  3. [security] Migrating from library version 2.1 to 2.2
48 Posts 7 Posters 15.0k Views 9 Watching
  • A Anticimex
    @alexsh1 AES key is never saved to atsha204. It is for encryption and always stored in eeprom.
    alexsh1A Offline
    alexsh1A Offline
    alexsh1
    @anticimex Now I got more confused. What keys do I need for atsha204a signing?
    A 1 Reply Last reply
    • alexsh1A alexsh1
      A Offline
      A Offline
      Anticimex
      @alexsh1 it is pretty clearly documented. HMAC key is used for signing.
      alexsh1A 1 Reply Last reply
      • A Anticimex
        alexsh1A Offline
        alexsh1A Offline
        alexsh1
        #43
        @anticimex Sorry, I think I need to re-read documentation. HMAC is for atsha204a signing and AES for encryption, right?
        I am in the process of re-personalising now :)
        • alexsh1A alexsh1
          A Offline
          A Offline
          Anticimex
          @alexsh1 correct
          • A Anticimex
            @alexsh1 correct
            alexsh1A Offline
            alexsh1A Offline
            alexsh1
            @anticimex thank you! I set-up singing some time ago and it was working fine, but now I need to revise all that again.
            • alexsh1A alexsh1
              A Offline
              A Offline
              Anticimex
              @alexsh1 it is worth mentioning that if you personalize using 2.2.0, you are free to go back to earlier versions without re doing personalization. It is only when going from 2.1 to 2.2 it has to be redone due to the checksum. Of course, be aware that overwriting the checksum will cause signing to fail again.
              • A Anticimex
                alexsh1A Offline
                alexsh1A Offline
                alexsh1
                @anticimex said in [security] Migrating from library version 2.1 to 2.2:
                @alexsh1 Of course, be aware that overwriting the checksum will cause signing to fail again.
                And what has to be done in this case? Re-personalising both GW and a node?
                • alexsh1A alexsh1
                  A Offline
                  A Offline
                  Anticimex
                  @alexsh1 re-personalize the node that lost the checksum. Each node (including gw) has a unique personalization and checksum (possibly). Just because one node looses the checksum or gets a mismatch does not mean any other node has the same problem. Everything is stored in eeprom locally.
