  3. A smart home vs an automated home
59 Posts 8 Posters 23.8k Views 8 Watching
  • wallyllamaW Offline
    wallyllamaW Offline
    wallyllama
    I think @dbemowsk is hinting at something that fits my understanding of "emergent behavior", individual simple things interact and create more complex results. How many, and whom are different questions. Counters in doorways plus a list of whose phones are at home, maybe add in some hostorical data of who likes to sit in which chair. There are probably better combinations, but that is what I got from hisnrecent comments.
    D 1 Reply Last reply
    • D dbemowsk
      So looking at the MySensors end of this, would it be too far off to think of adding a new node type, "person". A person node could have customizable properties that would allow you to define different useful bits of data related to that person. For example, preferred room temperature, or preferred light level. Heck, you could even have a room or area property that would get set when the system sees you move to a different area. So when you do figure out better occupancy sensing, you can automatically set user preferred light levels and room temps based on who is in the room, and dial them down after a person leaves the room. If you have more than one person in a room, it could take an average of the properties of all in the room to determine a setting like room temperature to provide a happy medium.
      wallyllamaW Offline
      wallyllamaW Offline
      wallyllama
      wrote on last edited by wallyllama
      #42
      @dbemowsk said in A smart home vs an automated home:
      I'd like to hear more about how you would use it. Below is my two pennies worth.
      My thinking is that mysensors is a transport for relatively simple data, like state, value, counts etc, things nodes would need to set the environment up, or report back to central command.
      A complex object like "person" could have all kinds of attributes and preferences, which would modify values sent to nodes. Example the curtain controller knows to open during the day, close at night, and maybe close for an hour at 10 am in the summer when the sun shines directly in and heats up the house( could also be a light sensor), but if the weather says it is clear, and kent is in the living room and it is night open the curtains up, and that would be an override coming from central. The node controlling the curtain doesnt need to know it is me in the room, it just needs to accept the modifiers.
      I say this mostly because as @gohan points out arduinos arent terribly powerful, and telling them too much info may just confuse them.
      I liken it to the body. E.g. your finger doesnt have to know if you are walking up as you are pushing a doorbell, it just extends on command and reports that it made contact, moved forward slightly and hit a stop. Your spine may get involved if the finger reports excessive heat, or something gooey on the switch, and pulls the hand back in reflex.
      • wallyllamaW wallyllama
        @wallyllama As to your first comment about "emergent behavior", that's pretty much what I was getting at.
        As to the MySensors node, my thoughts when I mentioned the "person" node were possibly some kind of MySensorized identifier or tag for a person much like a bluetooth tag. The more I thought about it though, you are correct that there would be all kinds of attributes, and most of them wouldn't need to be tied to the tag. The "person" though might be on the controller side where the processing power is greater and where most of that data would be dealt with anyway.
        wallyllamaW 1 Reply Last reply
        • D dbemowsk
          wallyllamaW Offline
          wallyllamaW Offline
          wallyllama
          @dbemowsk interestingly, as I thought about these ir cameras, they may require a smarter node (maybe something like a nanopi neo2) to preprocess the data, and then a person tag may be useful.
          For example 64 pixels, 2 bytes to encode temperature value, 1hz refresh would mean 1280 bytes/s. Which If I have been reading this right, is pretty high for mysensors. There are some ways to reduce that, but it is unkown if an arduino could keep up.
          I've mostly been doing research on sensors, and only built one node and a gateway, so alot of what I have been saying about my sensors is assumption.
          Does it have a defined method of extending the data types? Or a board that decides? A Glorious Leader we need to cajole? Maybe "user defined" types?
          Im kind of in love with these IR array sensors, and I'm probably not objective about what is best for mysensors as a whole, but I have boxes of opinions I'd like to get rid of, so just ask if you want some
          • D Offline
            Again, doing some more brain cell searching and reflecting on the subject of a "person" node for MySensors, I am more and more starting to realize that this part of things may not be in the realm of MySensors. Not to say it shouldn't be part of an HA system, just not handled by MySensors. I think it could be a different module/plugin for whatever controller people are using, e.g Vera, Domoticz, OpenHAB, etc... As was mentioned, a "person" node would probably have a great number of properties and attributes that define a person. That in itself I think is a great argument as to why it should NOT be a MySensors node. Some of those properties and attributes may be defined by one or more different MySensors nodes, but it may also take data from a different kind of node based on something like what @wallyllama mentions which might require a more complex processor such as a nanopi. The ways in which a person may be identified could differ greatly between systems and could range from simple to complex. Again I get back to the simple IR doorway occupancy sensor that can count the number of people in a room. I think that this could be a great starting point for something like this and could be something simple enough for MySensors to handle. Going with something like this and later finding varying ways to determine who the occupants of a space are may be a way to get this started.
            gohanG 1 Reply Last reply
            • D dbemowsk
              @dbemowsk that's something that netatmo did with their smart ip camera that is able to recognize who entered the room or your garden and with that you can set some rules in a HA system and I bet it is far from simple to be done on a DIY project
                wallyllamaW Offline
                wallyllama
                @gohan Openmv has a single board camera with opencv and micropython, another option.
