  3. sending string containing special chars (ä,ö,ü)
4 Posts 3 Posters 2.7k Views 5 Watching
  • AndurilA
    AndurilA
    Anduril
    Hey there,
    I'm building a Display where I want to show some information. As I live in germany, some of the strings I want to display contain the special characters ä, ö or ü (and maybe ß) Is there a way of sending them without bigger problems? In normal transmission I receive M⸮ller when sending Müller
    YveauxY 1 Reply Last reply
      I think it should depends on the display controller if it has those characters or not.
      • AndurilA Anduril
        Hey there,
        YveauxY
        YveauxY
        @Anduril MySensors supports regular strings of ASCII characters. These characters are IIRR in the high area of ASCII which might not be supported by a regular text display.
        Another problem could be that you're supplying the text as Unicode wide characters (2 bytes per character, eg. when typing in Ms Word) which is not supported by MySensors.
        • AndurilA
          AndurilA
          Anduril
          For this special application I use MyController. In the controller the string is displayed correctly, but in the serial monitor of the node I only see this distorted version (But sending them by sketch works, so it's not a problem of the serial monitor in general).
          I will ask at the MyController forum, maybe the dev can help.
