  3. Firmware does not load MYSController & MYSBootloaderV13pre
myscontrollerfirmware over the airmysbootloader
2 Posts 2 Posters 2.3k Views 2 Watching
  • I
    I
    itbeyond
    I am not sure what I am doing wrong but I have been working on MYSController to perform OTA on my network. I have a VeraEdge and Ethernet gateway setup for the main operation. I have now added MYSContoller onto my PC and it seems to connect and read data from the Ethernet connection fine and does not seem to clash with Vera. I must admit if I need to work on a node ie: do multi function like - reboot then request presenation or assign firmware I need to disconnect and re-connect to the Etehernet gateway (not sure if this is right or even if the way I am using it is supported). Anyway I assign a new firmware build to a node and then request reboot (have to connect/disconnect/connect). But it all runs however in the logs I get this:
    [2017-11-12 16:52:58.265 Info] RX 10;255;4;0;0;FFFFFFFF080004C30102
    [2017-11-12 16:52:58.265 Info] CHILD New child discovered, node id=10, child id=internal
    [2017-11-12 16:52:58.266 Info] DEBUG Undefined firmware/type for node=10
    [2017-11-12 16:52:58.266 Info] INFO BL version=258
    [2017-11-12 16:52:58.266 Info] INFO Send FW info to node 10: type=C, version=4, blocks=0x0438, CRC=0xD69E
    [2017-11-12 16:52:58.271 Info] TX 10;0;4;0;1;0C00040038049ED6
    [2017-11-12 16:53:01.598 Info] RX 10;255;4;0;0;FFFFFFFF080004C30102
    [2017-11-12 16:53:01.599 Info] DEBUG Undefined firmware/type for node=10
    [2017-11-12 16:53:01.599 Info] INFO BL version=258
    [2017-11-12 16:53:01.602 Info] INFO Send FW info to node 10: type=C, version=4, blocks=0x0438, CRC=0xD69E
    [2017-11-12 16:53:01.614 Info] TX 10;0;4;0;1;0C00040038049ED6
    [2017-11-12 16:53:04.937 Info] RX 10;255;4;0;0;FFFFFFFF080004C30102
    [2017-11-12 16:53:04.937 Info] DEBUG Undefined firmware/type for node=10
    [2017-11-12 16:53:04.937 Info] INFO BL version=258
    [2017-11-12 16:53:04.938 Info] INFO Send FW info to node 10: type=C, version=4, blocks=0x0438, CRC=0xD69E
    [2017-11-12 16:53:04.940 Info] TX 10;0;4;0;1;0C00040038049ED6
    [2017-11-12 16:53:10.500 Info] RX 10;255;0;0;17;2.2.0-beta
    The node states to send new firmware but then simple seems to boot the old code. Any help appreciated.
    petewillP 1 Reply Last reply
    • I itbeyond
      petewillP
      petewillP
      petewill
      @itbeyond I ran into issues with multiple connections to my Ethernet gateway. My current config is to route my Vera through MYSController. If I do that I'm able to upload new firmware without any issues. Also, check the distance/reception of the sensor. I had one with poor reception that either didn't upload or took 20 minutes. When I changed the radio antenna config it worked in about a minute.
