  3. Domoticz
  4. relay as a switch not as a button (domoticz)
25 Posts 4 Posters 9.0k Views 6 Watching
  • Boots33B Boots33
    @ago1980 said in relay as a switch not as a button (domoticz):
    I mean if GATEWAY does not work for some problem the node does not work does not turn on light
    The original sketch relies on an ack from the gateway to trigger the relay, so if the gateway is not available the relay state cannot be changed by the local switch or even the controller.
    Under most circumstances it would be desirable to have the local switch function no matter what the state of the network is. To do this you will need to modify the sketch so it no longer relies on the ack to make the change.
    In MySensors 2.1.1 by default a node will not boot through to the loop section of your sketch if it cannot find the gateway, so the first thing you need to do is force it to move on.
    The line shown below will do just that. The number at the end is how long you want the node to wait for an uplink to be established before it will move on to the rest of your sketch. It is in milliseconds, so in the example below it will wait 5 seconds. This line needs to be inserted near the top of your sketch before the #include <MySensors.h> line.
    #define MY_TRANSPORT_WAIT_READY_MS 5000
    After adding that you will then need to change the sketch so it no longer relies on the ack to change the relay state. that is pretty straight forward and once done your relay will then be able to be switched by the local switch no mater what the uplink status is.
    The next problem you will encounter is trying to keep your controller in sync with the local node. As you can now change the state of the relay without a connection to the controller it may loose its sync to the node. So you may find your controller thinks the relay is on when it is actually off. This is where it gets a little trickier so if it is important to you that the controller stays in sync you may need to experiment a bit to find what will give you the best results.
    I have some examples of relay nodes that explore ways to switch locally and try to maintain sync with the controller.
    The last sketch I posted there uses requestTime() to check to see if the controller is available and though there is a trade off in how quickly you can flick the switch back and forward it at least confirms that the controller is available. Other methods may only check for the gateways presence.
    Have a look you may find something of use.
    Synchronising Light switch
    Its a bit of an old post but some of these issues (using a toggle switch and making the switch always work) were also discussed in this post
    A
    A
    ago1980
    @boots33 ok, thanks, so if I use switches I should not have problems? I follow this thread
     https://forum.mysensors.org/topic/4847/multi-button-relay-sketch
    Boots33B 1 Reply Last reply
    • A ago1980
      Boots33B
      Boots33B
      Boots33
      wrote on last edited by Boots33
      #22
      Other than the issues I have outlined in my post above the toggle switch will work just like the button.
      The basic re-write of the original button with relay sketch so it will work with a toggle switch and no uplink to the gateway is shown below. Remember it does not try and keep in sync with the controller other than notifying it of a change by the switch.
      As @dbemowsk has already said you should also try and find out why the node is losing its uplink to the gateway.
      Sketch untested but I think should be ok
         Relay with toggle switch sketch
         modified to work with no uplink
         to gateway
         Toggle switch connected between pin3 and ground.
