Gateway type
    I need some advice on gateways. I have a RPi 3 and Arduino Pro minis. They will communicate with NRF24s. I will use arduinos as sensor and actuator. There is no sensor or actuator at RPi for now. Rpi has internet access via wifi, Arduinos don't. I installed Home Assistant manually in a virtual environment at RPi as described at their website.
    My purpose is to automate my home using every possibility like Google Assistant, Apple Home Kit, Home Assistant app from inside or outside of home network.
    Because I am a beginner, I need some help to choose gateway type and configure RPi.
    Serial Gateway is the easiest I guess but you can use every gateway that Home Assistant supports. Mainly depends on the physical position of the gateway I guess (if you can use serial or need a networked one).
    If you can, I'd connect a nrf24 module directly to the rpi and run mysensors ethernet gateway then use the other nrf24 on the pro mini
  • @LastSamurai said in Gateway type:
    i tried to setup ethernet gateway. But i got failure message on both arduino and RPi. Is there any mistake on codes? A few days ago I tested NRF24s and were working.
    RPi Debug
    mysgw: Starting gateway...
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:FAIL:RE-INIT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=2
    Arduino Debug
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:FPAR
    15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2022 !TSM:FPAR:NO REPLY
    2024 TSM:FPAR
    2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4034 !TSM:FPAR:NO REPLY
    4036 TSM:FPAR
    4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6046 !TSM:FPAR:NO REPLY
    6048 TSM:FPAR
    6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8058 !TSM:FPAR:FAIL
    8059 TSM:FAIL:CNT=1
    8061 TSM:FAIL:PDT
    Rpi Gateway Codes
    cd MySensors
    ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003 --my-gateway=ethernet --my-controller-ip-address=192.168.1.20 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 --my-leds-err-pin=7
    make
    sudo ./bin/mysgw -d
    Home Assistant - configuration.yaml
    mysensors:
      gateways:
        - device: '192.168.1.20'
          persistence_file: 'path/mysensors.json'
          baud_rate: 115200
          tcp_port: 5003
      optimistic: false
      persistence: true
      version: '2.1.1'
    arduino code
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    // Enable debug prints
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    the rpi gateway is not able to communicate with the nrf24. Try to use the development branch and try without
    --my-controller-ip-address=192.168.1.20 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 --my-leds-err-pin=7 (I didn't use them and it is working fine)
    and follow the instruction on how to connect the radio in the build section.
  • if it is not able, how will rpi get the data?
    I was planning to communicate over NRF24L01.
    I meant the error you are getting from rpi console means there is a communication problem between RPI and nrf24. Also in the arduino node it's better you set a node id for the moment.
  • aah sorry. will try to set a node id on arduino and then change gateway config as below.
  • i thinked it worked with ./configure --my-transport=nrf24
    i will try to configure home assistant tomorrow thanks..
  • 6
