contribution by Norbert Truchsess <norbert.truchsess@t-online.de>
       Contribution by Tomas Hozza <thozza@gmail.com>
       DESCRIPTION
       The EthernetGateway sends data received from sensors to the ethernet link.
       The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
       The GW code is designed for Arduino 328p / 16MHz.  ATmega168 does not have enough memory to run this program.
       LED purposes:
       - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
       - RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
       - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
       - ERR (red) - fast blink on error during transmission error or recieve crc error
       See http://www.mysensors.org/build/ethernet_gateway for wiring instructions.
    /* added by sigolhi
     * Hardware used
     * UNO r3
     * Ard Eth Shield with ws5100
     * NRF with ext. antenna +10uf on 3.3V
     * 2 pcs DS18B20
     * 1 light sensor
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    #define MY_IP_ADDRESS 192,168,2,66
    #define MY_IP_GATEWAY_ADDRESS 192,168,2,1
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    // Enable inclusion mode
    // Button pin with external pullup 4.7kohm to +5V
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin red
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin green
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin yellow
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    #include <OneWire.h>
    #define CHILD_ID_TEMP_IN 1    // Temperatur child-ID
    #define CHILD_ID_TEMP_OUT 2   // Temperatur child-ID
    #define CHILD_ID_LIGHT 3      // Lightsensor child-ID
    #define ONE_WIRE_BUS 8 // Arduino Digital I/O pin where dallas sensor is connected with 4.7kohm pullup to +5V
    #define MAX_ATTACHED_DS18B20 2  // Number of tempsensors
    #define LIGHT_SENSOR_ANALOG_PIN A3 // Arduino Analogue I/O pin0 for lightsensor
    OneWire oneWire(ONE_WIRE_BUS);
    int numSensors = 0;
    MyMessage msgTempIN(CHILD_ID_TEMP_IN, V_TEMP);    //CHILD_ID_TEMP_IN 1  Temperatur ID
    MyMessage msgTempOUT(CHILD_ID_TEMP_OUT, V_TEMP);  //CHILD_ID_TEMP_OUT 2  Temperatur ID
    MyMessage msgLL(CHILD_ID_LIGHT, V_LIGHT_LEVEL);   //CHILD_ID_LIGHT 3 Lightsensor ID
    unsigned long previousMillis = 0;        // will store last time data was sent
    unsigned long timetoWait = 300000;       // time to wait 300000=5min, 30000=30sekunder
    float Tempsensor1;    //store value to send
    float Tempsensor2;    //store value to send
    int lightLevel;       //store value to send
    void before()
      sensors.begin();                        // Startup OneWire
      Serial.println(__FILE__); // print filename to serialport at startup
      Serial.println(__DATE__); // print date to serialport at startup
      Serial.println(__TIME__); // print time to serialport at startup
      Serial.println();
      sensors.setWaitForConversion(false);    // request temperature() will not block current thread
      numSensors = sensors.getDeviceCount();  // Fetch the number of attached temperature sensors
      Serial.print("Number of temp sensors = ");
      Serial.println(numSensors);
      sendSketchInfo("Gateway", "2.1.1");
      present(CHILD_ID_TEMP_IN, S_TEMP, "InneTemp", 1);
      present(CHILD_ID_TEMP_OUT, S_TEMP, "UteTemp", 1);
      present(CHILD_ID_LIGHT, S_LIGHT_LEVEL, "Ljusstyrka", 1);
    #ifdef MY_DEBUG
      Serial.println("DEBUG IS ACTIVE ");
      sensors.requestTemperatures();     // Fetch temperatures from Dallas sensors
      if (currentMillis - previousMillis >= timetoWait) {    // create a delay between transmissions
        previousMillis = currentMillis;   // save the last time you measured the values
        for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++)
          //float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
          float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
          if (i == 0 && temperature != -127.00 )
            Tempsensor1 = temperature;
          else
            //Tempsensor2 = 12;
        lightLevel = map(analogRead(LIGHT_SENSOR_ANALOG_PIN), 0, 1023, 0, 100); //light in percent
        sendValue();
    void sendValue()
    #ifdef MY_DEBUG
      Serial.print("Temp_in = ");
      Serial.println(Tempsensor1);
      Serial.print("Temp_out = ");
      Serial.println(Tempsensor2);
      Serial.print("Lightlevel = ");
      Serial.println(lightLevel);
