  3. Home Assistant
  4. Gateway type
Gateway type
9 Posts 3 Posters 3.0k Views 3 Watching
  • K Offline
    K Offline
    karacay
    I need some advice on gateways. I have a RPi 3 and Arduino Pro minis. They will communicate with NRF24s. I will use arduinos as sensor and actuator. There is no sensor or actuator at RPi for now. Rpi has internet access via wifi, Arduinos don't. I installed Home Assistant manually in a virtual environment at RPi as described at their website.
    My purpose is to automate my home using every possibility like Google Assistant, Apple Home Kit, Home Assistant app from inside or outside of home network.
    Because I am a beginner, I need some help to choose gateway type and configure RPi.
    • L Offline
      L Offline
      LastSamurai
      Serial Gateway is the easiest I guess but you can use every gateway that Home Assistant supports. Mainly depends on the physical position of the gateway I guess (if you can use serial or need a networked one).
        If you can, I'd connect a nrf24 module directly to the rpi and run mysensors ethernet gateway then use the other nrf24 on the pro mini
        • K Offline
          K Offline
          karacay
          @LastSamurai said in Gateway type:
          i tried to setup ethernet gateway. But i got failure message on both arduino and RPi. Is there any mistake on codes? A few days ago I tested NRF24s and were working.
          RPi Debug
          mysgw: Starting gateway...
          mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: !TSM:INIT:TSP FAIL
          mysgw: TSM:FAIL:CNT=1
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:FAIL:RE-INIT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:CNT=2
          Arduino Debug
          3 TSM:INIT
          4 TSF:WUR:MS=0
          11 TSM:INIT:TSP OK
          13 TSM:FPAR
          15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          2022 !TSM:FPAR:NO REPLY
          2024 TSM:FPAR
          2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          4034 !TSM:FPAR:NO REPLY
          4036 TSM:FPAR
          4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          6046 !TSM:FPAR:NO REPLY
          6048 TSM:FPAR
          6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          8058 !TSM:FPAR:FAIL
          8059 TSM:FAIL:CNT=1
          8061 TSM:FAIL:PDT
          Rpi Gateway Codes
          git clone https://github.com/mysensors/MySensors.git --branch master
          cd MySensors
          ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003 --my-gateway=ethernet --my-controller-ip-address=192.168.1.20 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 --my-leds-err-pin=7
          make
          sudo ./bin/mysgw -d
          Home Assistant - configuration.yaml
          mysensors:
            gateways:
              - device: '192.168.1.20'
                persistence_file: 'path/mysensors.json'
                baud_rate: 115200
                tcp_port: 5003
            optimistic: false
            persistence: true
            version: '2.1.1'
          arduino code
           * Version 1.0: Henrik EKblad
          // Enable debug prints
          #include <DHT.h>
          #define DHT_DATA_PIN 3
          #define SENSOR_TEMP_OFFSET 0
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          float lastTemp;
          float lastHum;
          uint8_t nNoUpdatesTemp;
          uint8_t nNoUpdatesHum;
          bool metric = true;
          DHT dht;
            sendSketchInfo("TemperatureAndHumidity", "1.1");
            present(CHILD_ID_HUM, S_HUM);
            dht.readSensor(true);
            if (isnan(temperature)) {
              lastTemp = temperature;
              if (!metric) {
              // Reset no updates counter
              nNoUpdatesTemp = 0;
              #ifdef MY_DEBUG
              Serial.print("T: ");
              Serial.println(temperature);
            } else {
              nNoUpdatesTemp++;
            if (isnan(humidity)) {
              lastHum = humidity;
              nNoUpdatesHum = 0;
              #ifdef MY_DEBUG
              Serial.print("H: ");
              Serial.println(humidity);
            } else {
              nNoUpdatesHum++;
            sleep(UPDATE_INTERVAL);
            the rpi gateway is not able to communicate with the nrf24. Try to use the development branch and try without
            --my-controller-ip-address=192.168.1.20 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 --my-leds-err-pin=7 (I didn't use them and it is working fine)
            and follow the instruction on how to connect the radio in the build section.
            K 1 Reply Last reply
              K Offline
              K Offline
              karacay
              if it is not able, how will rpi get the data?
              I was planning to communicate over NRF24L01.
                I meant the error you are getting from rpi console means there is a communication problem between RPI and nrf24. Also in the arduino node it's better you set a node id for the moment.
                • K Offline
                  K Offline
                  karacay
                  aah sorry. will try to set a node id on arduino and then change gateway config as below.
                  • K Offline
                    K Offline
                    karacay
                    i thinked it worked with ./configure --my-transport=nrf24
                    i will try to configure home assistant tomorrow thanks..