                I think @dbemowsk idea of door sensors fits nicely with mysensors as he has said. Is there a more appropriate forum for the more complex devices that anyone knows of? Im thinking if I come up with a node, I can add it like any other, but there will be a lot of talk that ends up a bit off topic.
                On topic, are there controllers that are more amenable to the kind of combining of different nodes to identify people that we are talking about? I've used Mr. House for other things, and domoticz for my one test node, not enough to really have an opinion.
                  @wallyllama I was actually a Mister House user prior to finding MySensors. The death of my Raspberry Pi 2 that I was running Mister House is what got me looking for other options, which is how I found MySensors. I then tried Domoticz for a bit, mainly because I found PERL, which is what MisterHouse is written in, hard to work with. Domoticz had some limitations too. I now have my Vera controller which I like. All of these have deficiencies in certain areas, but the nice thing with all of them is that they support many different types of HA hardware.
                    wallyllamaW Offline
                    wallyllama
                    A thought experiment. 5 known people and 1 pet in a room. 1 living being leaves the room. IR door sensor in place. What information do we want about the new situation? And what sensors would we need to gather it?....
                      @wallyllama Are you talking about all the way down to the system knowing who each of those people are?
                        wallyllamaW Offline
                        wallyllama
                        I dont know. I guess Im wondering what you want from this. Do you care about pets vs humans? Adults vs children? General person count only? If the goal is to not shut the lights off on people then the last one is good enough.
                          wallyllamaW Offline
                          wallyllama
                          I have recieved 2 amg8832 chips for experimentation after some delays because of import rules. The labeling on the bagggie says they need to be mounted within 108 hours of opening the bag. I would recommend getting a breakout board and not raw chips.
                          I'll post in the appropriate category any additional progress.
                          D 2 Replies Last reply
                            @wallyllama If I am looking at the information on these, these could see the direction a person is moving correct? If so, that would be a way to count people entering or leaving a room.
                              @wallyllama After watching this video this looks even more interesting.
                              https://www.youtube.com/watch?v=_HA1DX4DQdM
                                wallyllamaW Offline
                                wallyllama
                                I've been thinking of them as low resolution cameras that can see in the dark, but there may be more clever ways to think of it that I havent come across, but any computer vision algorithm would work. Motion detection for sure.
                                I have a fairly large living room with a high ceiling, if I mount one in the center, i should cover most of the room, I estimate a person would be about 1 pixel at the floor. The coverage is a pyramid so at the edges height is zero. Corner mounting like the video shows would probably fix that.
                                I think these work work better than my idea for a giant capacitive touch screen.
                                • D dbemowsk
                                  @matt-shepherd Something I hadn't thought of. Nice idea. I do have an Amazon Echo in my living room. My only question on that is have they figured out a way to sparate 2 Amazon devices like an Echo in one room and a Dot in another room to know what room a sound came from? Last I checked, that was not possible.
                                  I was looking into it a bit for other automation stuff like turning on a light in a room. For example, when I am in the living room and I say "turn the overhead light on", it turns on the living room overhead light. When I go into the office, where now I am being heard by the Dot, and I say the same phrase, it should turn the office overhead light on. From the reading that I have done, you can't use them that way, but it should be possible somehow.
                                  sam9sS Offline
                                  sam9sS Offline
                                  sam9s
                                  wrote on last edited by sam9s
                                  #56
                                  @dbemowsk this can be crudely done via routine feature on amazon alexa, what it offers is that you can rename any IOT device state (ON or OFF) with any name, so like in your example, living room lights you can just say Alexa "living room overheads" and it will turn the living room overhead lights, similarly for office you can say "Alexa; "office overheads" and it will switch on the office overhead lights. Ofcouse you have to have a different phrase for OFF state, but you get the idea. But yes the same phrase for all rooms and letting alexa sense which room r u in, and acting accordingly is actual smart home. I would keep searching if I can find n build somethig like that.
                                  • sam9sS sam9s
                                    wallyllamaW Offline
                                    wallyllamaW Offline
                                    wallyllama
                                    @sam9s what you are describing, while a nice way to control things, has the same basic flaw as a PIR device. You have to tell it you are there. The PIR(alexa) knows what room it is in, but you have to signal it some how. Alexa is signaled by a voice command, PIR by motion, but if you are quietly reading a book both of them forget you are there. Alternatively you can have them assume you are there for a set amount of time after the signal, or until they get an off signal.
                                    The trick is to get them to detect you without actively addressing them. If Alexa can detect breathing, or heat or CO2, etc, then it would solve the problem.
                                    you can combine alexa with door sensors. If alexa is triggered and no one has left the room then someone is still here. That is the idea that @dbemowsk pointed out earlier in the thread.
                                      If you could tell Alexa which room is in, you wouldn't have any problems since it normally doesn't wander around the house 😁
                                        @wallyllama said in A smart home vs an automated home:
                                        If you enter a room and do not say anything, then Alexa has no way of identifying WHO you are. Even if the echo could detect breathing, heat, or CO2, you are back to knowing that someone is there, but not who.
