  3. Battery Door switch without debounce
3 Posts 2 Posters 1.7k Views 3 Watching
    MagnusF
    I have a battery operated node with a door switch using sleep and no debouncer.
    The node seem to work well but I have some thoughts about reliably in my sketch.
    The first 2 lines in the "void loop()" is:
    wait(50); // Short delay to allow switch to properly settle
    value = digitalRead(BUTTON_PIN);
    and the last is:
    sleep(digitalPinToInterrupt(BUTTON_PIN), CHANGE, SLEEP_TIME);.
    As I have understand, when the door e.g. is opened during sleep time the arduino wakes up and starts the loop from the beginning, is this correct?
    If so, will "wait (50)" prevent "bouncing"?
    YveauxY 1 Reply Last reply
    • M MagnusF
      and the last is:
      YveauxY
      YveauxY
      @MagnusF as the sleep statement is the last entry in the loop, the next command from your loop will be the 50ms delay.
      50ms should normally be sufficient for a mechanical switch to settle, so the value read will reflect the state of the switch.
      Should your switch take longer than 50ms to debounce, the value read will be arbitrary.
      M 1 Reply Last reply
      • YveauxY Yveaux
        MagnusF
        @Yveaux Thanks, it helped me.