      wait(200);
      send(msgTempIN.setSensor(1).set(Tempsensor1, 1));
      wait(200);
      send(msgTempOUT.setSensor(2).set(Tempsensor2, 1));
      wait(200);
      send(msgLL.setSensor(CHILD_ID_LIGHT).set(lightLevel, 1));
    this is the console output which repeat itself
    also the debug does not seem to work
    0;255;3;0;9;TSF:MSG:READ,18-4-0,s=16,c=1,t=0,pt=7,l=5,sg=0:9.0
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;MCO:BGN:BFR
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.2.66
    0;255;3;0;9;MCO:BGN:STP
    D:\Olle\Documents\Arduino\Eth_tGw\Eth_tGw.ino
    Oct 4 2017
    21:16:11
    Number of temp sensors = 2
    0;255;3;0;9;TSF:MSG:READ,3-16-0,s=2,c=1,t=2,pt=2,l=2,sg=0:0
    0;255;3;0;9;!TSF:MSG:LEN,11!=9
    0;255;3;0;9;TSF:MSG:READ,16-16-0,s=11,c=1,t=0,pt=7,l=5,sg=0:25.0
    IP: 192.168.2.66
    Oct 4 2017
    21:16:11
    best regards sigolhi
    parachutesjP 1 Reply Last reply
      Try latest mysensors development library, then if problem persists try a different UNO or downgrade boards definitions to 1.6.11 or 1.6.13 and see if it still has problems. Did you try to remove code for each of the sensors at a time in order to figure out if it's a specific sensor?
        A Former User
        No luck!
        The node keeps resetting all the time
        But it can be seen in Domotics so it is connected to the net
        se below
        2017-10-07 20:46:03.960 (MySensor) Temp (Gateway Kontoret UteTemp)
        2017-10-07 20:46:04.179 (MySensor) Lux ( Gateway Kontoret Ljusstyrka)
        2017-10-07 20:46:07.694 (MySensor) Temp (Relä_17 Temp i Garaget)
        2017-10-07 20:46:07.804 (RFLink) Temp + Humidity (Väderstation Växthuset)
        2017-10-07 20:46:14.585 (RFLink) Wind (Väderstation Vind)
        2017-10-07 20:46:15.695 MySensors: trying to connect to: 192.168.2.66:5003
        2017-10-07 20:46:16.695 MySensors: connected to: 192.168.2.66:5003
        2017-10-07 20:46:25.695 MySensors: Connection reset!
        2017-10-07 20:46:25.695 TCP: Reconnecting in 30 seconds...
        2017-10-07 20:46:30.039 (MySensor) Humidity (Källare Hum in IROXbox)
        2017-10-07 20:46:47.758 (RFLink) Wind (Väderstation Vind)
        2017-10-07 20:46:52.821 (RFLink) Temp + Humidity (Väderstation Växthuset)
        2017-10-07 20:46:55.696 TCP: Reconnecting...
        2017-10-07 20:46:56.696 MySensors: connected to: 192.168.2.66:5003
        2017-10-07 20:47:05.696 MySensors: Connection reset!
        2017-10-07 20:47:05.696 TCP: Reconnecting in 30 seconds...
        2017-10-07 20:47:07.962 (MySensor) Temp (Relä_17 Temp i Garaget)
        2017-10-07 20:47:20.587 (RFLink) Wind (Väderstation Vind)
          What did you try?
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @gohan said in No luck with ethernet Gateway:
            take heed to this advice... did you modify the boards definition in your Arduino IDE?
            • ? A Former User
                 REVISION HISTORY
                 DESCRIPTION
                 LED purposes:
              /* added by sigolhi
               * Hardware used
               * UNO r3
               * 2 pcs DS18B20
               * 1 light sensor
              #define MY_SOFTSPI
              int numSensors = 0;
              void before()
                Serial.println();
              #ifdef MY_DEBUG
                    else
                      //Tempsensor2 = 12;
                  sendValue();
              void sendValue()
              #ifdef MY_DEBUG
                wait(200);
                wait(200);
                wait(200);
              IP: 192.168.2.66
              Oct 4 2017
              21:16:11
              IP: 192.168.2.66
              Oct 4 2017
              21:16:11
              parachutesjP
              parachutesjP
              parachutesj
              @sigolhi do you have enough power? It seems USB does not be sufficient for me
              • fritsF
                fritsF
                frits
                There's an issue with Atmega2560 and Wiznet 5100, are you using an Arduino Mega?
                https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time
                  A Former User
                  Hi frits and others,
                  In your link i finally found out how to downgrade to 1.6.11 and behold!
                  Now it works.
                  Thanks to all of you for being patient with me.
                  Regards Sigolhi