      #define MY_DEBUG                               // Enable debug prints to serial monitor
      #define MY_RADIO_NRF24                         // Enable and select radio type attached
      #define MY_TRANSPORT_WAIT_READY_MS 5000        //set how long to wait for transport ready in milliseconds
      #include <Bounce2.h>
      #define RELAY_PIN  4      // Arduino Digital I/O pin number for relay
      #define SWITCH_PIN  3     // Arduino Digital I/O pin number for switch
      #define CHILD_ID 1        // Id of the sensor child
      #define RELAY_ON 1
      #define RELAY_OFF 0
      Bounce debouncer = Bounce();
      int oldswitchState = 0;
      bool state = false;
      bool firstStart = true;
      MyMessage msg(CHILD_ID, V_STATUS);
      void setup(){
        pinMode(SWITCH_PIN, INPUT_PULLUP);           // Setup the button pin, Activate internal pull-up
        debouncer.attach(SWITCH_PIN);                // After setting up the button, setup debouncer
        debouncer.interval(5);
        pinMode(RELAY_PIN, OUTPUT);                 // set relay pin in output mode
        digitalWrite(RELAY_PIN, RELAY_OFF);         // Make sure relay is off when starting up
      void presentation()  {
        sendSketchInfo("Relay & Toggle", "1.0");
        present(CHILD_ID, S_BINARY);
      void loop(){
      if (firstStart) {                            // this code is only run once at startup
        debouncer.update();
        oldswitchState = debouncer.read();         // set oldswitchState to the current toggle switch state
        send(msg.set(false), false);                              // notify controller of current state no ack
        firstStart = false;                       // set firstStart flag false to prevent code from running again
        debouncer.update();
        int switchState = debouncer.read();                               // Get the update value
        if (switchState != oldswitchState) {                                    // check for new throw of toggle switch
          state =  !state;                                          // Toggle the state
          digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);    // switch the relay to the new state
          send(msg.set(state), false);                              // notify controller of current state no ack
         oldswitchState = switchState;
      /*-------------------start of functions--------------------------*/
        if (message.type == V_STATUS) {                                   // check to see if incoming message is for a switch
              state = message.getBool();                                  // get the new state
              digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);      // switch relay to new state
              /*---- Write some debug info----*/
              Serial.print(message.sensor);
      A 1 Reply Last reply
      • Boots33B Boots33
           to gateway
        #define RELAY_ON 1
        #define RELAY_OFF 0
        bool state = false;
        void setup(){
        void loop(){
          debouncer.update();
          debouncer.update();
        A
        A
        ago1980
        @boots33 ok thanks does it work, wanting to add another relay?
        • A ago1980
          Boots33B
          Boots33B
          Boots33
          @ago1980 It should work but as I said i have not tested it. You may still need to tweak it to suit your setup.
          To add extra relays I usually just duplicate the code if it is only two relays but more than that you will probably want to use a loop and perhaps an array to assign the variables etc. You will also need to add some code to your void receive function to sort out which switch/relay the incoming message is for.
          The RelayActuator sketch in the MySensors examples shows a way to add more than one relay.
          You could also have a look at my AC power controller project for an idea of how to use a case statement in the receive function to filter the incoming messages.
          • zrom69Z
            zrom69Z
            zrom69
            thanks for the work you did
            i add the motion sensor and light level sensor its not working well
            you can help me thank you
            to gateway
            #define CHILD_ID_LEVEL A0
            #define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
            #define SWITCH_PIN 4 // Arduino Digital I/O pin number for switch
            #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
            #define CHILD_ID_MOT 2 //motion sensor
            #define CHILD_ID_LEVEL 3
            #define RELAY_ON 1
            #define RELAY_OFF 0
            bool state = false;
            int photocellPin = 0; // The photoresistor and resistance 10 / 12KOhms connected on the pin / analog pin A0
            int photocellReading;
            unsigned long interval= 6000;//dht.getMinimumSamplingPeriod(); // the time we need to wait
            unsigned long previousMillis=0; // millis() returns an unsigned long.
            MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
            MyMessage msgLight(CHILD_ID_LEVEL, V_LIGHT_LEVEL);
            void setup(){
            present(CHILD_ID_LEVEL, S_LIGHT_LEVEL);
            present(CHILD_ID_MOT, V_TRIPPED); //me
            void loop(){
            debouncer.update();
            debouncer.update();
            // Read digital motion value
            // only run loop if time has passed.
            unsigned long currentMillis = millis(); // grab current time
            // check if "interval" time has passed
            if ((unsigned long)(currentMillis - previousMillis) >= interval) {
            send(msgMot.set(tripped?"1":"0"));
            photocellReading = analogRead(photocellPin)/10; // Conversion en 100% (approximatif)
            // Valeur de la photorésistance avec lampe torche devant = ~1000
            Serial.print("Luminosité : ");
            Serial.println(photocellReading);
            send(msgLight.set(photocellReading, 1));
                  if(tripped == 1 && photocellReading < 30)           // Si la luminosité est inférieure à 30%
            #ifdef MY_DEBUG
            Serial.print("Motion: ");
            Serial.println(tripped);
            /-------------------start of functions--------------------------/
